-Engine braking
Just catching up over the past couple of days. Good stuff here! Thanks for posting the maps and all your testing/tweeks!
I'm going to look at running the one Tad posted up for my 12. So, if I read this correctly, I can change from fuel bias to TPM/RPM. This won't mess up anything on the work done to this map? Also, regarding the engine breaking..Tad..were you serious about it screwing up your work?
Do not touch the engine breaking sliders, I optimized the engine breaking by hand in the individual maps. If you touch them, it will overwrite all my changes. Anything else in the general settings tab, feel free to change to match how your bike is set up.
Don't use Power Commander map..
I was using PC map for akra exhaust with db killers, y pipe, exup on, 02 disconnected.
160km before the lack of fuel :S
No more power..
I sent the PC map to Jamie he say's to me that it was shit !! (extra fuel @ iddle etc)
I subscribed to this thread awhile ago before I bought a Flashtune kit for my 2010 R1. My objective in buying the kit was to smooth out the power delivery of my bike and rid it of the stock US restrictions. The throttle response in low gears was very abrupt as was the engine braking.
The thread is currently at 286 pages. Without having to search through this monstrosity - has this group created a list of favorite (tested) baseline configurations? :yesnod
I think I'm going to keep things simple at first and just try the 07-08 R1 PumpGas91+ base map to get a feel for things.
The guy I talked to on the phone says the stock R1 fuel map should be fine for normal riding and stock pipes (slip ons are going on this weekend).
A couple questions I have before I flash thing thing for the first time:
1. I watched the video and only see 1 engine breaking slider in it, the version I have has two, one for ETV devel % and another for Fuel/Ign. Now with the bars both at 0%, does this mean the same as stock? And what is the difference between the two? If I slide them to the right, will that give me less engine breaking?
2. Do I need to do anything with fuel map bias?
3. When I selected the 91 octane base map, the quick shifter box was selected, I'm guessing since I don't have a quick shifter that it should be unchecked. Can someone confirm this for me?
4. What does AIS mean? Disable or leave enabled?
Any pointers would be great at this point. Let me know!
There are some bugs in the flash-tune software. Slide the ETV slider to 50%, then back to 0%, before flashing. The ETV slider fakes a reduction in engine braking by keeping the throttle applied slightly when you go off the throttle. The Fuel/Ign slider adds fuel and ignition advance to reduce the engine braking (the "right" way to do it).
Just flashing the ECU disables fuel injector shut off on deceleration, which reduces the engine braking by about 30% (in my opinion). If you want even less engine braking, slide the fuel/ign to 76% and that'll take out another 20% of the engine braking, giving you a 50% reduction in total. I don't suggest using the ETV slider at all (except to slide to 50% then back to 0% to fix a big in the flash-tune throttle maps).
Nope, if you set it to TPS vs RPM it'll run the bike in the high load/performance map all the time (and totally disable the O2 sensor), which will hurt your highway fuel economy a bit.
You can leave the box checked, so if at any point in the future you want to add a quick shifter, you'll be all set up for it. It makes no difference if it's not hooked up
Do NOT disable AIS until you remove the catalytic converter as it can create an unsafe condition where unburnt fuel combusts on the front of the catalytic material and can melt it causing a restriction in exhaust flow. AIS is the Air Injection System, an anti-pollution measure, as well as protection for the catalytic converter, commonly disabled by installing "smog plates"
You the man Jamie! Those tips are just what I needed to get started.
So once I get my slip ons this weekend, the only things I should change are a PCV fuel map and enabling AIS? Are there any other changes I need to make?
I threw some baffled stock cans on the other month for a few days and the bike didn't run very well, I'm guessing due to the lack of the stock can back pressure. Will the PCV slip on map fix this? Or is it something else I need to tweak?
Ok so I just flashed Tad's tweaked map to my ECU. I took it for a spin around the block to get some gas. Feels like pretty good linear power on my butt dyno in 1st and 2nd gear. I did not get to run in the "fun zone" of 12-14K RPM. For some reason the map idle'd very very low (sub 1200RPM) especially after a few minutes of warming up.
I activated the data logger for the ZAFM and got the following results- overall I feel pretty good about the map and will continue to use it. Better power in midrange and where I was able to run between 5k-12K rpm (it was 5 oclock rush hour out and I didnt want to be a statistic this afternoon)
Overall I'm pretty happy and will log a few good sessions on the ZAFM to map it towards 12.9-13.0 AFR. I remapped with using the idle speed adjustment and manually changed the values to get a 15-1600 RPM idle.
Special thanks to Tad, Oilfield, and Elwin for contributions to make up this map. For those of us that are not tuning "specialist" we surely appreciate the work you guys have done. I'll continue to post my feedback and tweaks as I get them as well.
Glad you like it. Af/r's should be perfectly safe as is. I liked my idle low, the lumpy exhaust note gives me a chubby lol. This was posted up as a starting point for exactely what you are doing since all the other generalized maps have been crap so far. Have fun with it!
I ran the map with Tps vs Rpm setting ( it was preset to 50% bias) did not change any sliders whatsoever, and preset Ft to start in A mode. ( it was preset to std mode)
Am I doing this right or should I set anything else a specific way before I run Zafm capture and adjustments?
Got the ECU flashed this evening, process was very easy and straight forward. Started with the base map and then I'll get a little experimental once the slip ons come this Friday. I can't wait to try her out tomorrow morning on the way to work! Very excited!
Not sure if this has been discussed already because I haven't read through the whole thread.
I got my ECU flashed by Flashtune at the end of October last year with 350 miles on the bike. I put the bike away in storage the beginning of December with about 900 miles on it.
Fast forward to last week it was about 45 degrees out so I decided to go for a quick ride.
I figured the bike was pretty much broken in by now and decided to get in to the upper RPM's in "A" mode and in 1st gear just to see what it was like.
I noticed that after 6K the throttle seemed to get really "jerky."
At one point I got up to around 10K and just let off the throttle and once it got down to around 6K it seemed like it just hung there for a second or two and then dropped down.
Has anyone else noticed this at all?
I love A mode because of the power, but Standard mode is so much more smoother!!
If you e-mail flash tune sometime in the next month or so they'll e-mail you the map they used to flash your ECU. Post it online and we can take a look at it and see what they messed up. From the few I've looked at they tend to really mess up the engine braking/throttle maps to do what you describe. They usually only modify A mode, STD and B are stock, that's why they aren't messed up.
The other option is purchase the equipment and re-flash it yourself with one of the awesome maps posted here.
And this one too please. The Air to fuel is very important so please check them. This one has modified injector proportioning. Will be interesting to see what it gives compering to previous.
Ok so what slider settings, fuel bias, and mode settings do you recommend? A mode, Tps vs rpm, etc. I have bazzaz Zafm TC QS, Leo Y pipe, gytr slips, and ais block offs. Gearing is -1 up front.
So I got to ride the bike this morning, it was wet out so I couldn't go too hard. Everything felt really good. Take offs were much smoother and the throttle response seems much more smoother. The reduced engine breaking is much much nicer for day to day riding.
There were a couple things I had questions about regarding idle and returning to idle.
1. On a stock ECU, the bike has a high idle for a minute or two on cold startup to get the engine warmed up faster, I did not see that happen this morning. Was this setting removed with the flash?
2. When I pull the clutch in after acceleration or am in neutral and blip the throttle, it seems like the engine revs take longer than they used to to come back down to normal idle. Now is this the ETV decel setting? Or something else?
Unfortunately with the newer versions of the flash tune software (you probably have 1.5.4.0) they removed this. They also removed full manual control of the actual idle (more of an issue on R6 not R1). I am still using version 1.2.2.0 of flash-tune so I can have a high cold idle (2k rpm) and then a low normal idle (1200rpm).
It is due to the fuel injectors not shutting off at 0 throttle anymore, as well as if you've adjusted the ETV slider to anything other than 0 (or if you're using a custom map someone made, they may have put ETV settings right in the throttle map), then it can cause it a bit of RPM "hang" as well.
A. The engine braking. ETV and fuel/ignition bias. cant seem to figure out a base line. I have read back but from what i read seems conflicted with my setup.
By just flashing the bike you'll disable injector shut off on deceleration, which reduces the engine braking by 30% imo. That's a good place to start. If you want to remove more engine braking slide the fuel/ign engine braking slider to 76%, that'll take out an addition 20% of the engine braking for a 50% total reduction.
You can't use fuel map bias unless you're running the factory O2 sensor (which you're not cause you got autotune). So set the bias to TPS vs RPM which will tell the bike to ignore looking at the factory O2 sensor and to use the high load/performance map 24/7.
If fuel economy is a concern we can set up a fuel economy region in your autotune AFR table so that when cruising it'll lean it out.
i just got my Flash tuner last week and the weather should be breaking here in jersey soon, i plan on jumping on this whole tuning bandwagon you guys have going.
First off thank you Tad for the FAQ page and everyone else here helping with maps and tunes.
I have been tuning with my bazzaz and autotune quite well and have a pretty good handle on it. I run a 3/4 leo vince system with smog plates and race filter. However with incorporating the Flashtune i'm good with every thing except 2 things.
B. The fuel map bias check box and options. same as A above i have read things but it seems conflicted given what i have installed on the bike.
I appreciate any help getting started and plan to give back 100% once i get her back on the road full time and able to get some testing going.
HI ALL
GOOD TO SEE THE 07-08 r1 guys,some nice advice coming together keep it .
also i have the cordona gp strain gauge q/shifter,now working sweet as,have to say awsome mod a must for all riders .do these do any harm to the g/box.
looked at my kill times and think they like this.
1st 60ms/2nd 60ms/3rd 65ms/4th 70ms/5th 75ms/6th 80ms.
any other setup to try mine is good but little jerky at times maybe me just being picky
also is the forced idle working for you other R1 07/08 Riders,seems to go down a bit lowest is around 1400 for me ,maybe a little higher when hot,anyone know why it does that when hot or ridden quicker,but think that will be o.k. as i like mine just a bit over stock 1200ish
I got in touch with one guy from Italy who can do YEC flash to standard ECU.
Some Q/A:
Do I need to send you my ECU? YES
Do I need to change motorcycle wiring? NO, just need to do few swap wires into the ecu plugs, we supply details to do that.
Will my speedometer and lights work? YES, all as stock
Will I nee to disconnect O2 sensor? IF you want yes, you can choice trough the YEC software.
Does this ECU actually has all the base maps as original YEC for 2009, and if Yes, then how do I switch between them? Is there functionality for speed limiter, map switching, etc… all the function are there, may need to add some switch, just following the instruction pdf, pitlane, orr quick shift,ecc
Will it control AIS to I would need to block it off? YES, trough the YEC software
How long is the turnaround time? 5-6 days
Correct, he's manually tweaked the maps to build in a reduction in engine braking. DO NOT touch the etv slider. Even if you accidentally fondled it, close flash-tune and start over.
Everyone runs his map with stock stacks so I'd assume the 8k is good to go as well.
-Jamie M.
