FlashTune ECU Flashing Interface - Page 220 - Yamaha R1 Forum: YZF-R1 Forums
 55Likes
post #4381 of 12628 (permalink) Old 11-04-2012, 10:25 PM
J58
Mach.81's Avatar
Originally Posted by SySt View Post
For best results, go to the diag mode and energize the EFI circuit to power up the PCV properly. Now set the min and max TPS voltages while in the diag mode. If you don't energize the EFI circuit it will not work. To energize the EFI circuit you can jump 12v+ into one of the injector connectors or the fuel pump connector. Be careful and consult the wiring diagram if you're in doubt.
If you set the min TPS voltage with the engine at idle, you will offset the map once it's loaded into Flashtune because on the ECU fuel maps 0% TPS is with a closed throttle, not a slightly open throttle such as during engine idle.
Funny do you know why dynojet gets us to set up min voltage at idle? What do they know?
What the reasoning behind this?
Mach.81 is offline
post #4382 of 12628 (permalink) Old 11-04-2012, 10:40 PM
Originally Posted by Mach.81 View Post
So youre saying: when making value changes in fuel/ignition maps the percentages applied are off or incorrect. How are you determining whats the correct percentages for the changes? Stock values math applied?
i have looked at a few fuel logs that i have seen from some of the maps tried on here and also dyno sheets with the AF on them.
if you pull up a stock map and the 91 + and look at them you can see the differences. and if you compare most of the maps the 91+ you will see that the percentage havent changed from the 91+ map.
R1evolution is offline
post #4383 of 12628 (permalink) Old 11-04-2012, 10:54 PM
J58
Mach.81's Avatar
Sounds good..thx for the heads up. How are you determining advanced ignition timing values? Tuning then feedback from testers?
Mach.81 is offline
post #4384 of 12628 (permalink) Old 11-04-2012, 11:01 PM
v1025566's Avatar
Where are you getting that? Absolutely not, I would recommend the opposite: TPS vs RPM selection. The only thing I explained is that either selection can be made. For instance, if I was to run a supercharger or turbocharger I probably would use the MAP vs RPM only option.
thanks, that's what I was after. When you hover over it to get the explanation of what it does in the updated version it brings up about the fan temperature.
v1025566 is offline
post #4385 of 12628 (permalink) Old 11-04-2012, 11:06 PM
J58
Mach.81's Avatar
SyST
May try this : PCV WOT voltage calibration.
throttle position diag. mode 09 r1
Cheers
Mach.81 is offline
post #4386 of 12628 (permalink) Old 11-05-2012, 03:38 AM
R1, art of engineering
Halo_2's Avatar
Im suprised they havent made a ecu mod to change fahrenheit to celsius
Halo_2 is offline
post #4387 of 12628 (permalink) Old 11-05-2012, 05:24 AM Thread Starter
Since the engine doesn't really operate in TPS values below the idle TPS value. When engine breaking in gear the injectors shut off anyways. Scaling 0 still equals 0.
SySt is offline
post #4388 of 12628 (permalink) Old 11-05-2012, 05:27 AM Thread Starter
SyST
Cheers
That'll probably accomplish the same thing. You may want to try both and compare. It's probably unlikely but the servo may open the butterflies slightly less when the bike is at WOT than when you are holding them open. In other words, the mechanical stop of the butterflies may occur beyond WOT. Just something to think about and maybe verify.
SySt is offline
post #4389 of 12628 (permalink) Old 11-05-2012, 06:27 AM
Trackday junkie!
Powerflux's Avatar
Originally Posted by vcyclenut View Post
go into the fly by wire settings and for each gear above 5500 from 0-1% throttle put 2's in. I entered 3's in every gear but first but others have had bad results with this so start conservative. for me its smooth as silk coming from closed throttle and re opening it. no bump at all!!
Ok, I`m trying to wrap my head around this value vs percent bug that R1evo has talked about. The percent view really looks out of whack
This is just for testing so I haven`t tried it on the bike yet. I have entered 1`s instead of zero`s in the two first columns from 5000 up.
First pic is in value mode, left side map with the adjustments, right side map before adjustment!
Second pic is percent mode(even tho the drop down menu still shows value), again left side map with the adjustments, rightside map before adjustment.
How can a bug like this NOT be high on the bugfix priority list
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #4390 of 12628 (permalink) Old 11-05-2012, 06:43 AM
J58
Mach.81's Avatar
Thx for the info SyST. Interested to see the comparison. Also have you figured out what specifically causes he injectors to shut off? Is it the min TPS voltage the ecu see's or is it the throttle mapping "0" or combination of both? A lot of this popping on decel is caused by this shut-off injector sh*t.
Mach.81 is offline
post #4391 of 12628 (permalink) Old 11-05-2012, 06:47 AM
Please report back your opinions on that, especially in A mode!
This is also what I'm trying to understand.
AKDMA is offline
post #4392 of 12628 (permalink) Old 11-05-2012, 07:01 AM
n4speed's Avatar
That's not all... if you use the 1.2.20 version.. same values.. diferent percentages.. if i knew what i know now, i would never flash my bike.. the EU map with power comander is better.. i saw that on the dyno with a bike of a friend of mine... only on the top end the bike as a little more..
09 Yamaha R1
Flash Tune ECU
DanMoto Cans and Y Pipe
Stomp Grip Pads
Integrated tail ligth
Double Bubble Screen
GoodRidge Brake Lines
Addon Radiator
HM QuickShifter
n4speed is offline
post #4393 of 12628 (permalink) Old 11-05-2012, 07:11 AM
J58
Mach.81's Avatar
DynoJet sells a secondary ignition module that allows up to 20* advancement. Haven't been that ambitious yet.
Cheers
Here's the link. Not so sure I'ed use 20* advancement
http://www.powercommander.com/powerc...on_module.aspx
Mach.81 is offline
post #4394 of 12628 (permalink) Old 11-05-2012, 07:29 AM
Astronomer not Astrologer
Tad158's Avatar
Flux, I think that stems from changes in the ETV slider....
#158
2009 Raven R1
Tad158 is offline
post #4395 of 12628 (permalink) Old 11-05-2012, 07:33 AM
Trackday junkie!
Powerflux's Avatar
Don`t think so! Both maps are with the sliders at 0!!
M4 Y-pipe
K&N filter
ProGrip 714 grips
SpeedoDrD
Black Shorty Levers
Graves clutch kit
post #4396 of 12628 (permalink) Old 11-05-2012, 08:03 AM
something im having a issue with is the fact that you all have been running these maps in your bike well before i got to the boards or even known about the software.
The only reason i even started looking at this was because my bike ran like crap from Yamaha.
so enter me. i start looking at all the number and trying to get a feel for the software and try to figure out how i can make my bike better. i commute everyday on my bike so i wanted it to be better. then i start to find bug i make some adjustment the way i like on my bike and realize that the adjustments i made worked better and better. I just figured that stock was a 0 % seeing how thats what it is on the stock map. so i built upon that 0 was my stock number and saw all of the negative number in the YCC and said to my self why would they be less then stock and noticed the power commander maps where pulling fuel in the areas of the negative numbered areas. which means to me that its not getting enough air or to much fuel .but seeing how they where all negative number (below stock) i decided to make a few ycc changes and you guys said it was a better response already. now these adjustments where brought back to stock level. then adjusted a head by just a few percent where people said they had on off throttle.
i had already made these adjustments on my bike as well and noticed a large difference in the response. so before i ever made changes to your maps i trid them on mine 1st.
So i think for now i will keep my adjustments and bug i find to my self. I dont want to keep getting at why i did what i did. we should just be focusing on what i found... the bug that could of caused major engine damage and other issues,but i havent heard anyone say thanks. that could of been a bad thing for us. especially when many of you guys track your bike and go canyon riding.
If i wouldnt of tried the changes on my bike already i wouldnt of made the changes to these maps. So i will refrain from telling anymore bugs that i have found and how to work around them.
Let be honest if i found a way around the bug or fixed it with some adjustments after only knowing the software after a week and said something.
Why isnt FT on here telling all of us hey guys im working on this and so forth.
there has been no help from him,but i have.
so i will wait till i get more information about what and why i did what i did.
so i wont be posting the new bugs in software till i find out for sure what the impact will be.
post #4397 of 12628 (permalink) Old 11-05-2012, 09:04 AM
SoloStunna99's Avatar
Keep doing what you do man. There are alot of folks up here that appreciate what you do
STOLEN - '04 CBR1000rr
STOLEN - '04 GSXR1000
SOLD - '05 R1
SOLD - track whore - '08 CBR1000RR
SOLD - '09 R1
track whore - '11 r1 (flashed ECU)
SoloStunna99 is offline
post #4398 of 12628 (permalink) Old 11-05-2012, 09:11 AM
Me included, I just want to make sure it's all on the up and up. Plus, I like learning. Don't feel like I'm being too critical, just wanting some info on your methods.
AKDMA is offline
post #4399 of 12628 (permalink) Old 11-05-2012, 09:26 AM
R1evo,After flashing with your map, my bike is from another world, keep doing what you are doing, I'm grateful to you for wake up the monster on my bike....
Biricchino is offline
post #4400 of 12628 (permalink) Old 11-05-2012, 09:28 AM
ty sir... i looked at your AF logs and they looked good.
