-Engine braking
I would like to see that style in person some day. If you want to stop by or meet up somewhere, I could give you a hand.
In other news, I have officially started a new image v6.0.0 based on the v4.3.2 as a base image, and pasted in all the fuel, timing, and ETV maps from v5.3.15.5. I also made a tweak to the timing to see if I can make it pull less at throttle closed, as I don't remember having that issue with v4.3.2, and the throttle curves are nearly identical in that area, but the timing was different. So I made a small change to the timing below 5.5k RPM and 4% TPS. I will take it for a quick spin tomorrow around my neighborhood, as I still only have the track bodywork on it. I hope that the idle from 4.3.2 is retained...we shall see.
Stage three really is a rather poor method for idle control and was bypassed in earlier software versions.
I have another 09+ R1 racebike coming in tomorrow to confirm everything works as expected then I will add an option to the R1 definitions to extend warmup idle. After setting this to true you will be able to use the warmup/base idle map to adjust the idle.
So it seems that this might be fixed soon enough after all!
This is great news! This also explains why it will hang, as the ECU decides that it suddenly needs to add or subtract a bunch of timing and it kills the engine...So hopefully in the next few days we will have a solution!
So check this out! I got a reply from F-T about the 09+ idle.
Yeah, I just learned today via flash tune that the base idle map values are ignition timing, not TPS like I would have assumed. I guess it's best to adjust the idle ETV comp map to change idle speed.
Hey TAD,
I updated all the definitions for 09+ r1 models today to include an 'extend warmup idle' setting. Just set to true to bypass stage 3 of idle control. this setting will also recall a true value if the files were created with the earlier versions.
You will need to delete the following files to force your software to update from the server.
\Documents\Flash-Tune\Definitions\Retail\
110DYP.fdf , 110CYP.fdf , G706YP.fdf , and G705YP.fdf
It seems that my definitions updated automatically (and I didn't have to delete the above files), as I now have an "Extend Warm Up Idle" option. To use the ECT vs RPM map for all engine temps, you need to have the new option set to true. I will test it out tomorrow after work.
Hello. I'm looking around to buy an old version FT interface for 09+ Yamaha R1. Please PM or send me an email to jagib1972@yahoo.com. Thank you in advance.
Quick question, I'm still running the v.1 software from flashtune and i was wondering if now that i have installed my quickshifter will it require to be re-flashed or will it work right away?
I can't remember if Tad had said that in V1 you didn't have to do anything because the settings for the QS were already set... plz help someone!
Did you activate the quickshifter settings in the software when you last flashed the ECU? Was the switch type (NO/NC) specified correctly? From that, maybe you can answer your own question.
Bungs welded and here its the first a/f log from the y pipe ....
Next its to put the wideband in the cylinder 1 wich i dont know wich one its as you sit on the bike .... first on the left or on the right ... ?
Map in the ecu when i recorded a/f was stock ... and i didnt have where to neiled as it was rush hour .... to much trafic ....
Hey tad. Pretty sure this is what I would need right. This is the bench tuner. The one that I can use on multiple machines. 09-14. Flashtune interface 2.25
Also important to look at the associated numbers around to those odd (high/low) values. Depending how well the Bazzaz proprietary software works on decel those "odd" numbers may appear in the fuel map. Not to worry... Smooth (average) manually with surroundings numbers and collect more data
:epimp
on decel throttle go quickly enough to 0-5% tps area and dont have time to alter the 50 or 60% tps map ... this its what i think ..... maibe im wrong ... but after corecting the a/f to 13.2 its a pleasure to drive the bike ... makes a verry nice sound .... :boobies as you can see in the log it was running like crap to much vibrations from the engine and she dont like 12.4...
and in this log you can see the stock o2 sensor was activated and its working quite whell lock at 0-20%Tps unthil 5.5-6k .... it was aiming for 14.7 i think its setted like this from the factory ... next time i whill deactivate the stock o2 ...
When they initially released the idle fix I tired it, and it was well broken....So I repled to the support ticked to let them know. This is the reply I got today!
Flash-Tune said:
So I was able to get to the bottom of the idle issue...
The original version1 code had a bug that I overlooked when adding it to the definitions this effectively rendered the x axis of the warmup map useless.
I have updated the definitions again so you will need to delete 110CYP.fdf, 110DYP.fdf, G705YP.fdf, and G706YP.fdf but you should have no problems adjusting the idle speed via the warmup base map now. Thanks again!
Good question.....I haven't tried to do it yet. My guess is that you go into the file manager and hit the refresh button on the download new ecu files tab. I will rty tomorrow, as it is past my bed time....but the Bruin's game just went into overtime....so :dunno
