FlashTune ECU Flashing Interface - Page 225 - Yamaha R1 Forum: YZF-R1 Forums
 40Likes
post #4481 of 12550 (permalink) Old 11-09-2012, 01:17 AM
Extended Member
Decreasing Dave's Avatar
Sorry guys, I posted the info about only being able to read my speed up to 152 MPH from my phone and this is the first chance I have had to follow up on that.
Yes, I am -1 in the front with a stock 45 in the rear (2008).
Yes, I adjusted my ratio down to 94%. FTR, I don't think it made any difference in my speedo reading anyway.
Another point worth noting, as I was WFO in 6th gear running up through the 152 indicated MPH, I noticed that if I backed off of the throttle an 1/8th of a turn, that the bike pulled harder. I wouldn't have thought that this would happen considering the F-T program and the 100% throttle, blah, blah, blah. I knew this could happen with carburated bikes as the butterflies would rotate past horizontal at full throttle, so backing off would get you more flow, but with fuel injection and throttle by wire?
I'm also considering going back to my original throttle tube. I don't know if the R6 one would make a difference on anything but the throw, and it doesn't have any negative impact on riding on two wheels, but damn does it make wheelies a sketchy proposition. I thought that I could get used to it, and maybe I can, but I'm taking my life in my hands trying and they ain't pretty wheelies by any means.
Maybe everybody that only reads up to 152 MPH needs to post up their info so that we can see the simularities.
Dave
Decreasing Dave is offline
post #4482 of 12550 (permalink) Old 11-09-2012, 06:33 AM
Astronomer not Astrologer
Tad158's Avatar
Did you determine the 94% correction factor via GPS? Because that is my correction factor with stock gearing. I have verified that this correction factor was spot on via my 10Hz GPS logger up to 130MPH at the track.
The track does not have a long enough straight to go any faster at my put put pace...crash I do agree that this is an odd problem.
Venom Squadron Shirts
#158
2009 Raven R1
Mods: Custom Fender Eliminator, Custom Rear Res. Bracket, Custom Clutch Sliders, Spiegler Rennsport SS F/R Brake Lines, Driven Clip-ons, Spider Peak Grips, Zero Gravity Light Smoke Double Bubble Windscreen, M4 Y-Pipe, Vance&Hines CS One cans, Shogun No-Cut Sliders, F-T custom image with Bazzaz QS sensor, Galespeed VRC MC, Ferodo ST HH Front Pads, RaceDAC Data Logger, RaceTech Springs, F1Composites track bodywork.
Build Thread
Flash-Tune FAQ Thread
Tad158 is offline
post #4483 of 12550 (permalink) Old 11-09-2012, 08:59 AM
cheong1106's Avatar
The speedo correction off the default I used is 4.7% using speedohealer. At track, I have a Dainese D-Air suit which has data logging including GPS tracking and speeds.
At 240kph the diff was 1kph
Hope this helps. I have standard sprockets on.
Sent from my GT-N7105 using Motorcycle.com Free App
cheong1106 is offline
post #4484 of 12550 (permalink) Old 11-09-2012, 10:47 AM
Trackday junkie!
Powerflux's Avatar
Originally Posted by R1evolution View Post
tad is this the YCC that i have? also i talked to chris at FT if you get a chance call me i want to tell you what he said
Anybody tested the YCC tweaks yet??
Also, relaying what the FT guys have to say would be nice
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #4485 of 12550 (permalink) Old 11-09-2012, 12:52 PM
Just thought I'd mention, today I tried the R1evo map but with N4's YCC-T settings to see if it fixed the surging thing, however it remained.
AKDMA is offline
post #4486 of 12550 (permalink) Old 11-09-2012, 12:57 PM
not sure if he sent it to you or not,but i havent. Please let us look at it and see whats going on before you try anymore.
R1evolution is offline
post #4487 of 12550 (permalink) Old 11-09-2012, 01:12 PM
I'm talking about the old one, that we discussed on the phone.
AKDMA is offline
post #4488 of 12550 (permalink) Old 11-09-2012, 02:22 PM
I have sent European 2012 R1 ECU to Chris 3 weeks ago.
Chris will incorporate 2012 R1 EU maps into the flashtune software when they are ready.
He is busy building new software at the moment which I believe is the main reason for delay.
Hope EU maps will provide a lot of information on injector propositioning and ignition.
Elwin is offline
post #4489 of 12550 (permalink) Old 11-09-2012, 03:17 PM
Trackday junkie!
Powerflux's Avatar
Hey Elwin, welcome back
Sounds like good stuff
M4 Y-pipe
K&N filter
ProGrip 714 grips
SpeedoDrD
Black Shorty Levers
Graves clutch kit
post #4490 of 12550 (permalink) Old 11-09-2012, 03:28 PM
Just reading thru some of the post and I can't wait to get mine I got a full graves with a pc5 and auto tuner are there any good maps out there?
gixxerkillinR1 is offline
post #4491 of 12550 (permalink) Old 11-09-2012, 07:52 PM
NEW UPDATE:
11/9/12
- Added Revert Version feature to easily launch all local versions
- Fixed first gear bug for Type 1 gear dependent ETV
- Fixed 2012 R6 Specific Flashing routine
post #4492 of 12550 (permalink) Old 11-10-2012, 01:42 AM
J58
Mach.81's Avatar
Elwin...I'll second that...welcome back. How's the bike running now after all that tuning? Did you get your maps dialed in? Last we heard you had to tweak your mapping for each cylinder. Anymore dyno runs?
Mach.81 is offline
post #4493 of 12550 (permalink) Old 11-10-2012, 08:49 AM
Hi Elwin welcome back, quick Q. did you measure your r1 on dyno(your 4 o2 map), and what was the top end power?
laxwendrof is offline
post #4494 of 12550 (permalink) Old 11-10-2012, 10:41 AM
Welcome back elwin
Biricchino is offline
post #4495 of 12550 (permalink) Old 11-10-2012, 12:54 PM
Ok in a attempt to make A mode more responsive. i need to know what you all expect....
I have made a A mode throttle map that makes it very low input to get smooth consistent throttle till higher rpms then it comes on hard ... Kinda of like a 1/4 turn race throttle set up. there are so many different riders on here and i really need some help with input please. There is not perfect A mode for everyone. I know racer would like not having to do much input to get max power out of the bike,but that also makes it very sensitive to others. Please tell me what you guys want. im trying to balance it out. thanks for any help you can give me to make these maps better
post #4496 of 12550 (permalink) Old 11-10-2012, 01:22 PM
J58
Mach.81's Avatar
Just updated FT..... I now see the YCC-T mapping is all changed to numbers with decimals. Opened my old tried and true maps and they are changed also. Has anyone flashed with this new updated version? Trying to make changes to values, then look at percentages to confirm and go back to value and they revert back to the original numbers? More bugs to deal with...great!
Mach.81 is offline
post #4497 of 12550 (permalink) Old 11-10-2012, 01:40 PM
found the revert version...thx FT.
im not sure my self anymore what to do... they change small stuff and it makes other changes. its like one good map then turns it to crap. I feel like if we make any changes we cant really be sure if there true changes because of the software reading the maps differently. i havent tried my self to flash the new version tho.
post #4498 of 12550 (permalink) Old 11-10-2012, 04:12 PM
J58
Mach.81's Avatar
Stock Yamaha ECU going back in bike untill FT gets this sorted out.
Mach.81 is offline
post #4499 of 12550 (permalink) Old 11-10-2012, 07:54 PM
Tad158's Avatar
As far as I can tell it is calculated correctly. The decimal is there for fine adjustment.
#158
2009 Raven R1
Build Thread
Tad158 is offline
post #4500 of 12550 (permalink) Old 11-11-2012, 01:02 PM
another update...
ecuunleashed 0r flashtune vtwin Appearance & Mods 61 11-16-2014 07:37 PM
Flashtune ECU Dyno Results sirjag Appearance & Mods 183 03-30-2014 05:08 PM
Flashtune reflash 07-08 R1 bwash85 Appearance & Mods 171 06-22-2012 07:48 AM
flashtune VS ecuunleashed vtwin Mechanical / Help 3 03-17-2012 12:50 AM
Yec Cable Interface BERNY Bikes/Parts Wanted 0 03-19-2010 12:58 PM
