FlashTune ECU Flashing Interface - Page 233 - Yamaha R1 Forum: YZF-R1 Forums
 43Likes
post #4641 of 12564 (permalink) Old 11-20-2012, 04:20 AM
cheong1106's Avatar
Originally Posted by chatham View Post
Hello Sydster,
I have spent over three months building some very good maps for my Australian 2012 R1 but I got fed up with not being able to get that sweet spot with the tune when just using the Flashtune...I now use a flashed ECU (no 02)with a PCV and Autotune and this combo has worked so well!!
I'm finally happy with the tune.
It is by far the best money you could spend and In my opinion you need all three..the PCV allows a map to be built for each gear, the Flashtune allows you to disable the 02 and run TPS vs RPM fueling (better for tuning the whole map), and the autotune trims the map for you getting it almost spot on.
If you want a FT map made for a Flashed 2012 r1 EU spec running 98 fuel
y-pipe and GYTR's I have one 99% ready to go.
Just send me a PM if you want it.(it was built by running the Auto tune over the map for a 12.9 AFR)
Send it over!
Sent from my GT-N7105 using Motorcycle.com Free App
cheong1106 is offline
post #4642 of 12564 (permalink) Old 11-20-2012, 04:33 AM
Sydster's Avatar
Hello Sydster,
Just send me a PM if you want it.(it was built by running the Auto tune over the map for a 12.9 AFR on my Flashed ECU)
sweet, pmed u my email.
Sydster is offline
post #4643 of 12564 (permalink) Old 11-20-2012, 04:38 AM
indianfighter's Avatar
Originally Posted by Sydster View Post
so do i need to buy pc and auto tune to create a custom map with my exhaust mods or one that someone made will do?
R1evotion, is this what u are doing? a pcv for 12?
im in the same boat. what would flash tune do without this forum.
i'm learning, so i need to apply a PCV map to base maps even to the 2012 R1 y-pipe & slip-on.ftm map. How do I find the right PCV for my setup which is a GYTR slipons and mid y pipe?
im EU too
You could use a canned map off someone with a similar set up mate. Unless you wanna blow up more money
IndianFighter
2011 white R1
indianfighter is offline
post #4644 of 12564 (permalink) Old 11-20-2012, 04:40 AM
AAAHH-1's Avatar
Originally Posted by marider View Post
OK, Autotune installed (took approx. 1,5h to do it), tomorrow I'll start accepting trims for updated hybrid ECU fuel map. Meantime I'm waiting for the same posibility with Bazzaz, then I'll sell the PCV+AT and go with Bzzzaz (it works with all 8 injectors so fuel map there is more accurate I think without buying next Dynojet SFM-5 unit, not to mention putting all those connectors beneath the airbox in a very limited space..)
n4speed: as for the HM PLUS quickshifter I use 85% sensivity and 60ms kill time, mode C, yesterday I set up my Gilles rearsets to road shift pattern again (my max speed was 286km/h but speedo ended at 224km/h, something has to be wrong with 88% speedo correction I used for ECU reflash last time ).
Yer right? I get 305 km on my 07 R1 with a 9.88 1/4 mile. PCV+AT, removed exup valve, k&n filter, block off plates and graves full system. oh and i forgot to mention, bike dyno tune! No need for this flashing the ecu crap!! Get real!!
AAAHH-1 is offline
post #4645 of 12564 (permalink) Old 11-20-2012, 04:50 AM
Sydster's Avatar
Hello Sydster,
how about a step by step for a noob like me. I havent flashed yet..
so I should use a base map then import ur map into that, select options in general setting then hit flash correct? or import your map in step one of flashtune and hit flash?
sorry if I sound like an idiot. When I moded my Audi TT i simply sent the ECU to the states, got it back running super fast! I just use a software to adjust turbo boost, timing and fueling, simply plus or minus values.... I'm still getting my head around doing all this myself for the bike..
Sydster is offline
post #4646 of 12564 (permalink) Old 11-20-2012, 07:13 AM
Thats not me. Im doing a cylinder by cylinder test with wide band O2 and data log. im still waiting for my )2 bungs to show up
R1evolution is offline
post #4647 of 12564 (permalink) Old 11-20-2012, 10:42 AM
Astronomer not Astrologer
Tad158's Avatar
I got the answer on how the QS works from F-T
For the R1 the qs functions by emulating a rev limiter. It activates an ignition cut determined by the amount of time set in the map.
#158
2009 Raven R1
Tad158 is offline
post #4648 of 12564 (permalink) Old 11-20-2012, 03:18 PM
Hi,
I have something very good for US bikes not restricted throttle ECU(EUROPEAN) r1 rn22 kit(is a new without flash and has imobilaser inside).
Also very good for somebody who would like to save his ECU(eu) before FT.
Absolutely brand new ECU(EU) with imo. full kit (main looms+clock looms+red keys for this ECU(to program any barrel/antena)+ECU(EUROPEAN)+fuel cap)
one black key barrel is on racing bike with YEC ECU.
KIT is for now reserved for N4Speed to Friday
laxwendrof is offline
post #4649 of 12564 (permalink) Old 11-20-2012, 05:05 PM
Send it to flashtune to read and include EU 2009 into software!
Originally Posted by laxwendrof View Post
Hi,
Elwin is offline
post #4650 of 12564 (permalink) Old 11-20-2012, 06:06 PM
cheong1106's Avatar
Well... the 12 R1 has throttle mapping shutting the butterflies back down to 84% open after 11.5k rpm. ( That would explaim the stock power curve flatten / plateau right after that. )
Flashing keeps it at 100%
post #4651 of 12564 (permalink) Old 11-20-2012, 11:37 PM
R1
sorry if I sound like an idiot. When I moded my Audi TT i simply sent the ECU to the states, got it back running super fast! I just use a software to adjust turbo boost and fueling.... I'm still getting my head around doing all this myself for the bike..
Email sent
call me
chatham is offline
post #4652 of 12564 (permalink) Old 11-20-2012, 11:46 PM
Trackday junkie!
Powerflux's Avatar
A big
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #4653 of 12564 (permalink) Old 11-21-2012, 04:49 AM
ghost
frogsak1's Avatar
Hello Sydster,
Chatham live kind near me and what he is saying is correct all 3 units working together makes for a very nice map
frogsak1 is offline
post #4654 of 12564 (permalink) Old 11-21-2012, 09:03 AM
Ryans79's Avatar
Send a message via Yahoo to Ryans79
07 08 R1 Flash ECU
I got a 08 R1, DNA air Filter, Block off plates, Full Graves exhaust system(no exup Valve), Bazzaz ZFI+AFM kit. Bike was pulling super well up 300km/hr. But after I reflashed the ECU with Flash Tune kit, bikes pulls like a bullet and in much less time to the 300km/hr. The front end will fly easily even in 4th gear ...
Ryans79 is offline
post #4655 of 12564 (permalink) Old 11-21-2012, 01:15 PM Thread Starter
Lucky...My 07 has similar mods but i'm running a completely stock fuel map. I'm lucky to get my bike to lift in 2nd gear on power alone. I'm not that heavy at 185lbs.
Sent from my DROID4 using Motorcycle.com Free App
SySt is offline
post #4656 of 12564 (permalink) Old 11-21-2012, 11:46 PM
yamaha rules
Send a message via Skype™ to chrispy121
darn it just purchased a annitori qs as I hadnt had the answer but the main reason is the sensor works in standard and revese shift
chrispy121 is offline
post #4657 of 12564 (permalink) Old 11-22-2012, 12:04 AM
Trackday junkie!
Powerflux's Avatar
And you don`t have a small turbo you forgot to tell us about???........
M4 Y-pipe
K&N filter
ProGrip 714 grips
SpeedoDrD
Black Shorty Levers
Graves clutch kit
post #4658 of 12564 (permalink) Old 11-22-2012, 04:40 AM
Lol, that or a sprocket not much smaller than his wheel.
AKDMA is offline
post #4659 of 12564 (permalink) Old 11-22-2012, 08:18 AM
Feel the speed attack!
marider's Avatar
Send a message via Skype™ to marider
Hi guys,
after 4 days fiddling with R1, resetting the TPS damn sensor, having dried battery and other causing headache problems finally I managed to built up a map that works with Lax hybrid reflash based on Elwin hints (big thanks! ) using Autotune AT-200 and zero map in Power Commander. After almost 100km on a roller / 60 miles/ did a dyno run at the end.. First I did the dyno calibration and set up the minimum revs to 3000 rpm & maximum revs to 14 000 rpm and after the run...
Hit 170,1 RWHP and 103,1Nm (76.67 lb/ft)
Below you have my current dyno charts with the newest run compared to previous one (without the AT-200 unit trims, based on zero map only) and I made additional chart for the Flash-Tune'd ECU with 3/4 Akrapovic, K&N airfilter (road), Graves block offs VS my completely stock European 2009 R1 before the tune-up game ...
As you see the difference is HUGE (proper dyno calibration is a MUST here). I'll smooth it a little bit later, it was hard to hold the throttle all the time at 2%, 5%, 10%, 15% as the numbers flickered +/- 2% (I used a laptop to see how much I twist my hand). Suppose the dips in torque will flatten out similar to my best map trends when I ride more and accept further "city" trims at low throttle openings but for the next dyno runs will have to wait till Spring as snow is coming...
ID:	477274   Click image for larger version
ID:	477275   Click image for larger version
marider
Longest distance between two curves... straight line
EU 09 R1:
full Akrapovic Evo2,F-T'd ECU,Bazzaz ZFi-TC+Z-AFM,Marchesinis,Ohlins damper+FPK108+.95 springs,q'Ohlins r.shock,
Brembo RCS/w Hel&Braking SK rotors,Graves block offs,Clutch Kit,Fabbri screen,GYTR:sliders,clutch sliders,gel seat+cowl,Gilles VCR+Variobar,Gregg's Flushmount,-1/+1 sprockets,CustomLED mod. 3/4Dyno:170.1 RWHP,77 Tq.
marider is offline
post #4660 of 12564 (permalink) Old 11-22-2012, 08:53 AM Thread Starter
Hi guys,
It sounds like you spent a lot of time on a dyno. Too bad you used the AT-200 to tune it rather than the dyno output.
SySt is offline
