-Engine braking
As Tad mentioned, I got a response to my ticket that says if I register my current interface with my email by running the software with the interface hooked up, I will be eligible for the new interface. Sounds fair, but what is everybody doing? Keep the old interface and old software and still be able to flash multiple ECU's or bite the bullet and get the new single ECU setup?
I sent them a ticket email, and they sent me a new interface. Randomly about a day after I got it, I received a refund via pay pal. Had no idea that I was getting a refund.
No he is referring to the fact that he has traded in one of this original boxes for a new F-T cable....
In other news.....I FINALLY got the O2 sensor installed and hooked up to the RaceDAC....and everything seems to be working, but I can't test it till tomorrow....As it is late and I didn't want to piss off the neighbors....
I also got the calibration all squared away with the APS and TPS....So that should be all set and ready for the tuning....
Well I have now received my new interface...But it wont recognize my ECU and redirects me to buy a licence...
Has anyone got the new "latest update 2.1.0.14" of Ftune working? on a just replaced harness.
at the moment its asking for me to pay $100...and not recognizing my ECU to flash.
Hi
The same thing happened to me so I issued a ticket explaining that I shouldn't need a new licence as my bike already has a bike harnesses fitted and that they had confirmed to me previously that all i needed to do was update to the latest version.
They replied saying that they had reset my licence, so I tried flashing the bike and now everything is work again.
I got my O2 sensor all calibrated and and tested out what the data logger was reading and it is right on the money now. So now all I have to do is put everything back together, and start riding....:jump....
Yep it's the original one. I was about to make a sweet map with autotune I just got. But nope, damn thieves took bike. I've never had a bike stolen so not sure how it works here...do they just go by KBB value? People here ask for crazy prices for their ratty bikes. Mine was awesome and had a lot of good mods. So that would be a downgrade, and I don't like downgrades. So I think at this point I will either wait for the 2015's or maybe see what I can do about getting a KTM Superduke.
HI Tad
I'm a massive fan of your work and absolutely love your 5.3.15 map and also appreciant all the time and effort you put into this forum.
Now that you have installed your data logger and O2 sensor will you be gathering data and making any changes to this map?
I have had this map install on my 2012 limited edition R1 since you issued on the forum and I have tried other maps but nothing compares so even if no changes are made I will continue to use this map.
Once again Thanks for all you have done.
Many Thanks
Peter UK
Would it be possible to make a section just for uploading the .ftm files so we don't have to Google and scrub a long slew of posts to find individual items or is that already done and I am ignorant to how to find them easier?
Tad I got the new interface today, are the new tunes going to need a wideband 02 sensor installed to work properly or is that just going to let you tune it even better?
IDK if this is the right place, but I'll ask anyway. I had $100 and I was going to buy the new interface, since I don't have to now, I was thinking about getting the QS. What do I need? I know I need this https://ftecu.com/shop/ecu-based-quickshifter-harnesses/ but what else?
