FlashTune ECU Flashing Interface - Page 238 - Yamaha R1 Forum: YZF-R1 Forums
 55Likes
post #4741 of 12631 (permalink) Old 11-30-2012, 04:02 PM
R1 it's Legendary...like MOTO
AHB537's Avatar
I just got the Flash Tune interface. Haven't had a chance to get the software yet. Gonna need help soon. You guys ROCK!!!
BaLLiSTiX go get'um
AHB537 is offline
post #4742 of 12631 (permalink) Old 11-30-2012, 05:34 PM Thread Starter
Originally Posted by chatham View Post
ok...
why so many !!!
are you trying to yell your knowledge at me?
mate, I only asked if your bike was a 2012?
and if so PM me and id send you a map...
as far as part numbers are concerned the 09 and 11 have different cams.. so there is for sure some subtle differences between my 12 and your 09.
FYI,
This Yamaha 14B-12170-01-00 CAMSHAFT ASSY 1 is also used on these models and components:
2011 YZF-R1 - YZFR1AB CAMSHAFT CHAIN
This Yamaha 14B-12170-00-00 CAMSHAFT ASSY 1 is also used on these models and components:
2009 YZFR1 - YZFR1YB CAMSHAFT & CHAIN
2009 YZFR1 - YZFR1YY CAMSHAFT & CHAIN
2010 YZFR1 YZFR1ZCB_W_L YZFR1 (CA) - YZFR1ZB CAMSHAFT & CHAIN
I do, and have, shared my knowledge openly.
BUT.. I do it through PM's...my choice that's all.
my maps have been created on a flashed EU ecu then auto-tuned trims accepted, added on top of the image and re run.
I then add fuel in key areas to smooth the on off throttle at 0% and 2%
as the auto-tune is not capable of tuning that area correctly.
I tune the whole map and only use TPSvsRPM
on my bike with mixed riding fuel use is avg 7ltrs per 100ks
freeway consumption avg 5lts per 100ks
no need for the 02 as far as i'm concerned.
PM me your email and you can look at the numbers of a nice generic map for most 12 owners.. tuned to 12.9 AFR..
Why do you think the auto-tune won't tune the 0-2% TPS range "correctly"?
Good job clarifying that your map, although it may work great for you is still a "generic" map for anyone else using it with their bike.
SySt is offline
post #4743 of 12631 (permalink) Old 11-30-2012, 05:42 PM
R1
because after prolonged use the auto tune at low percent(2%) input suffers from the exhaust pulses of the engine creating reversion hence putting -30 and +50 numbers in your tune...
you don't notice it at first because you set to max tune of +/-20 difference... you accept trims ride all is good....you accept trims again....all is good you ride and now you have some way out of tune numbers..
First hand EXP... that is why.
the Auto tune works great.. just suffers from the pulses of our engines.
I hope I have explained myself clear... if you like i can show you a corrupted map where i had to fix some of the inputs...
chatham is offline
post #4744 of 12631 (permalink) Old 11-30-2012, 06:15 PM Thread Starter
No need to prove it to me, I believe you. I was actually more of fishing to make sure you weren't thinking that because (due to Dynojet's install instructions) most people set their 0% PCV TPS value to correspond to warm idle speed rather than actual 0% TPS. Of course, when the PCV is set that way, you cannot tune the TPS ranger under ~2% (idle TPS).
SySt is offline
post #4745 of 12631 (permalink) Old 11-30-2012, 07:30 PM
R1
all good man,
happy for my info to be double checked..I do the same, just to make sure I'm talking to someone who knows how to use this equipment, it just makes life and communication much easier.
chatham is offline
post #4746 of 12631 (permalink) Old 11-30-2012, 11:13 PM
Trackday junkie!
Powerflux's Avatar
ok...
why so many !!!
Definately not my intention to yell
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #4747 of 12631 (permalink) Old 12-01-2012, 01:13 AM
me r1 to eats P***y
vcyclenut's Avatar
anyone had trouble with a high idle like 3000 rpms on 07-08.
ive flashed two in the last two weeks that have had this issue, i never mess with the force idle.
hoping yesterdays update fixed it even though it was not mentioned in it
vcyclenut is offline
post #4748 of 12631 (permalink) Old 12-01-2012, 01:15 AM
Feel the speed attack!
marider's Avatar
Send a message via Skype™ to marider
I agree with that, my numbers 0-2% seem fine but at 5% throttle they fluctuate from 4 to -33 in 2000-6000 rpm area. Generally my AT trims subtract fuel than add .
BTW 5-7 l/100km fuel consumption is a very good result, I'd like that one too Oh, I forgot I still have the "old" Lax map in my ECU with bias set at 75% and ETV+FI=0%.
marider
Longest distance between two curves... straight line
EU 09 R1:
full Akrapovic Evo2,F-T'd ECU,Bazzaz ZFi-TC+Z-AFM,Marchesinis,Ohlins damper+FPK108+.95 springs,q'Ohlins r.shock,
Brembo RCS/w Hel&Braking SK rotors,Graves block offs,Clutch Kit,Fabbri screen,GYTR:sliders,clutch sliders,gel seat+cowl,Gilles VCR+Variobar,Gregg's Flushmount,-1/+1 sprockets,CustomLED mod. 3/4Dyno:170.1 RWHP,77 Tq.
marider is offline
post #4749 of 12631 (permalink) Old 12-01-2012, 02:52 AM
R1
cool, no worries thank you for clearing that up.
chatham is offline
post #4750 of 12631 (permalink) Old 12-01-2012, 09:47 AM
cheong1106's Avatar
Chatham
How in the world you get that fuel consumption!? Haahah im getting only 13 km/L street. At the track About 8 km/L
Hit 260 kph on front straight without speedo correction. 256 on back straight.
2:31 lap time (with traffic unfortunately & I dont overtake aggressively)
Will try to load videos.
I had the red engine light come on twice. Just came on then off. During hard braking and downshifting. Any idea?
Sent from my GT-N7105 using Motorcycle.com Free App
cheong1106 is offline
post #4751 of 12631 (permalink) Old 12-01-2012, 12:20 PM
Vcyclenut, have you tried my custom map for 07 08? The idle is around 1600tr/min
JAGI is offline
post #4752 of 12631 (permalink) Old 12-01-2012, 12:42 PM
graphitegripper's Avatar
Can you share this map on my thread for the users on the 07-08 FlashTune ecu tuning thread please? Or on here and ill copy and paste the link?
Thanks
graphitegripper is offline
post #4753 of 12631 (permalink) Old 12-01-2012, 12:43 PM
Astronomer not Astrologer
Tad158's Avatar
I can link to it in the FAQ as well.
#158
2009 Raven R1
Tad158 is offline
post #4754 of 12631 (permalink) Old 12-01-2012, 12:49 PM
R1
Originally Posted by cheong1106 View Post
Chatham
Hey 13km/l is like 7.6 ltrs per 100 ks.. that's close to mine, of course if i give it more than just mixed riding my average goes up to 7.6-7.8 but still in the 7's with mixd....hard riding, different story it uses in the 8's .
the red engine oil lite is a level sensor not a pressure sensor, even it the owners manual it states under hard riding you may see it come on.
check your oil level and see if you can top it up just a small ammount.
chatham is offline
post #4755 of 12631 (permalink) Old 12-01-2012, 08:53 PM
me r1 to eats P***y
vcyclenut's Avatar
no i have not, it seems the last update fixed the idle problem
post #4756 of 12631 (permalink) Old 12-02-2012, 02:54 AM
cheong1106's Avatar
Tks. I suspected as well. Will cx that. Tks. Will send you the info over next 2 days. Bike is being towed back from Sepang
post #4757 of 12631 (permalink) Old 12-02-2012, 06:21 AM
cheong1106's Avatar
Alright. My 2 laps of 2:31s at Sepang.
Http://youtu.be/gQoQCFaFtP0
post #4758 of 12631 (permalink) Old 12-02-2012, 06:29 AM
Nice man. What kind of tires were you using? How much does a trackday there run?
AKDMA is offline
post #4759 of 12631 (permalink) Old 12-02-2012, 06:43 AM
cheong1106's Avatar
Was running Metzeler K3s. SBR Trackdays organises such events (almost monthly) and it runs about 235 SGD for 2 half day sessions. You get 80 minutes of ride time per session. 3 groups, 20 mins each session rotated across the groups. 4 hrs (half day) total.
I crashed on 2nd turn of 1st day. Will be posting that up. Still no idea how it happened. The GYTR No-cut sliders worked great. not even a scuff on my signal lights / clutch lever hahahaha. And the rear GB racing swingarm spool also did its job.
Will be dloading my data and working with Chatham on the maps.
post #4760 of 12631 (permalink) Old 12-02-2012, 08:53 AM
close2reality's Avatar
I have a FT '12 map from back in september, i forget but i think it was peens map. havn't been on the boards as much. is there a pretty well refined '12 map out there at this point?
close2reality is offline
