FlashTune ECU Flashing Interface - Page 239 - Yamaha R1 Forum: YZF-R1 Forums
 40Likes
post #4761 of 12550 (permalink) Old 12-02-2012, 11:04 AM Thread Starter
I've got two things to bring up:
First is that I think some sort of two-step rev limiter would be an awesome next feature. It could be controlled by the clutch switch (not sure if that signal goes to the ECU) or perhaps the limiter would simply be active while the bike is not "in gear". "In gear" being defined as engaged in a gear with no/minimal clutch slip. I guess I'd like to see what Flashtune could come up with, but I would be against any sort of button or switch that would require additional use of the hands.
Secondly, I think we really need to agree on a terminology regarding maps. Because currently, and as Flashtune defines it, a "map" contains "maps" and that is somewhat confusing. There is a YCCT map, idle map, fuel maps, quickshifter maps and ignition maps all within what Flashtune calls a map. I think we need to refer to the "Flashtune map" as an ECU image or something like that. All other maps must be referred to as their type, for example "ignition map" or "TPS vs RPM (Alpha-N) fuel map". Perhaps we should try to get Flashtune to change the terminology in their software.
Tad, you seem to be in contact with the Flashtune guys pretty frequently. Perhaps you can be an "ambassador" for us.
SySt is offline
post #4762 of 12550 (permalink) Old 12-02-2012, 01:17 PM
me r1 to eats P***y
vcyclenut's Avatar
does anyone know how we disable the o2 sensor now that the crossover point is not adjustable on the newer updates
and is there anyway to disable the velocity stacks if you put fixed stacks on??
<a href=http://i64.photobucket.com/albums/h179/vcyclenut/sigpic7024_1.gif target=_blank>http://i64.photobucket.com/albums/h1...gpic7024_1.gif</a>
vcyclenut is offline
post #4763 of 12550 (permalink) Old 12-02-2012, 02:02 PM
This POS won't flash my ECU anymore. I updated to the newest version and it will get to 100% of the ETV flash but fails to connect when it attempts to write the FI side. Anyone else experience this?
Update: I tried flashing it with their new "flash etv only" "flash fi only" and it worked. Go figure.
2008 "Raven" - Mostly stock: -1, gutted cat, SS brake lines, flash tuned, and fast as hell
Raven1Actual is offline
post #4764 of 12550 (permalink) Old 12-02-2012, 09:25 PM
Astronomer not Astrologer
Tad158's Avatar
Sorry guys I have been on travel this week, so I have been a little slower to respond.
First point, send them an email, I think this thread has fallen off their radar for some reason. I will also request the feature. We can take the squeaky wheel approach. At some level the same goes for the second. I will add that terminaology to the FAQ (give me a few days as I am still pretty busy at work and home this week and next), and I support this convention, though you know what they say about old habits.
To be honest, I just send F-T emails, and they respond to them. Some times it takes a few days, but they usually get answered.
What do you mean you can not change the load bias setting? ...You do know that they changed it from a slider to a drop down box just above the speed adjustment?
One way to do it is to simply change it to an RPM that is above the rev limter, aka an RPM that the engine will never get to?
Does this help you VC?
Venom Squadron Shirts
#158
2009 Raven R1
Mods: Custom Fender Eliminator, Custom Rear Res. Bracket, Custom Clutch Sliders, Spiegler Rennsport SS F/R Brake Lines, Driven Clip-ons, Spider Peak Grips, Zero Gravity Light Smoke Double Bubble Windscreen, M4 Y-Pipe, Vance&Hines CS One cans, Shogun No-Cut Sliders, F-T custom image with Bazzaz QS sensor, Galespeed VRC MC, Ferodo ST HH Front Pads, RaceDAC Data Logger, RaceTech Springs, F1Composites track bodywork.
Build Thread
Flash-Tune FAQ Thread
Tad158 is offline
post #4765 of 12550 (permalink) Old 12-02-2012, 09:54 PM
me r1 to eats P***y
vcyclenut's Avatar
What do you mean you can not change the load bias setting? ...You do know that they changed it from a slider to a drop down box just above the speed adjustment? wow i didnt realize this
One way to do it is to simply change it to an RPM that is above the rev limter, aka an RPM that the engine will never get to?yea that was my plan,
Does this help you VC?yep thanks very much
post #4766 of 12550 (permalink) Old 12-02-2012, 10:13 PM
Does anyone know what the stock velocity stack switching point RPM for the crossplane is? I remember Jett and Garage Endeavors claimed they "optimized" this with the OEM stacks. I wonder if they used 10,500.
AKDMA is offline
post #4767 of 12550 (permalink) Old 12-03-2012, 05:32 AM
indianfighter's Avatar
Yes starting a new thread for map development would be a good idea. I have reached page 181 of thsi thread so far and all I have is peen's v2 and n4speed's map from old. I don't know if there have been any new maps since then. I don't know when I will be able to finish reading the entire thread.
IndianFighter
2011 white R1
indianfighter is offline
post #4768 of 12550 (permalink) Old 12-04-2012, 12:22 AM
Originally Posted by JAGI View Post
You will boooom your engine. I will open the Peen map and will edit the ignition map for you. Waiting 1-2days.
You can flash this map, it have the stock ignition values on the high revs and up 50% throttle.
Also, it have a lower engine braking at high revs.
Thanks Jagi, dunno how I missed this earlier
Stock ignition settings above 50% throttle and higher revs? I don't need stock ignition timing on lower revs?
Is engine braking linked with ignition timing, is that why you have edited that too?
IndianFighter
2011 white R1
post #4769 of 12550 (permalink) Old 12-04-2012, 12:39 AM
Originally Posted by R1evolution View Post
ok run the new map i updated. he has it in his signature or send me a pm with your mail addy and ill send it to you.
Originally Posted by AKDMA View Post
The old one or today's?
Sent from my SCH-R530U using Motorcycle.com Free App
Ummm, where is n4speed's modified map?
Guys, we need to have some proper organisation for finding all these development maps. Sifting through 250+ pages to find a map needs balls of steel.
IndianFighter
2011 white R1
post #4770 of 12550 (permalink) Old 12-04-2012, 09:02 AM
the map that N4speed and i worked on isnt published.
R1evolution is offline
post #4771 of 12550 (permalink) Old 12-04-2012, 12:32 PM
Lucky 13 X/O
marshdrummer's Avatar
Question (because I can't find the definitive answer). If I get the interface, can flash a 2011 AND a 2012 with the interface and software? thanks in advance!
Lucky 13th Squadron C/O
#69
LRRS AM
RSP Racing #920
Sponsors: Pirelli, Tony's trackdays, Motorcycle Tires and Gear, Dyno Solutions, Sportbike Track Gear, Knox, Woodcraft, 434racer.com
marshdrummer is offline
post #4772 of 12550 (permalink) Old 12-04-2012, 01:07 PM
get the 12 version and you can flash the 9-11 also
post #4773 of 12550 (permalink) Old 12-04-2012, 01:31 PM
Lucky 13 X/O
Thank you sir....
#69
LRRS AM
RSP Racing #920
post #4774 of 12550 (permalink) Old 12-04-2012, 01:32 PM
The 09-11 (2.2) version also works on 12. I've used mine on a friend's 2012. BTW, I think I'm going to switch permanently to the 100/20 engine braking setting, it's very consistent and still a hefty reduction over stock.
AKDMA is offline
post #4775 of 12550 (permalink) Old 12-04-2012, 07:30 PM
Tad158's Avatar
The 2.2 version is the 09+ version. The original 09-11 version (the one that I have) is the 2.1 version of the interface. I still believe that this version cannot flash 12+...., I have not tired. I will ask F-T.
#158
2009 Raven R1
Build Thread
Tad158 is offline
post #4776 of 12550 (permalink) Old 12-04-2012, 07:33 PM
Thanks for the clarification. So they have three crossplane interfaces? 2.1, 2.2 and 2.2.x?
AKDMA is offline
post #4777 of 12550 (permalink) Old 12-04-2012, 07:34 PM
Tad158's Avatar
...I have the 2.1.....it was the one they made before they came up with the one that would also the the 12+...the 1.x does the 07-08.
#158
2009 Raven R1
Build Thread
Tad158 is offline
post #4778 of 12550 (permalink) Old 12-04-2012, 08:05 PM
My R1 Makes me Horny!
Storm Trooper's Avatar
Can someone tell me why my FT may not be working? I was at the track on Friday and tryed more than several times to flash the ECU with no success. It kept giving me a connecting error and I did have the computer (charging) plugged in.
Also is there any new Latest/ Greatest map for a 2010 +/- with a full Akra, filter and Bazzaz that anyone has posted?
STORM
UNBELIVABLE SIG WORK COURTESY OF PETROL_SPICE!
"People will ALWAYS be MORE impressed with the Power of our Example,
then the Example of our Power!
- Bill Clinton 08/27/08
Kickin Track Videos:
PBIR: http://www.youtube.com/watch?feature...&v=gWBFjaXx4Pc
Homestead 1 http://www.youtube.com/watch?v=WfRS8EErMlU
2 http://www.youtube.com/watch?v=e6S0Q3-rP5g
Storm Trooper is offline
post #4779 of 12550 (permalink) Old 12-04-2012, 08:10 PM
Tad158's Avatar
Were you sure that you had a good 12V supply hooked up? That is the only time i get flashing errors...ie I forget to plug in the 12 power brick....
Also, does it work at home. If you were powering it off a generator, it could not be supplying it with a clean enough AC signal to generate the 12V DC (if you were using a wall mount power supply)...
#158
2009 Raven R1
Build Thread
Tad158 is offline
post #4780 of 12550 (permalink) Old 12-04-2012, 08:28 PM
Yup, I checked it several times. I haven't tryed it from home since nor in quite a while but I will this week.
STORM
ecuunleashed 0r flashtune vtwin Appearance & Mods 61 11-16-2014 07:37 PM
Flashtune ECU Dyno Results sirjag Appearance & Mods 183 03-30-2014 05:08 PM
Flashtune reflash 07-08 R1 bwash85 Appearance & Mods 171 06-22-2012 07:48 AM
flashtune VS ecuunleashed vtwin Mechanical / Help 3 03-17-2012 12:50 AM
Yec Cable Interface BERNY Bikes/Parts Wanted 0 03-19-2010 12:58 PM
