FlashTune ECU Flashing Interface - Page 244 - Yamaha R1 Forum: YZF-R1 Forums
 42Likes
post #4861 of 12562 (permalink) Old 12-15-2012, 12:41 PM
Originally Posted by Matador1340 View Post
Anyone experienced a bricked ecu situation?
I flashed my 08 R1 and from that time and after stoped responding I can now only flash the etv cpu. When I am trying to flash fi CPU stops and gives me error
I have this problem. The work around for me is flashing ETV and FI seperately.
2008 "Raven" - Mostly stock: -1, gutted cat, SS brake lines, flash tuned, and fast as hell
Raven1Actual is offline
post #4862 of 12562 (permalink) Old 12-16-2012, 03:03 PM
J58
Mach.81's Avatar
Any thoughts...opinions on the newer FT version. (ignition maps for the 09-11 R1) Good/bad/needs adjusting in some areas????
They look awful like the ignition maps Elwin made for his bike.
Mach.81 is offline
post #4863 of 12562 (permalink) Old 12-16-2012, 03:03 PM
Have the maps changed, ignition wise since the first release?
Sent from my SGS3
AKDMA is offline
post #4864 of 12562 (permalink) Old 12-16-2012, 03:19 PM
J58
Mach.81's Avatar
Been out for awhile now....month or so. (91pumpgas maps) Just wondering how the testing is coming along? Anybody run these newer ignition maps?
The older maps were ....stock/pump gas/ 91
Now....stock/91pumpgas
Mach.81 is offline
post #4865 of 12562 (permalink) Old 12-16-2012, 11:54 PM
indianfighter's Avatar
Originally Posted by Powerflux View Post
-Offline license checking bug fixed allows for faster loading
- Linkmaps disallowed with YCCT mapping
- Flash routine updated to support bluetooth interfaces
- PC value grid auto clears when applying to "current image"
1: hardly mattered?
2: What the hell is this?
3: And this? Can we flash wireless with bluetooth?
4: And this?
IndianFighter
2011 white R1
indianfighter is offline
post #4866 of 12562 (permalink) Old 12-17-2012, 10:11 AM
Those ign maps are decent. If you are running 91 or above pump gas you can advance the timing at 80-100% throttle from 6k to redline by 2 degrees and still be safe. Those stock ign maps are pretty conservative.
Sent from my DROIDX using Motorcycle.com Free App
R1-015 "Ghostrider" Squadron #145
Oilfieldtrash21 is offline
post #4867 of 12562 (permalink) Old 12-17-2012, 02:40 PM
motorhead
JollyRoger's Avatar
Originally Posted by r1Jersey View Post
#3 I met with Flash-Tune in LA on Saturday and can confirm that there is a new bluetooth harness/interface coming very soon which will allow flash-tuning without removing the ECU from the bike, plus data logging to internal memory on the harness and in the future bluetooth devices such as Android & maybe iPhone which can be applied via flash-tune (and much much more.)
That sounds awesome! Do you know if that will apply to the 07-08, or just the 09+
JollyRoger is offline
post #4868 of 12562 (permalink) Old 12-17-2012, 10:30 PM
For someone who just spent 500 dollars on buying the interface .......
IndianFighter
2011 white R1
post #4869 of 12562 (permalink) Old 12-17-2012, 10:58 PM
RAVJEET's Avatar
R1 2008 (CE) maps
can any one share tried and tested maps for 2008 R1 (CE) .
to improve overall performance of the bike .
thanks in advance
RAVJEET is offline
post #4870 of 12562 (permalink) Old 12-18-2012, 01:40 AM
Trackday junkie!
Powerflux's Avatar
That looks like radical new stuff ...wich means more money to shell out
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #4871 of 12562 (permalink) Old 12-18-2012, 05:40 AM
Trackday junkie!
Powerflux's Avatar
Cool, I`ll check it out
M4 Y-pipe
K&N filter
ProGrip 714 grips
SpeedoDrD
Black Shorty Levers
Graves clutch kit
post #4872 of 12562 (permalink) Old 12-18-2012, 05:45 AM
how much is it, more or less?
laxwendrof is offline
post #4873 of 12562 (permalink) Old 12-18-2012, 12:18 PM
Trackday junkie!
Powerflux's Avatar
***you must be a vendor or advertiser to sell on the forum!***
Haha, my response looks pretty lame after Kmac edited your post
M4 Y-pipe
K&N filter
ProGrip 714 grips
SpeedoDrD
Black Shorty Levers
Graves clutch kit
post #4874 of 12562 (permalink) Old 12-18-2012, 12:32 PM
Trackday junkie!
Powerflux's Avatar
250$ in the US/490$ in UK!
Being outside EU to boot, I`ll continue to import my gadgets from the US, sorry!
M4 Y-pipe
K&N filter
ProGrip 714 grips
SpeedoDrD
Black Shorty Levers
Graves clutch kit
post #4875 of 12562 (permalink) Old 12-19-2012, 03:10 PM
J58
Mach.81's Avatar
Awesome news. So a EU base map will be available soon. Great news.
Mach.81 is offline
post #4876 of 12562 (permalink) Old 12-19-2012, 07:53 PM
mnd
When in doubt....throttle out
Please Help!
Got my Flash tune today and it keeps failing.
Gets all the way through the first part of flashing to 100% and then moves to FI. At this point, it fails, exits and gives code 031.
Not sure what else to try? Tried reboots, new flashtune software etc. Strange that it gets that far and then fails. Any suggestions?
mnd is offline
post #4877 of 12562 (permalink) Old 12-19-2012, 07:55 PM
Astronomer not Astrologer
Tad158's Avatar
Try doing a FI only flash? Then call F-T in the AM and ask why....or in your case PM your time AM their time. The open at like 9 AM PST.
#158
2009 Raven R1
Mods: Custom Fender Eliminator, Custom Rear Res. Bracket, Custom Clutch Sliders, Spiegler Rennsport SS F/R Brake Lines, Driven Clip-ons, Spider Peak Grips, Zero Gravity Light Smoke Double Bubble Windscreen, M4 Y-Pipe, Vance&Hines CS One cans, Shogun No-Cut Sliders, F-T custom image with Bazzaz QS sensor, Galespeed VRC MC, Ferodo ST HH Front Pads, RaceDAC Data Logger, RaceTech Springs, F1Composites track bodywork.
Tad158 is offline
post #4878 of 12562 (permalink) Old 12-19-2012, 08:03 PM
Mine does that. I have to flash individually.
post #4879 of 12562 (permalink) Old 12-19-2012, 08:07 PM
Tad158's Avatar
I don't know why some people are having that issue, because my old interface works fine with the newest version of the software with no issues. I did a flash last Sunday.
#158
2009 Raven R1
Tad158 is offline
post #4880 of 12562 (permalink) Old 12-19-2012, 08:43 PM
mnd
Doing it separately finally worked. Still needed 3 or 4 attempts on the FI before it would stop failing.
mnd is offline
ecuunleashed 0r flashtune vtwin Appearance & Mods 61 11-16-2014 07:37 PM
Flashtune ECU Dyno Results sirjag Appearance & Mods 183 03-30-2014 05:08 PM
Flashtune reflash 07-08 R1 bwash85 Appearance & Mods 171 06-22-2012 07:48 AM
flashtune VS ecuunleashed vtwin Mechanical / Help 3 03-17-2012 12:50 AM
Yec Cable Interface BERNY Bikes/Parts Wanted 0 03-19-2010 12:58 PM
