FlashTune ECU Flashing Interface - Page 245 - Yamaha R1 Forum: YZF-R1 Forums
 43Likes
post #4881 of 12564 (permalink) Old 12-19-2012, 07:47 PM
Astronomer not Astrologer
Tad158's Avatar
That is odd. You should call F-T and report the issue. Maybe they can fix it in software.
#158
2009 Raven R1
Tad158 is offline
post #4882 of 12564 (permalink) Old 12-20-2012, 04:23 AM
The way you described is the way I've always done it. I plug the interface in before launching the software, then connect everything to ecu when it specifies. Never has failed.
Sent from my SGS3
AKDMA is offline
post #4883 of 12564 (permalink) Old 12-20-2012, 04:26 AM
cheong1106's Avatar
Sent from my SGS3
Yup. Same here.
Sent from my GT-N7105 using Motorcycle.com Free App
cheong1106 is offline
post #4884 of 12564 (permalink) Old 12-20-2012, 04:30 AM
mnd
When in doubt....throttle out
Sent from my SGS3
I tried every way known to mankind
In the end, no 1 method consistently worked. The FI flash ended up working when I kept the ecu plugged in.
Anyway, got there in the end but just a bit annoying. Will raise it with FT
mnd is offline
post #4885 of 12564 (permalink) Old 12-20-2012, 05:39 AM
I also have the 2.2 interface, might be a difference between us. Sorry for your troubles! I hope it gets worked out, but at least you got the flash completed.
AKDMA is offline
post #4886 of 12564 (permalink) Old 12-21-2012, 04:02 AM
mnd
Quick question.
If I'm only changing speedo settings and start in A mode, do I need to flash the FI as well ?
Thanks
mnd is offline
post #4887 of 12564 (permalink) Old 12-21-2012, 04:33 AM
J58
Mach.81's Avatar
Originally Posted by mnd View Post
Quick question.
Thanks
Ask theses questions.
What image is on my ECU now?
What image will I end up with after the flash?
What image has been proven to produce more power and torque.
A speedo healer is a cheap aftermarket add on available anywhere.
Mach.81 is offline
post #4888 of 12564 (permalink) Old 12-21-2012, 04:45 AM
mnd
Sorry, I don't think you understood the question. I already have a flashtune and have loaded maps etc.
I've put on a 16t front sprocket and so wanted to re flash with new settings. Oly I rather avoid flashing the FI again becoz it takes 5 attempts each time. See above. Was just wondering if the speedo settings and mode a settings change when you flash the FI or the ETV (or both)
mnd is offline
post #4889 of 12564 (permalink) Old 12-21-2012, 04:50 AM
J58
Mach.81's Avatar
Yah... my bad.
I didn't read your earlier posts.
You already flashed your ecu.
Mach.81 is offline
post #4890 of 12564 (permalink) Old 12-21-2012, 04:53 AM
mnd
Yah... my bad.
No stress....didn't explain myself. Trying to avoid doing the FI flash again.
mnd is offline
post #4891 of 12564 (permalink) Old 12-21-2012, 04:59 AM
J58
Mach.81's Avatar
My personal experience with this hardwear is a clean power sorce and updated windows software seems to help quite a bit in the flashing process.
Cheers
Happy holidays
Mach.81 is offline
post #4892 of 12564 (permalink) Old 12-21-2012, 03:19 PM
tajdk's Avatar
Send a message via Skype™ to tajdk
Had another dynorun this week, and is quite happy.
End results was 168 hp at the rearwheel, and a good liniar powercurve.
Need to scan the sheets from the dyno, but in the meantime is there a little video i took at one of the runs.
tajdk is offline
post #4893 of 12564 (permalink) Old 12-21-2012, 03:22 PM
The flames were a nice touch! Sounded good as well.
AKDMA is offline
post #4894 of 12564 (permalink) Old 12-21-2012, 04:54 PM
mnd
Sensational !! Love the flames
mnd is offline
post #4895 of 12564 (permalink) Old 12-21-2012, 06:08 PM
cheong1106's Avatar
Was he trying to get the fkames as far out ad possible or what?! Hahaha nice
post #4896 of 12564 (permalink) Old 12-23-2012, 04:30 PM
Feel the speed attack!
marider's Avatar
Send a message via Skype™ to marider
What's the purpose for blipping the throttle when the bike is in "clutch-in mode" on a dyno?
marider
Longest distance between two curves... straight line
EU 09 R1:
full Akrapovic Evo2,F-T'd ECU,Bazzaz ZFi-TC+Z-AFM,Marchesinis,Ohlins damper+FPK108+.95 springs,q'Ohlins r.shock,
Brembo RCS/w Hel&Braking SK rotors,Graves block offs,Clutch Kit,Fabbri screen,GYTR:sliders,clutch sliders,gel seat+cowl,Gilles VCR+Variobar,Gregg's Flushmount,-1/+1 sprockets,CustomLED mod. 3/4Dyno:170.1 RWHP,77 Tq.
marider is offline
post #4897 of 12564 (permalink) Old 12-23-2012, 04:49 PM
To clear out the cyl after the pull. I have been told that it also helps "cool" the cyl with the addition of fuel from blipping after a hard pull.
R1-015 "Ghostrider" Squadron #145
Oilfieldtrash21 is offline
post #4898 of 12564 (permalink) Old 12-23-2012, 05:44 PM
Tad158's Avatar
Makes sense, you usually don't run down the straight real hard then pull in the clutch and coast for a few miles...at least in a real world/track type of situation...
#158
2009 Raven R1
Tad158 is offline
post #4899 of 12564 (permalink) Old 12-24-2012, 11:48 AM
I RACE U LOSE
quick kurt's Avatar
What would be a good # or #'s to put in the dropdown box when forcing idle to 1200 rpm, growing tired of the 1300-1500 rpm idle (depending on eng temp) Thanks guys.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi
'12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi
Lucky 13th R1-013Squadron Member
quick kurt is offline
post #4900 of 12564 (permalink) Old 12-24-2012, 02:29 PM
Tad158's Avatar
, I am still using the stock idle setting, and is simply due to preference.
#158
2009 Raven R1
Tad158 is offline
