FlashTune ECU Flashing Interface - Page 253 - Yamaha R1 Forum: YZF-R1 Forums
 40Likes
post #5041 of 12553 (permalink) Old 01-17-2013, 06:24 AM
I'm hoping to get it out today it has been nothing but rain rain rain. Today is the first day without rain but the high is only 45.
Sent from my DROID RAZR HD using Motorcycle.com Free App
yman294 is offline
post #5042 of 12553 (permalink) Old 01-17-2013, 07:18 PM
danamite's Avatar
Originally Posted by yman294 View Post
How is yours running with the 3/4 map in it they installed ? Its a 2012 right? It it smooth? Strong? Flat spots? Describe power delivery..A-mode and standard... thanks
Yes 2012. Runs great! Smoothed out the power all the way through. Actually corrected a flat spot at 5200-5500 rpm. A-mode feels stronger...standard feels the same...slightly smoother.
Only thing...I now have flames that shoot out my exhaust after high revs - 10k plus rpm.
danamite is offline
post #5043 of 12553 (permalink) Old 01-17-2013, 08:18 PM
mnd
When in doubt....throttle out
Where's the problem !
mnd is offline
post #5044 of 12553 (permalink) Old 01-17-2013, 08:38 PM
danamite's Avatar
I am under the impression that even though its cool looking...it's a sign that your bike is not running efficiently. Yes? No?
danamite is offline
post #5045 of 12553 (permalink) Old 01-17-2013, 08:40 PM
Popping on decel could mean a lean condition, but the ais system causes that too if it hasn't been bypassed.
Sent from my SGS3
AKDMA is offline
post #5046 of 12553 (permalink) Old 01-17-2013, 08:54 PM
danamite's Avatar
I don't have too much pop on decel...what is ais?
danamite is offline
post #5047 of 12553 (permalink) Old 01-17-2013, 08:57 PM
Air induction system, smog unit.
Sent from my SGS3
AKDMA is offline
post #5048 of 12553 (permalink) Old 01-17-2013, 11:32 PM
Need $ for bike parts
BlackShadow's Avatar
Sent from my SGS3
Or paper weight
Sig by Uncle P
I wish my Dad was alive to see some of the crazy shit I do. RIP Pops
BlackShadow is offline
post #5049 of 12553 (permalink) Old 01-18-2013, 01:58 PM
Trackday junkie!
Powerflux's Avatar
The AIS system is pure BS! Dumping fresh air into the exhaust to make the emission numbers look better is just that, BS
I`m in the middle of removing the airbox and change the plugs and the AIS is def getting chucked out
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #5050 of 12553 (permalink) Old 01-18-2013, 02:00 PM
Nice. Next time I change my plugs I'm going to do mine as well, I'm not sure FT disabling it works as well. I still get popping on decel, just not as much.
AKDMA is offline
post #5051 of 12553 (permalink) Old 01-18-2013, 02:02 PM
I blocked mine off before the flash...
yman294 is offline
post #5052 of 12553 (permalink) Old 01-22-2013, 07:48 PM
Timekeeper
NoPro's Avatar
I'm looking to buy the interface in the next couple days. Anyone gracious enough to share a coupon code? EFJ124680 and topsecret are no longer valid.
NoPro is offline
post #5053 of 12553 (permalink) Old 01-22-2013, 08:02 PM
Astronomer not Astrologer
Tad158's Avatar
I would say give F-T a call and see if they will give you a discount over the phone. Try and tell them that you heard good things about it here, and maybe that will work?
#158
2009 Raven R1
Mods: Custom Fender Eliminator, Custom Rear Res. Bracket, Custom Clutch Sliders, Spiegler Rennsport SS F/R Brake Lines, Driven Clip-ons, Spider Peak Grips, Zero Gravity Light Smoke Double Bubble Windscreen, M4 Y-Pipe, Vance&Hines CS One cans, Shogun No-Cut Sliders, F-T custom image with Bazzaz QS sensor, Galespeed VRC MC, Ferodo ST HH Front Pads, RaceDAC Data Logger, RaceTech Springs, F1Composites track bodywork.
Tad158 is offline
post #5054 of 12553 (permalink) Old 01-23-2013, 12:14 AM
unleash the beast
LATIN's Avatar
just them know your from the R1-forum.com
created by Petrol_Spice
RIP Dad
te amo papi, dad i love u and i miss u..
11/25/30 - 01/19/09
RIP Pierre (DieYoung69) You will be missed brother!!! * It's sammich & beer time
RIP Andre (TWISTGRIP) Ride hard in heaven my brother your one best of the best..
LATIN is offline
post #5055 of 12553 (permalink) Old 01-25-2013, 01:00 PM
My R1 Makes me Horny!
Storm Trooper's Avatar
Quick question: How do you read the Engine Breaking adjustment on the software? Does the % Seen mean the % being reduced or the % of OEM Engine Breaking remaining?
STORM
UNBELIVABLE SIG WORK COURTESY OF PETROL_SPICE!
"People will ALWAYS be MORE impressed with the Power of our Example,
then the Example of our Power!
- Bill Clinton 08/27/08
Kickin Track Videos:
PBIR:
Homestead 1
2
Storm Trooper is offline
post #5056 of 12553 (permalink) Old 01-25-2013, 01:20 PM
Tad158's Avatar
The % number means howm much it is adjusted with in the range of adjustment. 0% means OEM settings, and 100% the most amount of reduction that the setting can remove.
That being said, if you look back a few pots, it has been documented that in the current release of the software the ETV engine breaking reduction has a small bug and may not lead to changes that are as good as in previous versions. This bug has been reported, and acknowledged by F-T and they are working on a fix.
#158
2009 Raven R1
Tad158 is offline
post #5057 of 12553 (permalink) Old 01-25-2013, 01:23 PM
...Ready
ZR1.'s Avatar
Fellas, I recently got my ECU flashed and I have some questions.... I don't have time to read through 256 pages!
So I noticed some great gains in the mid range dept and while that is great and all it needs some tuning. Once I release brake pressure and get back in the throttle, it is very abrupt and jerky. That is something I can deal with and not my biggest concern. One of my major gripes is under WOT the bike feels like it is lacking now. Running rich maybe?
Damn near everywhere else is strong but this is my racebike and I need WOT to be improved. I've been bumped to Expert and I need every inch of HP!
Before I had the ECU flashed, I had a custom tune on my PCIII but I don't have the file saved. If I get my bike custom tuned, again, can I take the map and adjust it with the ECU flash?? Integrate both together?
CMRA #713
ZR1. is offline
post #5058 of 12553 (permalink) Old 01-25-2013, 01:26 PM
Tad158's Avatar
Did you have it flashed, or did you flash it your self or did F-T do it for you? Also what ECU image did they/you use? The ignition and fuel maps really dictate how much power you make, where, and how smooth it is delivered....
#158
2009 Raven R1
Tad158 is offline
post #5059 of 12553 (permalink) Old 01-25-2013, 01:44 PM
go go juice gonna make me win
tnole23's Avatar
anything special to know about the new checkbox option on step 5 for fuel map bias? holding the cursor over it gives info for fan temp. it was defaulted to 'selected' and tps vs rpm. also anything to be concerned with as far as updating my maps with the 'latest gear dependent throttle by wire' settings?
just updated ft today and not real sure what these are for.
FlashTune w/dyno fuel map|RaceTech Suspension|Termignoni CF Slipons|Attack Performance Rearsets|Brembo 19 RCS MC|Renthal Clipons|Dano QS|Akrapovic Y-Pipe|520 (-1/+1)|Hyperpro Damper|BlasterX|MRA Racing DB|Gilles Chain Adjuster| MotionPro Throttle|BMC Air Filter|Graves Smog Plates|GYTR Comfort Seat|Targa Solo Cowl|Tec-Spec Traction Pads|Pazzo Shorties|GB Racing Covers|Spiegler SS Brake Lines|HIDs|Flushmounts|Gear Indicator|Sharkskinz Track Bodywork
tnole23 is offline
post #5060 of 12553 (permalink) Old 01-25-2013, 01:51 PM
Tad158's Avatar
That is the load bias setting in the older version it used to be a slider. it is now a drop down box. TPS vs RPM is no 02 sensor. The different percentages are laid out in the faq.
#158
2009 Raven R1
Tad158 is offline
ecuunleashed 0r flashtune vtwin Appearance & Mods 61 11-16-2014 07:37 PM
Flashtune ECU Dyno Results sirjag Appearance & Mods 183 03-30-2014 05:08 PM
Flashtune reflash 07-08 R1 bwash85 Appearance & Mods 171 06-22-2012 07:48 AM
flashtune VS ecuunleashed vtwin Mechanical / Help 3 03-17-2012 12:50 AM
Yec Cable Interface BERNY Bikes/Parts Wanted 0 03-19-2010 12:58 PM
