-Engine braking
It is actually how snappy the throttle is...so a larger number the slower it responds a smaller number the quicker it responds...at least that is how it was explained to me...and it is only in a certain range of rpms
Well at least I have shown that you can make this bike smooth as butter and have way less engine breaking....to the point they want me to put it back in...at the beginning people thought it was impossible because of the cross plane design....:no...It was because of the terrible ECU map from the factory to meet emission, noise, and fuel efficiency regs....
Just flashed your "2012-2014-US-R1-V2soft-v6.4.4.8-TAD158-Track-Tune-STD(B)-OptionalA(STD)-Tweaked-A(A).ftm" last night and took it out for a test ride this morning. I have a 2014-R1 with Yosh TRC slipons, airbox mod, and M4 Y-Pipe. Prior to using your map I was running the FTECU Slipon Map with a PCV two brothers map. While it was okay it had a bit of engine braking and popped and farted on decel to the point of being a nuisance.
I took it to Ortega this morning and found that your map nails it for me. Engine braking is gone! Makes it so easy to roll of throttle and brake into a turn without upsetting the bike. Rolling thru the turns was a revelation, it was much smoother under maintenance throttle. Before it always felt like it was hunting for an RPM to match my throttle position. Lastly, the popping and farting on decel is finally gone. Well done. Thanks for the effort you put into this and sharing it with the rest of us.
Isn't the high RPM area full of 100 values in the boxes? So 100 minus 7 is -7% or minus 5 is -5%, so on. Anything with a 100 value will be 1:1 with percentage changes. Even 98 or 99 values could yield 1:1 changes based on the software rounding up to whole numbers. The only way I can get the correct values is to copy and paste them into excel.
I have also learned to copy any values I paste into FTE back into Excel to see if/how much the software changed them. This is a big annoyance with throttle maps. As perfect as you make them, the FTE software will change the values and undo your hard work.
After pasting into FTE and back into Excel then trying to re-smooth it a little:
It's like it can't resolve enough to make proper adjustments. If you look at the lines it's as if there are preset values it stuffs the values into by rounding up or down. This is exactly what I find when adjusting values in FTE. Quick test, it's as I thought, preset values in FTE, the value difference between numbers is 0.14367816091954.
i'm not sure if its the eu fuel or what, but tad's map seems to run quite rich, apart from that i'm now starting to dig the lack of engine braking, noticed side to side transition seems alot easier off the throttle and i seem to be going into corners alot quicker. :riding
EU fuel doesn't seem to have all the additives we do in the U.S. so your bikes can get away with running less fuel. If you look at most EU PC5 maps they're taking away fuel instead of adding.
Flashed about 95% of your image today Tad, I ran your B mode YCCT map for my STD map and my own maps I'm happy with for A and B. The only other changes were adjusting the speedo to 95% since this is what my GPS tells me is most accurate for my bike and temp to 192 and 203, seems to help with So. Cal heat a little more.
Engine braking is definitely reduced with your B throttle map, so much so I got a near cruise control effect at 5000 RPMs. I have a feeling the jumble FTE software does might be causing this since it's almost the same as it was last time I ran your throttle maps. My throttle maps have a little bit of this effect also, but definitely more engine braking going on.
So far an excellent image, need to watch my fuel mileage to see how that does, before with a PCV Leo Vince map I was getting a week out of a tank going to and from work, so I'm hoping to continue that.
I'll play with my throttle maps some more to try to clean up the cruise control part and get smooth engine braking, just reduced.
Did you use the stock etv decell comp maps? Or mine? Because there is a difference...and could be causing the cruise control feeling. I don't ever feel that on the track or putting around town...
I'll run it some more and see how it goes. It's your image with your ETV decel comp maps. Maybe I screwed up a copy and paste, I'll look at the maps in a little bit.
Since you have also had issues with it idling when cold, both issues nobody else have complained about. Can you humor me and check both TPS signals in diagnostic mode? Check the numbers at closed and WOT, as well as making sure that the numbers move smoothly at all times and transitions?
Oh, the idle seems to have cured itself with this last flash, so good there. I think I found my throttle problem, I pulled the wrong map from Excel. I have my maps in Excel to plot them and clicked the wrong tab to copy and paste. So my fault there. I flashed it again last night, will ride it this morning to see how it does.
I've also left the injector cut disabled and that seems to have cured the crackle on decel and occasional pop going from zero to partial throttle. In short, I think it's good to go now. I just need to get a data logger so I can check things and make adjustments to suit my setup.
I saw it...look at what I have in my image. Increase or decrease the whole last two columns of that map until you get the idle speed you want. I have been able to crank it down to 1050 and up to 2100 using that method. Your map you attached in the email won't work well. Remember that the values in the cells are 10xTPS.
Hi guys. I'm from singapore and i'm currently riding a 2011 R1. Had my ecu flash quite sometime ago and it seems like everyrhing is wrong. My bike starts with B mode and apparently my A mode is shit. Bike is running too rich according to one of the mechanic from a bike shop. Could any of you guys help me out?
Yep right here....if you have a question I am sure someone else has the same question...and can learn from yours...and you can get help from the community, not just me...
Ok the thing now is, my ecu is being flash by a particular vendor. Apparently my bike response like crap. And there is too much of popping when i close my throttle. I'm not sure how do i copy another person image and put it to mine, that is why i am seeking help from here. ):
Anyway tad, is there any ways you can come out with a custom mapping for me? I dont mind paying for it though. As i am heading to the track next week and i doubt such map that i have now suits it. ):
Ok guys hopefully this thread is still active and some of my questions can be answered
Firstly it seems hard for me to find info. I have a 2006 r1 the yellow 50th.
It seems that the 2002 to 2006 have a Mitsubishi made ecu ( or Mitsubishi software based ) and then moved to denso for 07 onwards
Now questions.
Woolichracing have a flash tune harness available for the earlier years where ftecu inc. do not offer a harness or software for my bike
Does anyone have a 2006 with a harness and software with any info on which company to go with
If no one out there does can someone shine some light on the dark areas of the flash tune for this year
I understand that not being fly by wire will limit my ecu's functionability but what is my ecu really capable of and what really are its limits
I know this is a broad question
I'm just getting confused by woolichracing's interface not offering a lot of things that seem to be offered by mail in flash tunes
What software are these company's really using to flash my ecu's that I can't obtain myself with an interface
I wouldn't bother with earlier years even 07 or 08 there nothing wrong with them.
Can anyone confirm if i purchase a secondhand flashtune interface cable can i purchase a license to work with my ecu?
