The secret of the 2012 side light - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
Closed Thread
post #21 of 44 (permalink) Old 12-03-2012, 10:59 AM
Originally Posted by JRH_YellowR1_09 View Post
They sealed the LED housing, because LED's theoretically have no where out mechanism if the current is properly limited to safe level.
LEDs last forever and a day, and then some..!! they are very, very low current.! no point in making it serviceable... i dont think Yamaha ever intended for it to light the whole bar, looks to fade naturally..
. i still think they're fugly as all hell... but thats just me...
post #22 of 44 (permalink) Old 12-03-2012, 11:03 AM
R1 Forum Star
z064life's Avatar
Originally Posted by T-MannIBP View Post
Try more like I payed $130 dollars for my '12 Upper/Headlight conversion after I sold my '09 Upper and Headlight.
Bike looks ten times more aggressive and I love my LED strip!
headlights arent' needed on the track
Phantom Squadron XO -
z064life is offline
post #23 of 44 (permalink) Old 12-03-2012, 06:11 PM
burn-z's Avatar
It's nice to have the option though.
Sig courtesy of Petrol Spice
burn-z is offline
post #24 of 44 (permalink) Old 12-03-2012, 06:42 PM
Rebel w/ a Cause
Can you cut & rewire power supply to a 09-11 corner bulb unit and pop it back in? I know people can swap little led bulbs like that. I had my Tach changed from blue to green and I believe the guy that did it had to change each led on the circuit board. It's gotta be possible but slot of work. Also kudos for cutting that thing out I've been dying to see that actually.
That's Dope as f*ck...
JDollaz is offline
post #25 of 44 (permalink) Old 12-03-2012, 06:48 PM
V4 addict
Oz_R1's Avatar
Hey Burn-Z is your raceglass from cleverwolf?
Oz_R1 is offline
post #26 of 44 (permalink) Old 12-03-2012, 06:54 PM
burn-z's Avatar
Yes Sir...endurace kit.
http://www.cwr.co.jp/cathand_bparts/detail_1055.html
burn-z is offline
post #27 of 44 (permalink) Old 12-03-2012, 07:07 PM
R1 Forum Star
z064life's Avatar
Haven't found an organization that runs trackdays at night yet....
z064life is offline
post #28 of 44 (permalink) Old 12-03-2012, 07:21 PM
V4 addict
Oz_R1's Avatar
Yes sir thank you sir
Sent from my GT-I9100 using Motorcycle.com Free App
Oz_R1 is offline
post #29 of 44 (permalink) Old 12-03-2012, 07:44 PM
burn-z's Avatar
You can run with your headlights on at Miller. Since I'm not doing any racing I'm pretty sure that rules out endurance racing...but I can run down the street legally if throw on a tailight.
burn-z is offline
post #30 of 44 (permalink) Old 12-03-2012, 07:52 PM
R1 Forum Star
z064life's Avatar
and turn signals
z064life is offline
post #31 of 44 (permalink) Old 12-03-2012, 07:55 PM
burn-z's Avatar
and turn signals
That's what hand signals are for.
burn-z is offline
post #32 of 44 (permalink) Old 12-03-2012, 07:59 PM
R1 Forum Star
z064life's Avatar
well you did want legal
I'll see your hand signals and one up to you say I can tape a flashlight to the front of mine
z064life is offline
post #33 of 44 (permalink) Old 02-10-2013, 06:40 AM
led
Originally Posted by Flash-Ry View Post
There side light is white and the light travels about 2/3 the way down
Shot at 2012-07-27
Hi Flash-ry did you completed your LED light? Did you install/custom build a new bracket for a T10 LED .? Please show how you did it if you already done this project, thanks in advance.
Unirone is offline
post #34 of 44 (permalink) Old 02-10-2013, 07:37 AM
I'm an Englishman in WI.
Redgecko's Avatar
That Endurance setup is sick Chris.
Redgecko is offline
post #35 of 44 (permalink) Old 02-10-2013, 08:12 AM
Need $ for bike parts
BlackShadow's Avatar
Looking good Chris, I miss the black
Sig by Uncle P
I wish my Dad was alive to see some of the crazy shit I do. RIP Pops
BlackShadow is offline
post #36 of 44 (permalink) Old 02-10-2013, 04:50 PM
~ RELAPSED MOD ADDICT ~
FaSt iNtEnTiOnS's Avatar
Any light on the original topic OP? I've tried this too and became lost after I seen its internals?
FaSt iNtEnTiOnS is offline
post #37 of 44 (permalink) Old 04-01-2013, 04:43 AM
Here is my mod, currently ordered another brighter set of T10 hope it will shine all the wayndown:
Warning: it is a permanent mod, you can never turn back to original stage.
1) remove all front faring and remove the headlight unit from the bike
2) remove both LED strip from the unit (only clips, unclip with care and gentle
3)remove original LED circuitboard from the light, the onlyway to remove is to cut it off and say goodbye to it, it is your choice how to do it, I use a solder to melt the surrounding plastic,
Note: only cut a diameter enought to take the circuit board out, becAuse i want to keep the remain to glue a washer on it.
4)sand the surface smoth and glue a 1.2" washer ontop this to hold/support the 2009 r1 cord assy that we will use.
5)now you can use the 2009 r1 T10 Holder (i order it from yamahaparthouse - cord assy - http://www.yamahapartshouse.com/oemp...8069/headlight
Cut the 09 cord assy connector off and weld the wire to the oringal 2012 connector,
6) here is what it will look after use a super white 5w T10 LED bulb , I still not satisfy with the brightness, will order a better SMD T10 led,
Here using a blue T10 bulb
7) reinstall the LED strip back to the headlight unit and to the bike
I am waiting to try this LED t10
http://www.ebay.com/itm/270981307999...84.m1439.l2649
Unirone is offline
post #38 of 44 (permalink) Old 04-01-2013, 05:29 AM
Where did you order it from? Can the color be changed?
mannny9008 is offline
post #39 of 44 (permalink) Old 04-01-2013, 07:15 AM
R1der
kingnba6's Avatar
i think he ordered the t10 holders from the older generation r1s. you can change the color because its a simple t10 led bulb. any color you want.
btw nice work!
R1-013 'Lucky 13th' Squadron
kingnba6 is offline
post #40 of 44 (permalink) Old 04-01-2013, 08:31 AM
Rebel w/ a Cause
JDollaz is offline
Closed Thread
12 R1 Stock Headlights On 09-11 R1 rocketz Appearance & Mods 508 02-28-2017 02:25 PM
Aux. light removal 2012 R1 Oilfieldtrash21 Appearance & Mods 6 06-18-2012 02:49 PM
guage lights, rpm guage, temp guage, neutral light, side stand light -ALL not working 150atwheel Mechanical / Help 4 01-02-2008 07:39 PM
