Flash tune with pc5 - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 33 (permalink) Old 08-15-2012, 11:18 AM
v1025566's Avatar
Originally Posted by frogsak1 View Post
Installed correctly. ? I will install it as the direction on the papers they send and there would most likely be something on YouTube
Sent from my iPad using MO Free
Installed corectly as per the instuctions, majority of problems with pcv and autotune is incorrect installation.
v1025566 is offline
post #22 of 33 (permalink) Old 08-15-2012, 12:23 PM
Feel the speed attack!
marider's Avatar
Send a message via Skype™ to marider
Is the auto tune that good that it tunes as you ride ??? The dyno guys here in aus say not to have them because they are not reliable ??
Yup, it does the job and modify fuel map on the fly. The only problem I had with the Auto Tune installation were a little too short cables that connect the o2 sensor with a black big plug with cables that go into PC V (I wrote to DJ about that) but I manage to lay that f... plug horizontaly somehow and then it was OK. Also don't forget about small black jumper that goes into AT module!
marider
Longest distance between two curves... straight line
EU 09 R1:
full Akrapovic Evo2,F-T'd ECU,Bazzaz ZFi-TC+Z-AFM,Marchesinis,Ohlins damper+FPK108+.95 springs,q'Ohlins r.shock,
Brembo RCS/w Hel&Braking SK rotors,Graves block offs,Clutch Kit,Fabbri screen,GYTR:sliders,clutch sliders,gel seat+cowl,Gilles VCR+Variobar,Gregg's Flushmount,-1/+1 sprockets,CustomLED mod. 3/4Dyno:170.1 RWHP,77 Tq.
marider is offline
post #23 of 33 (permalink) Old 08-15-2012, 03:43 PM Thread Starter
ghost
frogsak1's Avatar
With the auto tune what's your thorts on setting the A/F at 13.5 across the table and then reduce the A/F down to about 12.7 ish at full throttle
Sent from my iPhone using MO Free
frogsak1 is offline
post #24 of 33 (permalink) Old 08-16-2012, 09:16 AM
DRGTI's Avatar
Hi guys , does anybody know where I can get a map for gtyr slip-ons and pcv ? I have a '08 R1. Thanks in advance.
DRGTI is offline
post #25 of 33 (permalink) Old 08-16-2012, 12:55 PM
Trackday junkie!
Powerflux's Avatar
Take a look at this thread! GYTR is mentioned in post 172!
2009 R1 power commander maps
M4 Y-pipe
K&N filter
Goodridge SS front brakelines
ProGrip 714 grips
SpeedoDrD
HVMP Extra Heavy Bar Ends
Black Shorty Levers
Graves clutch kit
Greggs`s Custom flushies
Powerflux is offline
post #26 of 33 (permalink) Old 08-16-2012, 12:55 PM
jcfz6r1's Avatar
check the dynojet website first.
R1-013 Lucky 13th Squadron
jcfz6r1 is offline
post #27 of 33 (permalink) Old 08-16-2012, 01:32 PM
DRGTI's Avatar
Thanks powerFlux,
jcfz6r1, I tried but have found no stock map in their library for the gtyr slip-ons.
Thanks again guys. Noobie here.
DRGTI is offline
post #28 of 33 (permalink) Old 08-22-2012, 04:14 PM
DRGTI's Avatar
Anybody ?
DRGTI is offline
post #29 of 33 (permalink) Old 09-14-2012, 03:16 PM
R1 OH MAN!!!!
darkone7's Avatar
power commander map
Use map M22-006-007.pvm (graves slipon). It is the most near your setup. No that is for an 09!
It's all about the ride... and the company!!
darkone7 is offline
post #30 of 33 (permalink) Old 10-10-2012, 03:23 PM
J58
Mach.81's Avatar
Has someone mapped a PCV in the closed loop area (<18% throttle <6000rpm) and produced a good working map? (flashed ecu) Afterflashing this changes to "open loop" high load fuel mapping. So fueling needs to be corrected for mods. (comon mod slipon + Y pipe) Asked DJ awhile ago.....said they would try to get to it.....said it was "uncharted territory" Thoughts were flashing is getting fairly common and dyno mapping of this area would be beneficial to PCV owers with flashed ecu's.
Note : lots of complaints thoughout the threads in the 5000rpm area.
Mach.81 is offline
post #31 of 33 (permalink) Old 10-10-2012, 06:58 PM
toysareforboys's Avatar
When you set up the AFR map in the AutoTune, don't let it AutoTune low throttle/low RPM areas (set AFR target to 0 in those areas), that's where it causes the most trouble.
Set it to tune over 15% throttle and over 3000rpm and you should be fine.
On the dyno I was getting maximum HP and Torque at 12.8 at WOT and generally run 13.2 all over the rest of the map (I like it rich ).
-Jamie M.
toysareforboys is offline
post #32 of 33 (permalink) Old 10-14-2012, 02:24 AM
hey mate i live in australia and the best thing you could do is get your bike to pro cycle dyno if u live near QLD fred is a champion at tuning them he got 180 rwhp out of my 06 r1
evlr1nitrous is offline
post #33 of 33 (permalink) Old 11-17-2012, 02:46 AM Thread Starter
ghost
frogsak1's Avatar
I have a flashed ECU and just installed the PC5 with Auto tune I have to say its smoothend out the ruff ness around 5k and the bike now is halling ass big time
My auto tune starts at 2 % and is running mostly 13.0 but I will have to do some more KM before I except the new trims
Very very happy rider now
frogsak1 is offline
