Sprocket Help - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 30 (permalink) Old 10-12-2012, 11:29 PM
R1 pilot
RedDevil154's Avatar
Originally Posted by Whitevenum View Post
Interesting. So if i get the driven 520 with -1 front and stock t45 the bike will have a better launch? What if i get the t47 rear, what effects will happen there?
Yes you will have better take off with the -1 up front and you will have even more take off with +2 in the back. Keep in mind, going -1 up front is like going +3 in the rear just to give you an idea.
The smaller up front, more take off with less top end. The bigger up front less take off with more top end.
Opposite for the rear. The bigger you go in the rear, the more take off with less top end. The smaller you go the less take off and and more top end.
RedDevil154 is offline
post #22 of 30 (permalink) Old 10-12-2012, 11:48 PM
HP Addict
Whitevenum's Avatar
I see, so maybe ill just try out the -1 front and stock rear first. See how i like it, i dont want to over kill it. Thanks
Whitevenum is offline
post #23 of 30 (permalink) Old 10-21-2012, 08:19 AM
nygto3's Avatar
What is the stock size in the front??
Sent from my iPhone using MO Free
nygto3 is offline
post #24 of 30 (permalink) Old 10-21-2012, 08:24 AM
R1 pilot
Depends on what year. I think 04 and up use a 17 tooth up front and 03 down use a 16. But I'm not 100%. Somebody will chime in that knows. 07 up definelty uses 17 tooth just not to certain about the older ones.
post #25 of 30 (permalink) Old 10-21-2012, 09:35 AM
toysareforboys's Avatar
Always go to http://www.gearingcommander.com and look it up You can play with the gearing there too and see what difference it makes. If trying to determine top speed (theoretical or otherwise) make sure to change the RPM in the green custom section to your rev limiter (13750).
-Jamie M.
toysareforboys is offline
post #26 of 30 (permalink) Old 11-07-2012, 09:07 PM Thread Starter
drozek's Avatar
Can someone tell me the number of links I would need when I go -1 front +2 in the back?
2010 Yamaha R1
Leo Vince Unlimited Mid Night Slip On's
Two Brothers Stainless Steel Y-Pipe
ECU Flashed
BMC Air Filter
Shogun No-Cut Frame Sliders
https://twitter.com/drozek
drozek is offline
post #27 of 30 (permalink) Old 11-07-2012, 09:10 PM
R1 Forum Star
z064life's Avatar
where do you want your wheelbase to be??
Stock length will still work
Phantom Squadron XO - http://www.r1-forum.com/forums/50-r1-012-%60phantom-squadron%60/
z064life is offline
post #28 of 30 (permalink) Old 11-07-2012, 09:12 PM
Yep, stock/120 will still work but she'll be at the front of the swingarm/adjusters. You can do 122 to have the wheelbase longer (the wheel will be around .65" farther back).
-Jamie M.
post #29 of 30 (permalink) Old 11-07-2012, 11:53 PM
Vendor
gsxcorey's Avatar
Best never to count links. Just get the chain a bit longer then you know you'll need and then install the new sprockets, put the rear wheel where you want it (normally closest to the front of the bike), wrap the new chain around, and then physically see where to cut the chain while remember you need chain slack as well.
gsxcorey is offline
post #30 of 30 (permalink) Old 11-07-2012, 11:54 PM
Vendor
gsxcorey's Avatar
We have a chart of stock gearing we keep on our website.
https://www.motomummy.com/stock_gearing.html
gsxcorey is offline
