quick throttle???? - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 32 (permalink) Old 10-30-2012, 08:08 AM
STFU and ride!!
2WEELFERRUM04's Avatar
i installed the robby moto QT
it woke up the old beast
i took the throttle body out and found the cause of the surging at idle too
cracked grommets= air leaks
fixed that and the quick throttle is fawking awesome
2WEELFERRUM04 is offline
post #22 of 32 (permalink) Old 10-31-2012, 07:41 PM Thread Starter
da rza's Avatar
so i tried the quick throttle mod on my stock throttle and did not work did not have enough adjustment in throttle to get it to work correctly...not something you want to half-ass on anyways..so the search for robbymoto quick action is on...$ was a bit to high from superbikesupply jus waiting on pjs parts to answer email...for those who have installed rm qt what goes for install on 07/08 r1?i see the kit comes with cables or are they not used?...any feedback will be appreciated!...
2007 r1 charcoal/blk
da rza is offline
post #23 of 32 (permalink) Old 11-02-2012, 06:11 AM
STFU and ride!!
the cables that come with it have to be used
be very careful as you tighten the two nuts to hold the cables at the throttle bodies
the tubed can be pulled apart at the threads
just tighten enough to make sure they wont slide off the steel plate.
let me know when you get it and i can walk thru it.
i took my throttle bodies out, it made for an easy install. plus i found issues with the airline caps. they were cracked and sucking air, the cause for my idle surging.
keep su posted
post #24 of 32 (permalink) Old 11-02-2012, 06:49 AM
Hope is what makes us Human.
Benocehcap's Avatar
keep su posted
Im about to buy one
Can you make a thread how to install one on a 01R1 pleaseeeeeeeeee
“Not every legend is a myth, some are flesh and blood. Some legends walk among us, but they aren’t born, they’re built. Legends are made from iron & sweat, mind and muscle, blood and vision and victory. Legends are champions, they grow, they win, they conquer"
Benocehcap is offline
post #25 of 32 (permalink) Old 11-02-2012, 11:29 PM Thread Starter
da rza's Avatar
Thumbs up
keep su posted
thanks i will
da rza is offline
post #26 of 32 (permalink) Old 01-09-2013, 01:53 PM Thread Starter
da rza's Avatar
have had rm quick action throttle for awhile now and like it very much...is the silver cam the quickest pull?...and what order/color do they go quickest to slowest pull? appreciate owner feedback....and what holes on cams should be used for quickest pull or does it make a difference?
da rza is offline
post #27 of 32 (permalink) Old 01-09-2013, 02:13 PM
Reflections's Avatar
i have the euro racing one, costs around 160 ish ? on my o6 racebike.
came with 3 cams, one is almost close to stock too if i wanted to go back without changing the whole assembly.
Reflections is offline
post #28 of 32 (permalink) Old 01-09-2013, 02:15 PM
stack the cams on top of eachother, the one with the largest gap (from hole to hole) is the shorter pull.
post #29 of 32 (permalink) Old 01-10-2013, 07:16 AM
Gap Addict
MotoMinx's Avatar
The silver one is similar to the the stock cam. Then comes blue, then red, and the black is the shortest turn, which is only recommended for track use.
MotoMinx is offline
post #30 of 32 (permalink) Old 01-10-2013, 09:05 AM
That Venom Swag Guy
Tek Daddy's Avatar
Motion pro also makes an adjustable kit
Tek Daddy is offline
post #31 of 32 (permalink) Old 01-10-2013, 08:53 PM Thread Starter
da rza's Avatar
Thumbs up
thanks man
da rza is offline
post #32 of 32 (permalink) Old 01-12-2013, 09:55 AM
Race Engineer's Avatar
What about the Activ kit, Firehawk2003 used one of these on his R7 Replica ;-)
Race Engineer is offline
