Jelizondo_20 build thread - Page 3 - Yamaha R1 Forum: YZF-R1 Forums
post #41 of 129 (permalink) Old 11-14-2012, 07:57 PM
graphitegripper's Avatar
Ya I have already setup mine and dialed it in best it can be for my 240lb body on stock suspension. But thanks for the quick link!
graphitegripper is offline
post #42 of 129 (permalink) Old 11-14-2012, 11:48 PM Thread Starter
jelizondo_20's Avatar
Thanks for the help about the suspension. I have noticed that the previous owner has made the ride stiffer than usual. I'm going to put it back to stock settings and go from there
Watch your Six!
jelizondo_20 is offline
post #43 of 129 (permalink) Old 11-19-2012, 07:33 PM Thread Starter
Installing these this week.
Name:	ImageUploadedByMO Free1353378821.112529.jpg
Watch your Six!
post #44 of 129 (permalink) Old 11-19-2012, 10:47 PM Thread Starter
So I got the exhaust cans off and in the process of drilling out the rivets but I need a stronger drill to get it done. Also on the bright side is that the baffle kit comes with screws instead of new rivets!
Name:	ImageUploadedByMO Free1353390471.717660.jpg
Watch your Six!
post #45 of 129 (permalink) Old 11-20-2012, 06:41 AM
Let the fun begin! U have a y pipe or smog plates yet?
post #46 of 129 (permalink) Old 11-20-2012, 06:42 AM
Remember, the tighter you wrap the fiberglass the louder it will be, loose will be quieter. Lets just say that my baffles with y pipe no make me have to wear ear plugs when I ride its THAT loud
post #47 of 129 (permalink) Old 11-20-2012, 08:33 AM Thread Starter
I plan on buying the ypipe and plates soon. I really want to flash my ECU next.
Watch your Six!
post #48 of 129 (permalink) Old 11-20-2012, 02:25 PM
I like me bike :)
LION R1's Avatar
Smile Wasssup dude
[QUOTE=graphitegripper;5400883]I wouldn't run velocity stacks since the 07-08 run variable velocity stacks unless he is drag racing only
Graves VS its variable, and you can use it on the street or track, ive got on my self...you gonna love it, you can feel the power comparing to full system exhaust.
Peace
LION R1 is offline
post #49 of 129 (permalink) Old 11-20-2012, 06:43 PM Thread Starter
Cool, I really appreciate the help guys. I am keeping a build list of things I want.
Watch your Six!
post #50 of 129 (permalink) Old 11-20-2012, 07:06 PM
Baffles are easy to do. Front sprocket is easy to do.
2008 "Raven" - Mostly stock: -1, gutted cat, SS brake lines, flash tuned, and fast as hell
Raven1Actual is offline
post #51 of 129 (permalink) Old 11-20-2012, 07:19 PM
[quote=LION R1;5405358]
Peace
Can you share a link to these? All o the ones I found were fixed.
Thanks
post #52 of 129 (permalink) Old 11-20-2012, 11:19 PM
I like me bike :)
LION R1's Avatar
Smile Back again :)
[quote=graphitegripper;5405639]
Thanks
Here is the link:
http://www.oppracing.com/category/30...ike_specific=Y
You can buy them as a full kit (lower & upper) togther, or just the lower and upgrade to the upper in the future.
All the best my friend.
LION R1 is offline
post #53 of 129 (permalink) Old 11-21-2012, 11:59 PM Thread Starter
I can't believe how much trouble I am having with the baffles. My holes don't line up with each other when I put the end cap on.
Watch your Six!
post #54 of 129 (permalink) Old 11-22-2012, 12:02 AM
You have to kinda tap them down into place because they are a little wider than the area where they sit. Does that make sense? You gotta force them down for that last 1/2".
post #55 of 129 (permalink) Old 11-22-2012, 12:11 AM Thread Starter
Yeah I get it, I got one on but one side doesn't match up anymore. This is first and last time on doing this.
Watch your Six!
post #56 of 129 (permalink) Old 11-22-2012, 07:31 AM
[quote=LION R1;5405991]
Here is the link:
Holy crap!!!! 900$ for 3hp???? No thanks, maybe when I crap gold bricks ill get em. Lol
Thanks tho
post #57 of 129 (permalink) Old 11-22-2012, 07:34 AM
I did mine within 45 mins. 2nd one was a pain. Gotta make sure u get the bottom of the baffle to slide over the pipe in the back of the can. Then twist to make sure the longest point of the baffle is at the top of the can and the cap should go on pretty easy after. Also wait to put the threaded clips for the screws on until after you get a good test fit on bc they like to snag the fiberglass.
post #58 of 129 (permalink) Old 11-22-2012, 07:39 AM
[quote=graphitegripper;5406892]
Thanks tho
See I knew somethin was wrong with this! Our bikes in this thread are 07-08 models. The 04-06 and 09-11 have velocity stacks. Never found a set for 07-08.
Thanks again tho. Good look
post #59 of 129 (permalink) Old 11-22-2012, 08:41 AM Thread Starter
[QUOTE=graphitegripper;5406893]I did mine within 45 mins. 2nd one was a pain. Gotta make sure u get the bottom of the baffle to slide over the pipe in the back of the can. Then twist to make sure the longest point of the baffle is at the top of the can and the cap should go on pretty easy after. Also wait to put the threaded clips for the screws on until after you get a good test fit on bc they like to snag the fiberglass.
Yea I needed to walk away before I tossed the exhausts cans in the air and say f&ck it. I'm going to try again today
Watch your Six!
post #60 of 129 (permalink) Old 11-22-2012, 09:44 AM
Gr8 White's Avatar
We do t have the flashing options here in south africa and we are too stuck in our old ways to try it....
But i had a bone stock 08 and small upgrades i found usefull and clean up the looks is stompgrip which helps alot with leg grip and sitting nice n tight, a puig screen really adds to look and makes quite a difference to keeping head stable at speed n flush indicators and mirror blanks to clean up the look
Oh and did the 520 trick whick i reccomend.
Sofar im dead happy
Gr8 White is offline
