heay y'all, i'll start by saying, this is by no means a HOW TO thread as I know there are others that could do a much better job than me,
I dont mind reading manuals and such but i've always hated writing them..
*note: since this is a rebuild of suspension for bigger guys, i've taken DanQs recommendation on FORK OIL LEVEL (s)
the manual recommends 117mm (from the top of the outer tube, with the outer tube fully compressed and without the fork spring)
I have mine set to 122mm, since this is a measurement from the top of the outer tube, we're effectively reducing the amount of oil used to fill the forks up
Race Tech recommends 120mm, i believe i will try this out at some point n' see where we're at
quick update as to what fluids i'm going with these days..
this has been a kind of a dream of mine for about 2 years now, to completely upgrade,
and in the process rebuild {learn how to} the entire suspension package
anyway, i'm more into computers and electronics than anything, but i figured with the help of my bud {machinist extraordinaire}
and access to all the tools I could possibly need, how can we go wrong! :dunno
2 years ago I got a bit of a leg up by a fellow member as he was selling his newly purchased OHLINS 30mm FPK
{thanks AnonymousR1, he was after real OHLINS forks}, which would allow me to upgrade the valving up front...
so I figured, you may as well do it right... whats it gonna take? pulled the trigger :sing:
i proceeded by purchasing a set of 0.95kg/mm fork springs from Race Tech USA, along with a 11.6kg/mm shock spring.
I also decided to purchase a RACE TECK G3-LD Gold valve for the shock, and to top it all off an extended RT reservoir
cap for said shock.
of course at the time I was healing from a previous motorcycle accident and wasn't riding much,
I decided to upgrade the springs and wait till winter to do the valving, which is a bit more complicated a process.
unfortunately, life took a turn and I received doctors orders that I was not to ride the bike due to complications
from my fall and {without boring you} I actually ended up being sidelined during 2012!! what started rather literally
2 months short of 2 years ago, is now finally taking place..
some may have read of my little ooopsie with one of the backing shims for the Ohlins COMPRESSION valve {performance section},
and of course as it turns out it really isnt a big deal at all, i should have it sorted by tomorrow if luck is with me.
anyway... on to the pics... !! i'll be posting up a small description of the process as we go along but please be aware, I tend to skip over the easy parts...
lets just say the 1st thing I did was remove the forks & rear shock! D'UH!! :dunno :lol
yes, i'm starting from somewhere in the middle, hahaha... i'll document the fork rebuild more clearly once i have a chance to go up to the shop.
in the ghetto :sing:
meaning if you're having issues on the 09+ R1 and bottoming out the forks, adjust oil level by 5mm at a time
cap for said shock.
