Status
Not open for further replies.
2015 R1 Seat cowl, anyone still have the instructions?
6K views 8 replies 4 participants last post by  JLeosnow
Hello,
Looking for a favor.... If anyone still has the instructions that came along with your seat cowl would you be able to take a look at them and get me the part# of the bracket that comes with it that volts to the rear subframe and provides the seat cowl a place for the 2 mounting to thread into?
I already ordered and recieved one from a M(came with a bracket for the seat cowl from the factory) and it is slightly different and will not work.
Thanks,
-John
Save
That braxket(#12) is what I am looking for but the one supplied in the accessory cowl kit. I already ordered and recieved #12 In the diagram and it is different(fits slightly different/won't work)than the one supplied in the accessory cowl kit.
Thanks,
-John
Save
It should work. When installed mine I admit that I thought it did not fit either. But I had it backwards. Rotate it around n flip it. If the cowel is oem you shouldnt be having a problem.
The M cowl will only work with the M bracket. The non M regular cowl needs its own bracket (I have no idea what the part # is either). The hole spacing and angles are different between the M carbon seat cowl and the regular seat cowl. The regular seat cowl will not mount on my M with the M bracket. I have both and tried because I have lost my regular bracket.
Dealer said its not available separate from the complete cowl... :-0
-John
Save
Status
