R1 1999 offset - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 14 (permalink) Old 03-19-2017, 10:41 AM Thread Starter
Jonas A's Avatar
R1 1999 offset
Ok, i have a R1 1999 and i have mounted a front fork (legs), brakes and wheel from R1 2005.
But like i know the legs are 15mm shorter than the old.
How can i extende the new forks to the missing 15 mm?
Or is there a easier way?
I have read a lot about the "head shake" problem.
I can't try my bike yet becuse of snow so i have to trust everybody ho have done this swap.
But i can't find enything how they have fixed the problem.
Jonas A is offline
post #2 of 14 (permalink) Old 03-19-2017, 11:27 AM
zx7marsh's Avatar
I've done the same change to my '99 with 04-06 R1 forks. You can set the top of the fork outer tube flush with the top of the upper triple, and the fork cap will be the only thing above the triple. Here is a pic of mine, my tubes were raise in this pic.
zx7marsh is offline
post #3 of 14 (permalink) Old 03-19-2017, 11:37 AM Thread Starter
Jonas A's Avatar
I see that you use another triple tree.
Is it same offset like triple tree from 1998-01, 2002-03 or 2004-06?
Jonas A is offline
post #4 of 14 (permalink) Old 03-19-2017, 11:52 AM
zx7marsh's Avatar
04-06
zx7marsh is offline
post #5 of 14 (permalink) Old 03-19-2017, 01:25 PM
NeeD 4 SpeeD
sss r1's Avatar
i've done the same swap . i set the forks flush . adjusted the rear with adjustable dog-bone to compensate just a little . some like raised rear anyways .
cant say my geometry is perfect right now , still working on it .
sss r1 is offline
post #6 of 14 (permalink) Old 03-19-2017, 01:54 PM
Have you changed the triple clamp, or just the forks?
Sent from my iPad using Tapatalk Pro
NZ_R1 is offline
post #7 of 14 (permalink) Old 03-19-2017, 02:06 PM
NeeD 4 SpeeD
sss r1's Avatar
who me ? yes i did . different triple offset . 35mm stock , 25mm on 04-06 triples
sss r1 is offline
post #8 of 14 (permalink) Old 03-19-2017, 02:22 PM Thread Starter
Jonas A's Avatar
Soo the best triple tree is R1 2004-06 for this swap?
Jonas A is offline
post #9 of 14 (permalink) Old 03-19-2017, 03:34 PM
zx7marsh's Avatar
I have the 98-01 is 35mm offset, 02-03 is 25mm and 04-06 is 30. Then it varies again on the newer bikes. There is no perfect offset, everyone has their own preferences, stability vs turn-in, etc.
zx7marsh is offline
post #10 of 14 (permalink) Old 03-19-2017, 03:45 PM Thread Starter
Jonas A's Avatar
Ok, then i will try first with my -99 triple tree.
If that wont work i have -05 triple tree lying.
Jonas A is offline
post #11 of 14 (permalink) Old 03-19-2017, 05:15 PM
Sorry, I meant the OP. But I think he's answered the question now.
NZ_R1 is offline
post #12 of 14 (permalink) Old 03-19-2017, 10:10 PM Thread Starter
Jonas A's Avatar
I still have the old triple tree on the bike.
Which triple tree do you use?
Jonas A is offline
post #13 of 14 (permalink) Old 03-20-2017, 12:36 AM
I have the standard forks and triple tree. My plan is to have the forks revalved because I want to keep the bike looking original.
Most people replace the triple tree because the 98-01 bikes have quite aggressive steering geometry. Either 02-03 or replace the complete front end from a 04-06 - everything including wheels.
NZ_R1 is offline
post #14 of 14 (permalink) Old 03-23-2017, 01:50 PM
99 R1
Death R1's Avatar
Send a message via AIM to Death R1
FYI, I have a set of attack racing triples for sale with adjustable offset .. PM if interested ..
Tuned by Bugaj
"In pursuit of more speed with the same power"
my "back from the dead" thread:
Death R1 is offline
