2000 r1 wont start anymore after installing battery - Yamaha R1 Forum: YZF-R1 Forums
00-01 R1 Mechanical Help Mechanical and Critical Issues for the 00-01 R1
post #1 of 4 (permalink) Old 07-27-2007, 04:50 PM Thread Starter
Unhappy 2000 r1 wont start anymore after installing battery
while the bike was key on, i was fiddling with the battery terminals and it kind of flickered. The bike was starting fine but now wont start. I think a fuse broke but all the fuses look good in the fuse box. i just got a new starter relay and tryed that. That didnt work either. If i touch both terminals ont he starter relay it cranks over but doesnt start?
there is alittle bit of oil on the kick stand sensor. but i tryed to unplug the sensor and start and still no start. does anyone have any advice
bratt is offline
post #2 of 4 (permalink) Old 07-27-2007, 05:53 PM Thread Starter
I did some checks.
all fuses are good including the 30amp on the starter relay
checked the pin under the clutch lever and its good
kicked it in neutral, my nuetral light in the guage has never worked though.
I can hear the fuel pump start up when i key on and everything lights including the tach.
It just wont turn on when i press the start button.
is there a way to trigger the start button without pressing the start button. maybe my start button is bad? but the bike will not turn on if i touch the starter relay terminals. it turns over and over and over but does not fire up. so i think that could be a bad on / off switch or bad kickstand
bratt is offline
post #3 of 4 (permalink) Old 07-27-2007, 10:34 PM
1RFZY99's Avatar
Did you try to jump starting it. Your bike's cdi requires 12.4 volt to even spark. Then it's got to have enough amps top push those volts. Try to jump start with a known good batt. Sometimes a batt. will go bad to where it will turn the motor over a while with no prob but it still won't have that 12.4 to activate the ignition.
1RFZY99 is offline
post #4 of 4 (permalink) Old 07-29-2007, 02:51 PM Thread Starter
the battery is brand new fully charged at 12.5 volts. i can smell gas when i short the 2 terminals on the starter relay. I think my on / off switch might be bad because its not starting up anymore. maybe the kickstand or the nuetral switch is doing this? it was working just a while ago but i was installing the battery while the bike was key on and now it wont start!
bratt is offline
99 R1 Wont Start fredthegeek 98-99 R1 Mechanical Help 3 08-05-2009 12:42 PM
2000 r1 wheels on a 99 r1? UnknownR1 98-99 R1 Mechanical Help 4 06-25-2007 11:10 PM
03 R1 won't start JBliff77 Mechanical / Help 1 04-19-2007 08:18 PM
r1 won't start 2000 thechooze Mechanical / Help 6 05-23-2003 04:34 AM
2000 R1 dies while riding...battery??? ghostrider1 Mechanical / Help 6 03-04-2003 06:31 PM
