Headwork Winter Project - Page 1022 - Yamaha R1 Forum: YZF-R1 Forums
 5Likes
post #20421 of 20615 (permalink) Old 11-06-2012, 03:55 PM
burnin' up the streets
BSR-1's Avatar
3/4 Leo SBK and bmc filter. Pretty much it
So you've added more air but not more fuel. That can (will) make more heat.
I just want to stroke it all the time. (For you BSR )
BSR-1 is offline
post #20422 of 20615 (permalink) Old 11-06-2012, 04:25 PM
Gearheaded's Avatar
I had the ecu flashed and listed my mods. Flash tune is supposed to add fuel accordingly. Whether they did or not I don't know because it hasn't been dyno tuned or anything, but I trust they did
Whoody whoody woo!
You pecker head....
R1-016 Venom Squadron
Gearheaded is offline
post #20423 of 20615 (permalink) Old 11-06-2012, 04:34 PM
BSR-1's Avatar
I'd get a PC-V and a custom map but that's just me.
It may or may not solve your heat issue but your bike will run WAY better!
BSR-1 is offline
post #20424 of 20615 (permalink) Old 11-06-2012, 09:21 PM
Yamaha blue, in any color.
DanQ's Avatar
Yea i have fans in the pits and kill the bike before it overheats, but my higher priority problem is the coolant filling the over flow during track riding. I am afraid it is going to spit coolant out of the overflow tube and soak the rear tire
Dan
R1-016 'Venom' Squadron Member
CCS #598
91 FZR 1000
04 YZF-R1
05 YZF-R6 (track bike)
04 Road Star Warrior
DanQ is offline
post #20425 of 20615 (permalink) Old 11-06-2012, 10:53 PM
look for special phrase here
greenstreak9205's Avatar
A pcv shouldn't do anything more than what he already has. The flash tune does the same thing but doesn't physically add any wires/modules/boxes...ect..plus it will do things a PCV can't do. So adding one wouldn't exactly help with fueling as you're implying. It's kind of a neat system they have with it
The Man, The Legend Uncle P
greenstreak9205 is offline
post #20426 of 20615 (permalink) Old 11-07-2012, 01:21 AM
Taking my bike test soon :)
Tim Radley's Avatar
Is flashtune a closed loop system or a generic map?
"Engine builder for the worlds fastest Skoda - 227mph, Bonneville class record
"One mans ceiling is another mans floor" - Erland Cox.
"Don't judge me by your ability" - Clive W.
Tim Radley is offline
post #20427 of 20615 (permalink) Old 11-07-2012, 12:20 PM
I personally have not messed with it first hand. So I don't wanna be that guy passing out info w/out using it personally. But I believe you can operate it very similar to a PCV/bazzaz by changing the tables. You can enter a map, leave it open/closed loop, ect... But again, that's the info I've gathered from reading a bit and listening to other that have had the opportunity to play with it
post #20428 of 20615 (permalink) Old 11-07-2012, 04:39 PM
Gearheaded's Avatar
This is correct.
It has a tuning interface like a power commander or bazzaz, it's just better with more options
Whoody whoody woo!
You pecker head....
post #20429 of 20615 (permalink) Old 11-07-2012, 05:03 PM
BSR-1's Avatar
This is correct.
But the question was:
Maybe I'm confused but it seems like it doesn't have a lambda sensor or any other means to check fueling and make adjustments, right? It's just someone's guess as to what you need.
BSR-1 is offline
post #20430 of 20615 (permalink) Old 11-07-2012, 05:23 PM
Gearheaded's Avatar
It's the ecu
Whoody whoody woo!
You pecker head....
post #20431 of 20615 (permalink) Old 11-07-2012, 06:49 PM
BSR-1's Avatar
It's the ecu
I know it's the ECU......it's been, "flashed"...... my question is, How does it know to adjust fueling? Was it put on a dyno and properly tuned or did somebody just load a generic map into it in his garage?
I'm trying to help here but it's like we're talking two different languages.
If the fueling is too lean it can cause it to run hot. You've added more than stock air. How does anyone know if the, "flash" is adding the correct amount of fuel to compensate?
BSR-1 is offline
post #20432 of 20615 (permalink) Old 11-07-2012, 08:11 PM
Gearheaded's Avatar
The flash tune has an interface where I can adjust the amount of fuel. It also still uses the stock o2 sensor
Whoody whoody woo!
You pecker head....
post #20433 of 20615 (permalink) Old 11-07-2012, 08:26 PM
BSR-1's Avatar
Maybe I'm just uninformed, it may be fine.
Sorry if I came across as a dick, I just didn't think you were getting my point.
Last Ideas:
You could wire in a fan switch so that you can run the fan whenever you need to.
Have you tried engine ice or the other brand, (don't remember the name)? Are those allowed on racetracks?
Or pure water?
Pure water has a higher thermal transfer rate than coolant. The coolant has anti corrosion additives, long term use of pure water will cause rust but for just track use it would be fine.
BSR-1 is offline
post #20434 of 20615 (permalink) Old 11-08-2012, 07:47 AM
Already using water/water wetter
post #20435 of 20615 (permalink) Old 11-08-2012, 08:27 AM
Tim Radley's Avatar
But how do you know what and where to adjust? How was the mapping setup? The stock O2 sensor is not a wideband sensor so cannot be used for loaded higher rpm mapping at all its just a idle trimming device and a very crude one.
post #20436 of 20615 (permalink) Old 11-08-2012, 10:24 AM
Gearheaded's Avatar
Little update :
I got fed up with it and sent it to the shop, and magically they found nothing wrong. They pressure tested the system, holding beautifully...
Whoody whoody woo!
You pecker head....
post #20437 of 20615 (permalink) Old 11-08-2012, 04:34 PM
Gearheaded's Avatar
So now I'm lost. I think next I am going to have the bike dyno-tuned, and if that doesn't work I'm gonna burn it to the ground
Whoody whoody woo!
You pecker head....
post #20438 of 20615 (permalink) Old 11-09-2012, 12:23 AM
post #20439 of 20615 (permalink) Old 11-09-2012, 04:46 AM
Gearheaded's Avatar
I figure it can't hurt to even out the a/f mix . I'm not sure what's at
If that doesn't work I'm gonna just throw shiny parts at it
Whoody whoody woo!
You pecker head....
post #20440 of 20615 (permalink) Old 11-09-2012, 06:30 AM
Flashtune is just a device that allows you to modify and then flash the ECU ROM. Currently, you can adjust the YCC-T map and base ignition maps (one per gear) and the base fuel maps (one per cylinder in MAP vs RPM and TPS vs RPM)(for 07-08 R1, but you get the idea). The MAP vs RPM map is used only below ~14% TPS allegedly (for 07-08 R1). There are also other features such as a quickshifter, V-stack switch-over adjustment, rev limit adjustment, idle adjustment, EXUP delete...
Of course the only way to know what to adjust is to tune on a dyno or through some data logging. It just depends on your tuning criteria. Some guys are convinced they can tune the fuel and ignition maps by feel alone (high load).
SySt is offline
Headwork weekend project trottski Mechanical / Help 19 11-04-2008 03:54 PM
Winter project andyh Appearance & Mods 11 04-15-2007 02:37 PM
Winter Project 95% Done JspecZ R1 Appearance & Mods 23 03-02-2005 10:50 PM
Winter Project......... snorbitz General Motorcycle Discussions 8 01-29-2004 04:29 PM
So tell us...what your winter project will be? Maxxym General Motorcycle Discussions 23 09-27-2002 07:16 PM
