Headwork Winter Project - Page 1023 - Yamaha R1 Forum: YZF-R1 Forums
 5Likes
post #20441 of 20628 (permalink) Old 11-09-2012, 05:48 AM
Gearheaded's Avatar
Originally Posted by SySt View Post
Flashtune is just a device that allows you to modify and then flash the ECU ROM. Currently, you can adjust the YCC-T map and base ignition maps (one per gear) and the base fuel maps (one per cylinder in MAP vs RPM and TPS vs RPM)(for 07-08 R1, but you get the idea). The MAP vs RPM map is used only below ~14% TPS allegedly (for 07-08 R1). There are also other features such as a quickshifter, V-stack switch-over adjustment, rev limit adjustment, idle adjustment, EXUP delete...
Of course the only way to know what to adjust is to tune on a dyno or through some data logging. It just depends on your tuning criteria. Some guys are convinced they can tune the fuel and ignition maps by feel alone (high load).
You can use a wide band and the highway, personally I wouldn't, but some people do..
Whoody whoody woo!
You pecker head....
R1-016 Venom Squadron
Gearheaded is offline
post #20442 of 20628 (permalink) Old 11-09-2012, 03:18 PM
Taking my bike test soon :)
Tim Radley's Avatar
Some people jump in front of trains but i wouldn't recommend that either
"Engine builder for the worlds fastest Skoda - 227mph, Bonneville class record
"One mans ceiling is another mans floor" - Erland Cox.
"Don't judge me by your ability" - Clive W.
Tim Radley is offline
post #20443 of 20628 (permalink) Old 11-09-2012, 04:37 PM
brocks07R1's Avatar
Interface
The interface does have basemaps to start with. It dont just sit you out there blind though.
Heads done by docdug, ECU Flashing, Brocks full shortmeg undertail exhaust, Powercommander V, Factory pro Velocity stacks, No air filter, Brocks clutch mod, 3 Mccoys HD springs, Swingarm extention 63.5", -2 N stock gearing, Michelin Cup rear tire, Front end straps, Adjustable lowering link thats machined 2 more inches for extra low, Track pack clutches.VP MRX01
brocks07R1 is offline
post #20444 of 20628 (permalink) Old 11-09-2012, 06:27 PM
Yes, the but modifying those base maps without the proper instrumentation is tuning blind. No offense, but in the context you used 'basemaps' in I doubt you really understand how maps are used in the ECU. I recommend some research into.
Sent from my DROID4 using Motorcycle.com Free App
SySt is offline
post #20445 of 20628 (permalink) Old 11-10-2012, 12:44 AM
Tim Radley's Avatar
This is the problem with giving the public access to ecu's. Its no different to selling them jet kits. I've had people come in and say "yes my friend tuned my bike for me at the track". "Oh how did he do that". "He adjusted the idle screw whilst blipping it, its really crisp now". That's like looking at a cracking tit job and the camera pulls back and its some 70 year old
As you said no offense to anyone having a play but its either right or its wrong. There is no middle ground. Generic maps are at best useable but nowhere near optimum. The data going in is only as good as the person entering it too!
post #20446 of 20628 (permalink) Old 11-10-2012, 06:53 AM
brocks07R1's Avatar
Basemap
I understand that when you buy a exhaust that they also send you a map which would probably considered as a "basemap" so your bike wont run like total crap until you can get to a tuner. I my self do not have an interface but i do have my ecu flashed and yes i have tuned my bike with the flashing.But i would like the capabilities to advance or retard timing which the interface gives you that capabilitie.
On another note the autotune is a alternative way of tuning for everyday riding instead of a dyno run everytime you go to the track or a LCD screen where you can adjust for the weather among other devices that display air and fuel mixture.
post #20447 of 20628 (permalink) Old 11-11-2012, 02:49 AM
Tim Radley's Avatar
Yuuuuup
The base map is just a start. I often see some of the US powercommander maps being really poor when run on UK bikes as our fuel is quite a lot different to theirs. Probably not a worry for americans running our maps though as they are all gay and can't ride so never run high rpm anyways.
post #20448 of 20628 (permalink) Old 11-11-2012, 04:57 AM
Gearheaded's Avatar
Yuuuuup
Least our women don't have hairy armpits
Whoody whoody woo!
You pecker head....
post #20449 of 20628 (permalink) Old 11-11-2012, 06:54 AM
Tim Radley's Avatar
That's germany, here they have hairy upper lips
post #20450 of 20628 (permalink) Old 11-11-2012, 07:35 AM
brocks07R1's Avatar
Lol
Yuuuuup
Lol thats funny. I am a drag racer so my RPM stay above 12000 but your right I don't know how to ride on a road racing track.lol! I'm definitely not gay though.
post #20451 of 20628 (permalink) Old 11-11-2012, 04:26 PM
burnin' up the streets
BSR-1's Avatar
Is that what my problem is?
All those years in therapy and I could have just talked it out with you!
I just want to stroke it all the time. (For you BSR
BSR-1 is offline
post #20452 of 20628 (permalink) Old 11-12-2012, 04:42 AM
firehawk2003's Avatar
prefer calling that 'brazilian'.
firehawk2003 is offline
post #20453 of 20628 (permalink) Old 11-12-2012, 09:45 PM
look for special phrase here
greenstreak9205's Avatar
Thread went down hill quick there
The Man, The Legend Uncle P
Phantom Squadron CO
greenstreak9205 is offline
post #20454 of 20628 (permalink) Old 11-21-2012, 11:21 AM
Chain Breaker
im2fast2furious's Avatar
I bought a yec generator for my 08 r1 recently. Once I had it, I started to think about how a standard rotor could possible be modified to the same or even better for the road guy somewhere in between. I have been looking at 2 different ways of doing this both will mean machining the magnets. Just wondering has anyone ever tried this or heard of being done?
im2fast2furious is offline
post #20455 of 20628 (permalink) Old 11-21-2012, 03:16 PM
I'm totally guessing here....but I don't think you can machine magnets..can you?
Phantom Squadron CO
post #20456 of 20628 (permalink) Old 11-21-2012, 06:27 PM
BSR-1's Avatar
Probably possible but the magnets are what's generating the juice. I suspect that reducing the magnets will reduce the juice.
Also just a guess.
BSR-1 is offline
post #20457 of 20628 (permalink) Old 11-21-2012, 06:36 PM
I guess I'll also agree with your guess
Phantom Squadron CO
post #20458 of 20628 (permalink) Old 11-21-2012, 06:40 PM
BSR-1's Avatar
I'd say that's a good guess!
BSR-1 is offline
post #20459 of 20628 (permalink) Old 11-21-2012, 06:42 PM
Phantom Squadron CO
post #20460 of 20628 (permalink) Old 11-21-2012, 06:44 PM
BSR-1's Avatar
Kinda strange how we're the only ones left around here...
This used to be THE spot for any real info.
BSR-1 is offline
Headwork weekend project trottski Mechanical / Help 19 11-04-2008 02:54 PM
Winter project andyh Appearance & Mods 11 04-15-2007 01:37 PM
Winter Project 95% Done JspecZ R1 Appearance & Mods 23 03-02-2005 09:50 PM
Winter Project......... snorbitz General Motorcycle Discussions 8 01-29-2004 03:29 PM
So tell us...what your winter project will be? Maxxym General Motorcycle Discussions 23 09-27-2002 06:16 PM
