05 ignition removal ? - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 4 (permalink) Old 05-12-2007, 12:52 PM Thread Starter
Send a message via AIM to WilkR1 Send a message via Yahoo to WilkR1
any hints
WilkR1 is offline
post #2 of 4 (permalink) Old 05-12-2007, 03:00 PM
Wicked Clowns NEVER Die
ChainSmoker's Avatar
Disconnect the battery first.....What are trying to do? switch keys or do you have a coil problem throw me freaken bone here!
ChainSmoker is offline
post #3 of 4 (permalink) Old 05-13-2007, 02:35 PM Thread Starter
Broke My Key Off In It Just Trying To Get It Out Think I Have To Drill Some Safety Bolts Out.... ?
WilkR1 is offline
post #4 of 4 (permalink) Old 05-14-2007, 12:11 AM
Derka Derka Doit For The R1!
Curby's Avatar
It's not a very easy task, not at all, because of the bolts in there from factory, they tightent hem in, then the heads snap off, to prevent someone from swtiching ur ignition to ride off so easy. But mean while u can hot wire it in no time.
But neways best bet to do is to disconnect ur ignition from the wiring, take ur top tripple off, then buy a EZ-out drill bit, or something that can get into the bolt to get it out.
It's a PITA.
Curby
"I'd rather be sweating, instead of bleeding. Wear your gear!"
Curby is offline
04 R1 Ignition Module LOYZFR1 Mechanical / Help 65 01-19-2013 08:59 PM
Dynojet Ignition Module by Graves... Buckeyes7 General Motorcycle Discussions 1 03-27-2006 06:27 PM
Scorpio alarm ? ---- How to install the ignition disable? Count Porkula General Motorcycle Discussions 2 07-17-2005 08:08 PM
ignition switch removal clayjackson Mechanical / Help 4 11-19-2004 05:35 AM
Removal of Ignition Advancer rasta1096 Mechanical / Help 5 01-03-2003 09:43 AM
