Ignition Coil Help/Advice Needed - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 27 (permalink) Old 11-20-2012, 07:50 AM
burnin' up the streets
BSR-1's Avatar
Originally Posted by batman007 View Post
it opens and closes when key is turned.
It was just an Idea. the cables are adjusted properly? Not tight like a piano wire but snug.
I'm not much help on electrical problems, sorry.
I just want to stroke it all the time. (For you BSR
BSR-1 is offline
post #22 of 27 (permalink) Old 05-23-2015, 05:04 PM
This thread was super helpful and i just wanna thank everybody for the free helpful info.
r1jh is offline
post #23 of 27 (permalink) Old 07-16-2015, 04:46 PM
Just a newb on here!
Adrenaline416's Avatar
I'm having the exact same problem with my '07 R1. Just under 31k miles, I started it the other day and:
1) Sounds like a Ducati or V-Twin (louder, deeper sounding)
2) Strong smell of gasoline. I'm guessing it's because a cylinder isn't firing, just dumping fuel in and overflowing into the exhaust.
3) Rough idle, boggy and slow on the throttle.
4) Backfires a lot when decelerating with throttle closed (I only rode it once around the block once the trouble started, haven't ridden it since).
I pulled the coils and had them tested at the local Yamaha dealer. All tested ok, but the #2 coil had a small hole burned through the side of it, indicating that it's arcing. When I pulled the spark plugs, the #2 spark plug was coated with black liquid- either oil (hope not) or residual gasoline built up from not firing. I replaced the spark plugs and the problem was the same. I'll order a new coil and see if that solves it, then reply here.
Adrenaline416 is offline
post #24 of 27 (permalink) Old 07-16-2015, 05:56 PM
BSR-1's Avatar
Sounds like you're on the right track.
BSR-1 is offline
post #25 of 27 (permalink) Old 07-29-2015, 01:05 AM
I found a new coil on eBay for $57 including shipping. Installed it and the bike runs like new.
post #26 of 27 (permalink) Old 08-18-2015, 06:31 AM
Hi all - I have an 07 R1, having similar issues to both Paranoid and Adrenaline416 - however in addition to this the bike will often stall while I am running through traffic and at low revs (I suspect this may be temperature related to a degree).
The readings that I am getting from my coils are a bit opposite - on the primary resistance all 4 are out of spec (reading 2 Ohms) with the secondary measures all being nicely within spec.
I have just cleaned my air filter, 4 sparks are all iridiums in good nick, battery is less than 12 months old and holding charge well, oil changes on 6 monthly basis - clutch replaced about 18 months ago and new rotor about 12 months ago also. (generally a well maintained bike)
I am basically trying to narrow the issue down before shelling out for 4 new coils and would really welcome any advice etc.
Thanks in advance - Nooks
Nooks is offline
post #27 of 27 (permalink) Old 02-22-2017, 05:45 PM
I have a 99 R1 and blew the motor awhile back. Since then I bought another 2001 R1 that has been wrecked for the motor. I've switched the motors and got the bike to fire up. Problem is that I tried the next day and motor would turn but wouldn't start. It would back fire when I was done cranking the motor. And very loud at that. My coils I checked and primary reading is good, but secondary I don't get nothing. Maybe I'm doing it wrong. Any advice would be appreciated. Another thing. Fuel pump went out so I replaced it. So I put the new one in and it pressured up but the bike wouldn't fire up and number 4 cylinder filled up with gas. Advice to how I could fix that would be great also. Thanks
Joseph Flynn is offline
OEM ignition coil pack for 2000 R1 jmadcb7c Bikes For Sale 0 02-22-2007 08:33 PM
Ignition coil/spark plug How do I get to them? crazycatzracing Mechanical / Help 3 02-14-2006 06:08 AM
Need to locate Ignition coil wire CrewznR1 Mechanical / Help 7 06-29-2005 07:04 AM
02 Spark Plug/Ignition coil removal pr2300 Mechanical / Help 2 04-27-2005 07:01 AM
HELP!!Removing ignition coil on '03 crazyclimbr Mechanical / Help 1 01-30-2005 03:37 PM
