I took the tank off to clean the air filter. The tank was empty when I took it off. I put about gallon of gas back in to start it. I double check the gas line. It's got gas coming out.
Check your connections under the tank. Do you run a power commander?
Check to see if you have spark at the spark plugs. If you do not have spark on any of them then you probably have a wire disconnected somewhere. My guess would be your power commander plugs or tip over sensor plug.
Pull a plug out. Put it in the boot. Hold the plug end against any metal part of the engine. Try to start. You should see a spark.If you do not see a spark then you more than likely have a bad connection somewhere. I highly doubt all 4 plugs are defective or that all of your coils went out at the exact same time.
Check the power commander connections under the tank first. Make sure they are fully connected, the PC3 ground is still intact and the extra grey wire if you have it.
Check all of your fuses before you do anything. Might be something very simple.
Travel u r the f'ING man. It was that little grey wire (ground wire to the power commander) thank u. Connected the wire started right up. Thank u if u r going to indy for the motogp races. Look me up I'll buy the beer for the day
Too all I'll be there Thursday through sunday. Look me up to have a beer
