in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
R1 Related Discussion
Mechanical / Help
04-06 R1 Mechanical Help
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 194
Go to page
Go
194
Sticky
2004-2006 R1 Service Manual
Kevap
Feb 17, 2016
0
35K
Feb 17, 2016
by
Kevap
R
05 R1 loss in power acts like clutch is engaging
r1swoozky
2d ago
2
136
24h ago
by
MANOWAR
H
Need help finding a piece to my side fairing on a 2004 R1, pics attached
hwm
1d ago
1
66
1d ago
by
blackraizo
D
Blown trans?
Dannydadingo
3d ago
1
103
1d ago
by
Glassman76
T
My 06 r1 won’t start?
Tainyrrid
5d ago
4
233
2d ago
by
Tainyrrid
R
Are there any mods to lighten up the clutch pull on a 2006 R1
rconaway
Feb 24, 2024
5
374
3d ago
by
tigertim20
Battery help plz
DavidjR1
Jul 5, 2020
4
475
5d ago
by
Loose
S
2006 fuel pump question
Stickershock23
Jul 16, 2023
24
2K
6d ago
by
rbon.mpeg
Changing gears without clutch
CottonR1
Feb 27, 2024
11
165
Mar 9, 2024
by
andrewstclair
Looking for advice for my R1 2004. Please help
dlmedlam
Mar 7, 2024
4
246
Mar 9, 2024
by
andrewstclair
05 R1 exup motor installation
Cpt. Price
Mar 3, 2024
3
207
Mar 4, 2024
by
kkid
F
Starting problem?
feetboy17
Feb 22, 2024
1
143
Feb 23, 2024
by
bmahony1972
E
2006 R1 cranks but wont start
Elvsashagen
Feb 12, 2024
5
314
Feb 13, 2024
by
maximillianR198
Multiple oil/coolant Leaks
Cinnabar
Feb 9, 2024
1
190
Feb 11, 2024
by
Cinnabar
R
04 R1 Shows code 12 even after replacing the crank sensor?
R1Boi018
Feb 6, 2024
0
138
Feb 6, 2024
by
R1Boi018
OEM Electrical Connector Source
Smitty965
Oct 15, 2023
9
667
Feb 3, 2024
by
John K
M
Any of you fellows have a pinout for a 2005 cluster?
makenzie71
Jan 31, 2024
5
120
Feb 1, 2024
by
Numbers
Febur Radiator Mounting
topherchris
Jan 26, 2024
0
204
Jan 26, 2024
by
topherchris
R
05 R1 wiring problem
readyreadymate77
Jan 23, 2024
1
194
Jan 23, 2024
by
2muchbluE
R
2004 R1 Please tell me what this is?
Rackleyt
Jan 20, 2024
3
509
Jan 21, 2024
by
Kevap
Blown R1 engine rebuild help
AlanNY
May 18, 2022
26
11K
Jan 19, 2024
by
UPON_1
Oil leaking thru weep hole?
2004silverR1
Jan 4, 2022
13
9K
Jan 13, 2024
by
evan.khizkial
04-06 R1 Recommendations for replacement air filters?
maximillianR198
Jan 2, 2024
8
579
Jan 11, 2024
by
maximillianR198
04 r1 oil pump gear
stephenolinick35
Jan 11, 2024
0
101
Jan 11, 2024
by
stephenolinick35
H
04 R1 Won't Start
Hunterjames
Dec 27, 2023
5
324
Jan 5, 2024
by
siralfredthe4th_3265
J
Oil or coolant pipe ?
Jammy-R1
Jan 5, 2024
1
261
Jan 5, 2024
by
Numbers
F
yamaha r1 2005 error code 46
fda
Dec 26, 2023
4
488
Jan 2, 2024
by
Numbers
G
2005 R1 timing
glenshoults86
Dec 28, 2023
1
376
Dec 28, 2023
by
Numbers
S
2006 r1 seized starter motor
SageBanks
Dec 27, 2023
1
287
Dec 27, 2023
by
thwalker13
T
Does anyone know what this connector or sensor is?...
theegspot
Dec 19, 2023
5
61
Dec 20, 2023
by
theegspot
05 R1 Graves EXUP Servo Eliminator Installed... How To Prevent Code 18
Smitty965
Dec 16, 2023
1
239
Dec 19, 2023
by
Smitty965
K
2006 R1 which plates go in the clutch first?
Kularr04
Dec 10, 2023
2
382
Dec 14, 2023
by
Kularr04
P
2004 R1 not starting, tried most things
Pepe1249!
Dec 11, 2023
0
148
Dec 11, 2023
by
Pepe1249!
Fault Code 18 - EXUP Deleted w Graves Blockoff Plates, But Still Getting the Code
Smitty965
Dec 10, 2023
0
29
Dec 10, 2023
by
Smitty965
B
Spun Bearing, Can't find standard specifications for crank journals
Bent Iguana
Dec 8, 2023
0
176
Dec 8, 2023
by
Bent Iguana
04 R1 High idle
AlanNY
Sep 27, 2022
5
5K
Dec 7, 2023
by
ToxicRR1
1
1 of 194
Go to page
Go
194
49.3K
posts
16.4M
views
Mechanical and Critical Issues for the 04-06 R1
Show Less
Join Community
Grow Your Business
Forum Staff
View All
MANOWAR
Super Moderator
Skeeter
Super Moderator
Motorcycle.com
Moderator
Top Contributors this Month
View All
Loose
kkid
CottonR1
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Yamaha YZF-R7 Forum
2K+ members
Home
Forums
Mechanical / Help
