Hi everyone, my bike has a small motoroil leak on the front side ,it is when you look from the front side to the block left to the exhaust. the two parts of motorblock are fitted there together, there is no gasket between so you can't change it. my question is now has anyone used something called TORALIN ? you can put it together with the oil and is should stop the leak after running 15 minutes.
like to hear your reactions.
Is it leaking oil or coolant? If you have a hole in the engine that's leaking fluid...no additive is an appropriate solution. You'll either need to repair the block or head correctly or have it replaced. JBWeld is the only I would recommend but that's a band aid, and I wouldn't use it on a bike that revs out to 15k rpms on the regular.
Hi Onevrsix, Yes it is leaking oil and its not a hole but a very small leak,its the connection between the lower and upper part of the engine which gives the problems, Between those parts there is no gasket. i would like to place a picture but can't manage it. drag and drop seems not working.
