Wet Sump vs. Dry Sump - Yamaha R1 Forum: YZF-R1 Forums
Oil and Lubrication For discussion on oil and lubrication
  • 1 Post By partyman66
post #1 of 16 (permalink) Old 09-28-2009, 12:46 PM Thread Starter
Loudpipe's Avatar
Why are all modern sport bikes wet sump designs, as opposed to dry sump? Seems like dry sumps (which are used in high performance and racings cars) would be the more "stable" way to lubricate a high performance engine, especially one whose attitude (leaning left/right) changes quite a lot. Don't have to worry about the crank getting bogged down in the oil, or whipping it into a froth, thus creating a problem with oil pressure. Even my old CB750 had a dry sump system.
Loudpipe is offline
post #2 of 16 (permalink) Old 09-28-2009, 01:01 PM
iceman4357's Avatar
Send a message via AIM to iceman4357
...especially when they put the sump at the FRONT of the damn engine which can cause the engine to starve for oil.
2007 R1(black/gray)
A&R baffles
Akra Ypipe
BMC Race Filter
AK-20 Fork kit
Penske Double click
AIS blocked
PC3
Flash-Tune
Sintered Pads
more I cant remember
iceman4357 is offline
post #3 of 16 (permalink) Old 09-28-2009, 05:49 PM
turd1's Avatar
it probably involves cost and room/design.
turd1 is offline
post #4 of 16 (permalink) Old 09-28-2009, 06:14 PM Thread Starter
Loudpipe's Avatar
I don't think so. The MotoGP bikes use a wet sump as well, and cost isn't a problem for them. Gotta be another reason.
Loudpipe is offline
post #5 of 16 (permalink) Old 09-28-2009, 08:15 PM Thread Starter
Loudpipe's Avatar
Originally Posted by ProModR1 View Post
But MotoGP bike teams don't really have a budget.
That's the whole point. If a dy sump system is better, than surely a MotoGP bike would run it, regardless of cost.
Loudpipe is offline
post #6 of 16 (permalink) Old 10-02-2009, 10:01 AM
Squid
yankin&bankin's Avatar
ALL modern sport bikes DO NOT use wet-sump oiling, as you infer.
Most Aprilia motorcycles use dry-sump oiling, as well as the KTM Super Duke and 1190 RC-8.
Other sportbikes, the names of which you would recognize, use dry-sump oiling systems - I just can't think of any more examples right now.
I would agree with Blu that the reason is probably cost...the Japanese OEMs are trying to maintain a certain price point in their bikes as one of the ways to differentiate them from the European bikes.
A hallmark of Jap bikes has always been the ability to equal or exceed the performance of Euro bikes, at a lower price of admission. Part of the reason they are able to do this is by limiting unnecessary gadgets on the bikes (such as dry-sump oiling).
Yes, dry-sump offers some advantages, such as lower weight and consistent oiling in high-G cornering, but it's really not needed - these bikes do fine with wet-sump.
yankin&bankin is offline
post #7 of 16 (permalink) Old 10-02-2009, 12:01 PM Thread Starter
Loudpipe's Avatar
I know that not all modern sport bikes use wet-sump designs. That was a generalization.
I can only imagine that the Big Four have gotten wet-sump designs to be "good enough" where they don't think the added complexity of a dry sump is necessary. I still don't think cost is an issue in their decision, because the MotoGP bikes use a wet-sump design (unless the regulations require that and the manufacturers don't have a choice... I don't know).
Loudpipe is offline
post #8 of 16 (permalink) Old 10-02-2009, 12:54 PM
NeeD 4 SpeeD
sss r1's Avatar
motogp bikes use dry sump .
sss r1 is online now
post #9 of 16 (permalink) Old 10-02-2009, 01:40 PM Thread Starter
Loudpipe's Avatar
No, they don't. They're all wet sump.
Loudpipe is offline
post #10 of 16 (permalink) Old 10-02-2009, 02:08 PM
NeeD 4 SpeeD
sss r1's Avatar
ok , coz u said so
honda rcv :
"Another unique aspect of the engine was its semi-dry-sump oiling system; the crankshaft area is sealed off as a separate chamber, and a scavenge pump uses the transmission cavity as an oil reservoir. This setup offers numerous benefits over conventional wet- and dry-sump designs, including less pumping losses and blow-by into the combustion chamber, a more stable oil level and a stronger and more compact crankcase construction."
http://www.sportrider.com/features/0...11v/index.html
i think ducati is also dry sump , but i cant find it.
kawasaki , yami and suzuki are all wet sump , because they are using conventional il4 engine config.
conventional il4 engine is wide , so it must be installed high in the chasis (for ground clearance mainly) .this leaves lots of space and simplicity for regular wet sump.
all other engine configurations (v2,v4,v5) installed lower in the frame , so they use dry sump most of the time.
post #11 of 16 (permalink) Old 10-02-2009, 02:16 PM Thread Starter
Loudpipe's Avatar
ok , coz u said so
honda rcv :
So I'm right. Thanks for proving my point. Dry-sump is only used out of necessity (clearance), not because it's better in some way. Sounds like Honda is the only one that has a proprietary system, and even that is not strictly dry-sump.
Loudpipe is offline
post #12 of 16 (permalink) Old 10-02-2009, 02:32 PM
NeeD 4 SpeeD
sss r1's Avatar
also , motrcycles are a bit different fron cars . motorcycles lean into the turn , so , the oil wont move to the outer side of the engine .
if that was the case , motorcycle would never work good with carburetors.
take a carbed bike , lean it 45 deg while standing still , the engine will stall.
luckily , this doesnt happen when u ride
or , take a cup with water , hold it in your hand and spin around ...
now do the same thing , but lean the cup into the turning radius ... see what i mean?
post #13 of 16 (permalink) Old 10-02-2009, 02:37 PM Thread Starter
Loudpipe's Avatar
That's a good point. The oil probably doesn't slosh around quite as much as in a car because of the centripetal force.
Loudpipe is offline
post #14 of 16 (permalink) Old 12-18-2015, 01:35 PM
I think he was saying the opposite actually... that it doesn't slosh around as much in a bike because it's leaning in the turns so the sump (your cup) is being tilted as you lean (spin). Your oil (the water from the example) doesn't slosh around as much as it would in a car cornering just as hard because the car's sump maintains a more level pitch throughout that same turn and the oil will slosh more and be pulled to the sides of the sump by centrifugal force (not centripetal).
-2012 Yamaha R1 50th Aniv. Edition
-2007 Suzuki SV1000S
partyman66 is offline
post #15 of 16 (permalink) Old 12-18-2015, 03:46 PM
Crossed Up
Goatse's Avatar
You just argued an over 6 year old post.
Goatse is offline
post #16 of 16 (permalink) Old 12-18-2015, 04:04 PM
I do that every once in a whole for shuts and giggles and to dig up interesting old topics.
KaiserR1 likes this.
magnetic sump plugs? turd1 Mechanical / Help 1 12-02-2005 08:58 PM
Oil Pan / Sump jock1969 Mechanical / Help 1 09-07-2005 01:57 PM
How not to rethread your sump plug!! Se7enUK How To's 1 06-06-2005 12:33 PM
torque on sump...anybody know?? wozza Mechanical / Help 2 07-09-2003 05:10 AM
magnetic sump plug turd1 Mechanical / Help 6 01-08-2003 08:47 AM
