55 Wide Tires ? - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 156 (permalink) Old 07-04-2007, 09:48 AM Thread Starter
djfleming22's Avatar
55 Wide Tires ?
Hi there everybody, i was wondering if you could help me with a question i am wanting to fit 190 x 55 wide tires to 05 model R1 but heard that there may be issues over the width hitting off the frame and that you may have to adjust the chain, are there any views on this or any of you riding 55 tires with no adjustment.
djfleming22 is offline
post #2 of 156 (permalink) Old 07-04-2007, 09:59 AM
My R1 ate my Warrior.
Did_Have_Cars's Avatar
190/55 should fit just fine just fine :-)
55 is the aspect ratio referring to the tire's height in percentage proportion to the width...Basically saying that the tire is 190mm wide and 55% of 190 is the sidewall height.
Your stock tire is a 190/50, so the 190/55 is 5% taller.
Basically to make sure you'll be okay, look at the area where the tire comes closest to the U of the swingarm...If you have 1/3" to 1/2" of space, you should have no problems.
Did_Have_Cars is offline
post #3 of 156 (permalink) Old 07-04-2007, 10:01 AM
bryhart's Avatar
55 is the height . It's a percentage of the width (190).
As far as your question, sorry...I have no idea.
R1-015 `Ghostrider` Squadron
bryhart is offline
post #4 of 156 (permalink) Old 07-04-2007, 10:15 AM
on the 04 for bike shows when i threw the chrome rims on i had a 200 mounted on there..no problems..i would leave them on sometimes and ride with no issues
W8nonu is offline
post #5 of 156 (permalink) Old 07-04-2007, 10:21 AM
STRAIGHT ROADS SUCK!
R1 MASTER's Avatar
Assuming that everything in the driveline is stock, no adjustment is necessary. The 190/50 was one of the first things to go on my bike. As others have already mentioned, the 55 is not in reference to tire width.
Graves Smog Block Off Plates, Rear Fender Eliminator, Puig Windscreen (Dark Smoke), Pazzo Lever (Black w/Gold Adjusters: Long Clutch Short Brake), Shogun Slider Crash Kit, Speedohealer, Galfer Front Braided Brake Lines (Black), Progrip Handlebar Grips, Harris Tank Pad (Blue), Greggs Mirror Block Offs, CRG 2" Bar End Mirror, Watsen Flush Front LED Turnsignals.
R1 MASTER is offline
post #6 of 156 (permalink) Old 07-04-2007, 10:24 AM Thread Starter
Hi there thanks for some of the quotes i should have said the U of the swing arm my mistake some have said you need to go down the front sprocket which i do not want to do i as like the top speed that it has got again i know that 06 and onwards do not a have a problem as the swingarm was made longer in this model and that it might only be 04 and 05 that might have the problem many thanks
post #7 of 156 (permalink) Old 07-04-2007, 10:50 AM
Yamaha blue, in any color.
DanQ's Avatar
I know for the 190/60 all my friends run a 16 tooth front. The 16 tooth front may be a good mod anyway because of how steep first gear is. And with a 190/55 you'll be looking at a minor reduction of final drive. Wouldn't amount to more than a mph or two (plus these things are too dang fast to use top speed anyway).
As far as fit, you should be good. Close, but it shouldn't rub.
Dan
CCS #598
91 FZR 1000
04 YZF-R1
05 YZF-R6 (track bike)
04 Road Star Warrior
DanQ is offline
post #8 of 156 (permalink) Old 07-04-2007, 11:04 AM
so ur bud had zero problems mounting the 190/60/17 rear if so im planning on buying some but i wanted to make sure that i wouldnt have no probs with clearance!! im on a 04r1 and i also have 520 conversion kit "16" front.
R1-016 'Venom' Squadron the best Squadron
mad271r1 is offline
post #9 of 156 (permalink) Old 07-04-2007, 12:14 PM
Controlling the slide
schism's Avatar
Are you building a track bike?
schism is offline
post #10 of 156 (permalink) Old 07-04-2007, 01:40 PM
DanQ's Avatar
I have had several friends run the 190/60. I even bought a scuffed set, but never got around to mounting them. I run 180/55 Dunlop D220 for street/hiway use, and I just burned up a set of Dunlop 208 GPa's with a 180/55 rear at the convention. Stuck like glue (except for once... my bad, not the tires).
Like I said, if you run a 16 tooth sprocket, you will be fine with the 190/55.
Dan
CCS #598
91 FZR 1000
04 YZF-R1
DanQ is offline
post #11 of 156 (permalink) Old 07-05-2007, 09:04 AM
yea im gonna try the 190/60 not 55s guess if they dont fit ill sell them!!
mad271r1 is offline
post #12 of 156 (permalink) Old 07-05-2007, 09:30 AM
Skipper08's Avatar
here is a pic of my street bike with 190/55
btw you want to say 55 profile
ID:	299186   Click image for larger version
ID:	299187   Click image for larger version
AMA PRO SuperBike
Sponsors: SBK PRO Race Team, SOLOSON Import, MIN. deporte, Otalora Racing, Dainese, AGV, Leo Vince, Chicken Hawk Racing, RK Chains
Official site:
Facebook:
Skipper08 is offline
post #13 of 156 (permalink) Old 07-05-2007, 10:01 AM
no im going 60 profile Dunlop 209GP 190/60/17 i may have to add two lengths to the chain!!
mad271r1 is offline
post #14 of 156 (permalink) Old 07-05-2007, 10:11 AM
Skipper08's Avatar
thats cool the ones i have are sportmax 209GP, the new tire they came out with.
AMA PRO SuperBike
Official site:
Facebook:
post #15 of 156 (permalink) Old 07-05-2007, 10:30 AM
BiZ
BiZ's Avatar
Send a message via AIM to BiZ
dont mean to jack the thread, but I have a similiar question. I would like to mount a 200/50/17 rear tire on my "stock" R1. its a 2004.
Will I have issues with rubbing?
BiZ is offline
post #16 of 156 (permalink) Old 07-05-2007, 01:16 PM Thread Starter
wide
hi there again just to ask has anybody ever fitted a 190 x 55 to a r1 04 or 05 plate with changing sprockets or moving the chain
post #17 of 156 (permalink) Old 10-09-2007, 09:13 PM
bikefanatic's Avatar
another tire size question
so will a 190/60 make the bike turn faster or slower on my 07 R1, which came stock with 190/50's
bikefanatic is offline
post #18 of 156 (permalink) Old 10-09-2007, 09:31 PM
Premium Member
Jboat's Avatar
I remember when my friend tried to fit a 190/55 on an otherwise stock 05 R1, the tire rubbed the lower center of the swingarm...
I just switched from a 190/55, but I have a 16 tooth front sprocket and it was still pretty close...
Jboat is offline
post #19 of 156 (permalink) Old 10-09-2007, 09:34 PM
R1 MASTER's Avatar
It will improve "turn in". Not necessarily faster but easier. Unless you are down a tooth on the front it is going to be a tight fit. Make sure you have enough room for the added height.
Ride safe.
post #20 of 156 (permalink) Old 10-09-2007, 09:42 PM
I smoked U
punisher28's Avatar
Send a message via MSN to punisher28 Send a message via Yahoo to punisher28
it will be fine i run a 190 55
|R1-014 Dragon Squadron|#28
Covering: West/SW USA: CA, HI, NV, AZ,
punisher28 is offline
Wide boots! dmaxr1 Apparel 0 10-02-2007 05:09 AM
WTB 05-06 R1 with wide tire kit mac_z_28 Bikes/Parts Wanted 0 01-30-2007 11:43 AM
Wide wheel? Joemommas4 Appearance & Mods 3 11-07-2006 10:22 AM
It's 3am and I'm wide awake mkinla Off Topic Talk 5 07-30-2005 04:46 AM
