Graves R1 Garage - Page 4 - Yamaha R1 Forum: YZF-R1 Forums
Graves Motorsports AMA Championship Winning Motorcycle Exhausts and Accessories: Graves Motorsports
post #61 of 301 (permalink) Old 12-13-2009, 11:41 AM
Racer - WERA Expert # 125
kneedragger101's Avatar
Chuck, on the 2009 R1 that I plan to race I have full Ohlins, Marchesini a full Akrapovic. I am wondering what I can do next to get another 10-15 hp from the motor. YEC ecu? Cams? Cam timing? Head gaskets? If you had a couple g's what would you recommend?
Thanks in advance.
2009-2011 AMA Novice Twins SuperBike Champion
2013 WERA West Twins SuperBike Champion
"Do or do not, there is no try" - Yoda
kneedragger101 is offline
post #62 of 301 (permalink) Old 12-13-2009, 12:07 PM
Hope is what makes us Human.
Benocehcap's Avatar
I have a 2001 with a retrofit infiniti fx35 Bi-xenon projectors replacing the original headlights. Everything works great and it looks super nice. The only problem that i found is that when im running the projectors the battery is not charging at all. So what i do i ride the bike with the headlights off in the day. what can i do you to get more power to both systems?
thanks!
“Not every legend is a myth, some are flesh and blood. Some legends walk among us, but they aren’t born, they’re built. Legends are made from iron & sweat, mind and muscle, blood and vision and victory. Legends are champions, they grow, they win, they conquer"
Benocehcap is online now
post #63 of 301 (permalink) Old 12-13-2009, 09:23 PM
Thanks in advance.
Graves Cams 1600, Yec ECU with Graves Map 871.00, Graves Cylinder Head 1400 = 178 hp
Runs on Pump Gas , you will need the gaskets to assemble
www.gravesport.com
chuckgraves is offline
post #64 of 301 (permalink) Old 01-12-2010, 08:04 PM
thanks!
Try running only one light
www.gravesport.com
post #65 of 301 (permalink) Old 01-13-2010, 08:39 AM
OptimoPrime's Avatar
for the 09 is your low mount exhaust available as just a slip on? or is the entire header different from stock also??
OptimoPrime is offline
post #66 of 301 (permalink) Old 01-13-2010, 09:38 AM
Full system only.
www.gravesport.com
post #67 of 301 (permalink) Old 01-17-2010, 10:51 AM
Originally Posted by Graves 09 View Post
Got a tech question on your R1? We'll do our best to help out.
Get technical info from the Graves Motorsports Staff and Race team. Occasionally one our own Race Team mechanics will step in and take on tech questions that can only be answered by the pros.
Lets keep this thread strictly R1 tech and we will get some questions answered. I will also be adding some standard technical advice that is relative to Graves products and/or just plain fun to talk about.
Thanks, Taige
Graves Motorsports
Taige Webster
Phone (818)902-1942 ext 108
Fax (818)902-3821
taige@gravesport.com
http://www.gravesport.com
Hey guys,
I hope you can help. I have a 2004 R1 and I am looking for the some YEC performance parts specificly:
Flat Valve Set (5VY-A2100-70)
Gasket Head Cyl. (5VY-11181-70, 30 mm)
Gasket Cyl. (5VY-11351-80, 15 mm)
Any and All help would greatly be appreciated. Thanks in advance for your help.
CS
socalrz500 is offline
post #68 of 301 (permalink) Old 01-17-2010, 12:17 PM
Originally Posted by socalrz500 View Post
Hey guys,
CS
Yes we can help. Contact Weston@gravesport.com or http://works.gravesport.com he can get you what you need
www.gravesport.com
post #69 of 301 (permalink) Old 01-17-2010, 05:55 PM
X_Infantry
FOZZ's Avatar
You can still get old 04-06 R1 race kit parts Chuck ?
Thought they were nearly all gone ?
FOZZ is offline
post #70 of 301 (permalink) Old 01-26-2010, 08:45 PM
i've just been told through rumours that if getting the the low mount fort he 09's, you have to remove the whole system to change the oil... tru or false?
robertsoll is offline
post #71 of 301 (permalink) Old 01-28-2010, 06:13 PM
NESBA CR / WERA #811
811Racer's Avatar
Not true... However, you do have to remove headers 1 & 2. Trust me, its better to remove them! I also recommend putting a bag over the open exhaust pipe and secure with a rubber band.
I'm pretty sure this applies to all Graves exhaust, not just the low pro.
811Racer is offline
post #72 of 301 (permalink) Old 01-28-2010, 09:33 PM
next question then... and u might know 811 racer, how much time is involved in fitting/removing... i have no option now, parts are on their way... seems absolutely ridiculous!
post #73 of 301 (permalink) Old 01-28-2010, 11:44 PM
Beau, Garage Endeavors
It really sounds worse than it is. The pipes are spring mounted so it's just a matter of popping them off their tabs. They come off and fit back in place with minimal effort...
ffaspector is offline
post #74 of 301 (permalink) Old 01-30-2010, 07:14 PM
Go Slow... WHY??
ThinBlueR1's Avatar
Graves Y-Pipe ???
I know you guys at Graves sell a cat eliminator slip-on exhaust system. I have a 2007 R1 and already have Cat Back Slip-On System, I just need the y-pipe. Will you guys sell just the y-pipe.
If so, how much?
Thanks
ThinBlueR1 is offline
post #75 of 301 (permalink) Old 01-31-2010, 04:30 AM
thats a relief, last thing i would want is to be charged labour to r &r pip[es to do an oil change!
post #76 of 301 (permalink) Old 02-27-2010, 07:14 PM
TechnoPhiliac
adamsys's Avatar
Not the '07-'08 full Graves system. Just drop the plug and drain. Can't speak about the '09 version.
adamsys is offline
post #77 of 301 (permalink) Old 02-28-2010, 06:26 PM
YEC Reflash is awesome!
dystortdreality's Avatar
I have a full Graves system on my 07 R1 and was wondering if the tip that is inside the end cap was removable? Also what is it there for? To make it a little quieter? To increase back pressure for more mid range and torque? Some other reason? What will happen if I remove them?
dystortdreality is offline
post #78 of 301 (permalink) Old 02-28-2010, 06:56 PM
A guardrail ate my right leg..
R1Rider31's Avatar
I've got a PC3 with no map (for future use when I get slip-ons), Graves smog plates, Akrapovic y-pipe, and stock slip-ons (no racing baffle kit just bone stock). Do you disconnect the O2 sensor when using the smog plates? If so wouldn't you need to get a "canned" or a "custom" map to make up for the lack of the sniffer?
I'm sorry if this seems redundant. I've posted this in a few places and can't get any answers. It's not urgent as I've got my tank in the shop getting painted but I would like some kind of explanation. I've read contradicting info of people with similar mods running good and running poorly so I'm just trying to cover all bases before it gets good enough weather to ride.
Chris, R1-016 VENOM Squadron
^^^ That's what she used to look like before I downed her...
'07 R1 Charcoal Gray
Fair Weather Fan
R1Rider31 is offline
post #79 of 301 (permalink) Old 02-28-2010, 07:07 PM
I was told by Graves that if your bike runs good with it connected leave it. They said it only affects your mapping under 6000rpm if I recall and only under low load. If you punch it hard at any rpm the ecu uses the map and ignores the o2 sensor. Its basically for economy and emissions. I still have my o2 hooked up. I forgot to mention that I have smog block off plates also. My bike runs great.
post #80 of 301 (permalink) Old 02-28-2010, 07:20 PM
R1Rider31's Avatar
cool, that's more what I wanted to hear, definitely don't need any fuel problems when it comes time to ride out
Fair Weather Fan
Graves Full Exhaust Vs. Graves Slip-On w/V-Stacks lthrnwd98 Appearance & Mods 7 04-06-2007 08:53 AM
Graves exhaust & Graves stacks & PC3 USB vs stock vs other combos ciaka General Motorcycle Discussions 2 10-04-2006 11:40 PM
Just a few pictures from the Graves/Yamaha garage at Infineon. VPREATR Racers Corner 18 05-17-2004 08:56 PM
need a garage tidbit General Motorcycle Discussions 31 05-05-2004 04:22 PM
garage luckystar1 General Motorcycle Discussions 2 04-18-2004 02:05 PM
