Graves R1 Garage - Page 5 - Yamaha R1 Forum: YZF-R1 Forums
Graves Motorsports AMA Championship Winning Motorcycle Exhausts and Accessories: Graves Motorsports
post #81 of 301 (permalink) Old 03-01-2010, 04:40 PM
YEC Reflash is awesome!
dystortdreality's Avatar
Anybody have any idea on the question about the endcaps aon the previous page?
dystortdreality is offline
post #82 of 301 (permalink) Old 04-22-2010, 08:13 AM
seatec's Avatar
Originally Posted by Graves 09 View Post
The header design can defintely add some significant performance in all the right areas but unfortunately you cannot fit headers up to the cat eliminator system. the sizing and connection points are different. You would have to sell the CE and get a full. It is worth it if power is your main consideration. Thanks, taige
Why are these people advertisizng that you can upgrade to a full system?
http://www.indysuperbike.com/custome...t=35160&page=1
~2010 R1-Raven
seatec is offline
post #83 of 301 (permalink) Old 04-26-2010, 05:00 AM
seatec's Avatar
Guess graves is busy racing right now. lol Anyway, i just ordered the Graves Cat eliminator and hope it's as good as people say it is.
~2010 R1-Raven
seatec is offline
post #84 of 301 (permalink) Old 04-26-2010, 05:23 AM
martywhynot's Avatar
I wanna get one too,just not sure which one yet
martywhynot is offline
post #85 of 301 (permalink) Old 04-26-2010, 10:16 AM
That is correct.
The 2009-2010 Graves cat eliminator system allows you to purchase an up grade kit to a full system by purchasing headers.
www.gravesport.com
chuckgraves is offline
post #86 of 301 (permalink) Old 04-26-2010, 10:20 AM
seatec's Avatar
Originally Posted by Charles Graves View Post
That is correct.
Nice!. Thanks for the reply and kick a$$ in the AMA
~2010 R1-Raven
seatec is offline
post #87 of 301 (permalink) Old 04-26-2010, 11:13 AM
We install the director on the end cap for 2 reasons.
If a customer installs the system and the mapping is incorrect at small throttle openings and off gas, the likelihood that the exhaust gases will burn the tail sections is reduced by directing the pulse.
The sound is also reduced without a power loss.
www.gravesport.com
post #88 of 301 (permalink) Old 04-26-2010, 02:49 PM
If I decide I want to try taking them out can they be put back, or do I have to cut them to get them out? If I have to cut them I'm not doing it. Its hard to cut up a $2000 exhaust... Lol
post #89 of 301 (permalink) Old 04-26-2010, 03:27 PM
You will damage the end caps if you cut them out.
www.gravesport.com
post #90 of 301 (permalink) Old 04-27-2010, 08:40 PM
Updated Cam Chain Tensioner for 2009 R1
Hi ,
What have you guys been running for a cam chain tensioner and have you had any failures on the 2009 R1?I saw an offical tech update from Yamah that states a new one is in development but can get no answers for an eta.
Also , do you guys offer a PC V map for a jett tuning reflash ecu for your exhaust or stock ?
I have your frame sliders and fender eliminator , I,ove your products , I have never seen quality like this ever before in the industry , it's like everything you make was factory , amazing , keep up the good work.My bike has 700 miles and my next upgrade will be your full twin systen and PC V and ECU reflash , if you recceommend it.
Last question , do you know if I could run the Jett Tuning ECU reflash with stock exhaust and no fuel computer without running motor too lean and grenading it?
Thank you for everything!
Marky69 is offline
post #91 of 301 (permalink) Old 04-30-2010, 06:48 AM
seatec's Avatar
I put the Cat eliminator Graves on last night. NICE!!!! One thing though. Check engine light on. What could be the problem. Did a quick search but ZIP.
I have the 2010.
~2010 R1-Raven
seatec is offline
post #92 of 301 (permalink) Old 04-30-2010, 07:13 AM
tHE GODFATHER
SpidermanSS's Avatar
Send a message via AIM to SpidermanSS
Originally Posted by Marky69 View Post
Hi ,
We usually optimize the tuning with a power commander (and have a map for that alone) and then use the auto tune add-on to keep a/f correct.
www.gravesport.com
Twitter:
Instagram:
KILO 3483 : fastblueR1 : K_FleXXX : GLENN "ELVIS" : Gawarrior : Vman1300 : Bandrews
SpidermanSS is offline
post #93 of 301 (permalink) Old 04-30-2010, 12:38 PM
I have the 2010.
The stock lambda must be unplugged, correct?
Did you install a PC5?
www.gravesport.com
post #94 of 301 (permalink) Old 04-30-2010, 12:40 PM
seatec's Avatar
Stock what?? lambda? and no, havent installed a PC5
~2010 R1-Raven
seatec is offline
post #95 of 301 (permalink) Old 04-30-2010, 01:13 PM
If you installed the cat eliminator and did not reinstall the stock air fuel (lambda) sensor you will get an error code.
You should get the PC5 and the auto tune set up for your bike.
The PC5 will come with the error code eliminator for this.
If you like the way in runs now, you will be doing back flips if you install the PC5 with auto tune.
I use this set up on all my personal bikes. I installed it most recently on my WR250X after the pipe install WOW! The mapping will always be perfect with this set up.
www.gravesport.com
post #96 of 301 (permalink) Old 04-30-2010, 01:15 PM
seatec's Avatar
THanks for the tip. i did re install the stock sensor. will look into a PC5.
~2010 R1-Raven
seatec is offline
post #97 of 301 (permalink) Old 04-30-2010, 07:59 PM
Cct
Hey ,
You completely ignored the cam chain tensioner question , what do you guys use , a manual one or do you have an updated one?
Marky69 is offline
post #98 of 301 (permalink) Old 05-01-2010, 08:57 AM
seatec's Avatar
So your saying that we don't wknow hy my check engine light is on because i re-used my lambda and reinstalled it into the bung that came with the Cat Elim. Just to be clear. i never even uninstalled the 02 sensor. could it be becauser the sensor me have had a cable break?
~2010 R1-Raven
seatec is offline
post #99 of 301 (permalink) Old 05-01-2010, 05:54 PM
Warpig1's Avatar
Hey guys,
I have 2009 R1 and I have a full system + PCV on the way.
How does tuning the bike work with the 09 R1 having the "selectable throttle control maps?" Does the PCV eliminate that feature or can we load mutiple maps, or does it just work with one loaded map?
Thanks in advance!
Graves- good luck this season!
Warpig1 is offline
post #100 of 301 (permalink) Old 05-03-2010, 01:13 PM
seatec's Avatar
I figured out why the Check Engine light was on. I accidently pulled the ESD fuse when i thought it was a spare to use it for my fried Signal fuse when the rear brake light wire baked on the exhaust. it's all good now.
~2010 R1-Raven
seatec is offline
Graves Full Exhaust Vs. Graves Slip-On w/V-Stacks lthrnwd98 Appearance & Mods 7 04-06-2007 07:53 AM
Graves exhaust & Graves stacks & PC3 USB vs stock vs other combos ciaka General Motorcycle Discussions 2 10-04-2006 10:40 PM
Just a few pictures from the Graves/Yamaha garage at Infineon. VPREATR Racers Corner 18 05-17-2004 07:56 PM
need a garage tidbit General Motorcycle Discussions 31 05-05-2004 03:22 PM
garage luckystar1 General Motorcycle Discussions 2 04-18-2004 01:05 PM
