Yamaha R1 2012 - Yamaha R1 Forum: YZF-R1 Forums
 4Likes
  • 1 Post By esferato
  • 1 Post By Tad158
  • 1 Post By Tad158
post #1 of 16 (permalink) Old 03-18-2017, 02:52 AM Thread Starter
Yamaha R1 2012
hi guys,
anyone know how to change fuel consumptions settings on display to show L/100km instead of km/L?
esferato is offline
post #2 of 16 (permalink) Old 03-19-2017, 09:11 AM
gkamp's Avatar
Originally Posted by esferato View Post
hi guys,
I'd look at the manual, not sure if it's possible man
Sent from my A0001 using Tapatalk
gkamp is offline
post #3 of 16 (permalink) Old 03-19-2017, 01:38 PM Thread Starter
Problem solved. Need to hold select button
gkamp likes this.
esferato is offline
post #4 of 16 (permalink) Old 03-19-2017, 01:56 PM
gkamp's Avatar
Sweet, yeah ive set up my shift lights, that's about it
gkamp is offline
post #5 of 16 (permalink) Old 03-19-2017, 02:37 PM Thread Starter
Have another question. I bought this bike only 1 week ago. Noticed some rattle noise from clutch. Wehen you pull it only 40-50% you can hear rattle noise from clutch and after pulling 100% sound goes away after 1-2 seconds. It's normal or something wrong? I pull out cover and I see that ir not stock clutch but STM Slipper Clutch.
Name:	R1 Clutch.jpg
esferato is offline
post #6 of 16 (permalink) Old 03-19-2017, 03:05 PM
gkamp's Avatar
I asked the same question in the forum, a little rattle is normal.
gkamp is offline
post #7 of 16 (permalink) Old 03-19-2017, 10:39 PM Thread Starter
Sound totaly like in this video This is not 2012 R1 but still the same noise
gkamp likes this.
esferato is offline
post #8 of 16 (permalink) Old 03-20-2017, 08:13 AM Thread Starter
Here is another problem with starting. I got this only in a morning or if the bike stand a long ~10h without touch. And another video that stupid rattle sound can I start crying?
esferato is offline
post #9 of 16 (permalink) Old 03-20-2017, 04:20 PM
R1Gator's Avatar
I have a similar rattle with mine, I'm looking at going with a YEC upgrade kit, but the sound goes away after riding it for a bit as well if you can deal with it in the short term on warm up. Best of luck with regards to the start issue!
R1Gator is offline
post #10 of 16 (permalink) Old 03-20-2017, 09:04 PM Thread Starter
Look what I found under cover. STM Slipper clutch
Name:	R1 Clutch.jpg
esferato is offline
post #11 of 16 (permalink) Old 03-25-2017, 04:22 AM Thread Starter
New problems....As I mention before, have a problem on hard start in a morning. 3rd attempt and starts, after 30s it stalls! Error code 39 and 40. Turn ignition off/on start again with a little throttle and works fine. What could cause this?
esferato is offline
post #12 of 16 (permalink) Old 03-30-2017, 06:14 PM
https://www.youtube.com/watch?v=eX-7aohxh3o
How warm was the ambient temperature when this happened to you? My bike (Also a 50'th anniversary edition 2012) does this whenever it's below 50 degree F outside. It gets worse and harder to start the colder it is outside, until it's about 30-32 degrees out, at which point the bike will almost never start from a stone cold situation without killing the battery while trying to start it over and over again. I also have to give it throttle while cranking to get it to start when it's below 50 or it will pop and stall without ever catching idle. I have a Flashtune installed on my bike and have messed with all sorts of settings in there and none seem to make any difference with my cold starts.
-2012 Yamaha R1 50th Aniv. Edition
-2007 Suzuki SV1000S
partyman66 is offline
post #13 of 16 (permalink) Old 03-30-2017, 09:59 PM Thread Starter
On Sunday, will be around 65-70F. Will try again but still have stall issues. Look at videos. When it's temp around 180F++ you almost can't feel anything. I can't do power wheelie on 1st gear below 9000RPM and it's easy when over 10k maybe it's normal for these R1's? 2nd video when I very quick turn throttle you can see a little lagging and after 5k RPM it's jumps normally.
esferato is offline
post #14 of 16 (permalink) Old 03-31-2017, 05:05 AM
Astronomer not Astrologer
Tad158's Avatar
What ECU image do you have in the bike? What mods have you done? You have a European bike right? Where do you live? Have you checked the TPS and APS sensors in diagnostic mode?
You shouldn't rev a bike when it is still cold and when the dash still says Lo for the coolant temp.
gkamp likes this.
#158
2009 Raven R1
Tad158 is offline
post #15 of 16 (permalink) Old 03-31-2017, 05:18 AM Thread Starter
I get this bike from Italy. Full Akrapovic exhaust, Smog OFF Plates, quick shifter and worst thing that I don't know what kind of ECU image is in. Living in Lithuania, +13'' Celsius outside. Checked TPS+APS seems to ok. European model, noticed that immobilizer flash not flashing
esferato is offline
post #16 of 16 (permalink) Old 03-31-2017, 05:19 AM
Tad158's Avatar
Put my image in it...
gkamp likes this.
#158
2009 Raven R1
Tad158 is offline
