Ok so I have been reading multiple forums on the site and have replaced and attempted almost everything I have read about and still stalls when 1st Gear is engaged. Here we go:
History: Purchased the bike from a guy who bought it from another guy yada yada yada..apparently someone tried to steal it and wiped out pretty much breaking most of the fairings, bars..ignition switch etc. I have attached an image of what the bike looked like when I got it.
I have pretty much replaced everything from auctions and new parts (OEM) minus the ignition switch. The first issue I had was I ordered an aftermarket ignition switch with a key and had an orange wire left over. The bike started with no issues but had not attempted to drive it. Ran a Diag and 1 code appeared related to the air temp sensor (22).
So i have completely assembled it and the bike stalls when 1st gear is engaged. I replaced clutch switch (New) below lever, bypassed kickstand switch, then ended up purchasing an OEM (New), and still stalls. Neutral light is on when in neutral and comes off when in gear and also stalls. If I attempt to start it in gear while squeezing clutch it won't start at all. A local guy (El Paso TX) said I needed to replace Neutral Switch, another guy said I needed to replace the clutch. I mounted the bike to see if it would spin in 1st gear and wheel is very tough to rotate so I know the clutch is still good. Before I send it to the shop, which are crap here (Lies, Lies, Lies) maybe someone can help.
Any responses can be replied to here or emailed to friendsandhotrods@yahoo.com
Thanks in Advance
Thanks in Advance
