How much sprocket wobble is too much? - Yamaha R1 Forum: YZF-R1 Forums
 26Likes
post #1 of 157 (permalink) Old 06-12-2017, 05:08 PM Thread Starter
gkamp's Avatar
So just replaced the sprockets and chain and the rear sprocket has a wobble to it... Worried about it, I occasionally feel a a light impact sensation or something thru my foot pegs, not sure if I'm being paranoid because my old chain and sprockets where worn pretty bad and appeared to have rubbing on the inside of the plate of the chain.. see attached for video of new sprocket. Things I've checked, torque of the sprocket bolts and alignment and torque of the rear axle.
gkamp is online now
post #2 of 157 (permalink) Old 06-12-2017, 05:15 PM
iamzombie's Avatar
Christ, is it bent or is your axle horribly out of adjustment? That does not look normal to me.
iamzombie is online now
post #3 of 157 (permalink) Old 06-12-2017, 05:20 PM
How many miles. Looks to me like it's time to replace all bearings' Cush drive and axle. Don't **** around.
Thejman1000 is offline
post #4 of 157 (permalink) Old 06-12-2017, 05:22 PM Thread Starter
gkamp's Avatar
:/ dang
gkamp is online now
post #5 of 157 (permalink) Old 06-12-2017, 05:23 PM Thread Starter
gkamp's Avatar
14.5k... it's my daily don't even really hot rod it... Don't feel any play when I grab the tire and try to move it...
gkamp is online now
post #6 of 157 (permalink) Old 06-12-2017, 05:25 PM Thread Starter
gkamp's Avatar
Originally Posted by gkamp View Post
:/ dang
Axle alignment
gkamp is online now
post #7 of 157 (permalink) Old 06-12-2017, 05:40 PM
It only takes a little play. I personally would replace all the bearings their pretty cheap. Check the Cush drive peices.
post #8 of 157 (permalink) Old 06-12-2017, 05:42 PM Thread Starter
gkamp's Avatar
Are they pressed in? Yeah I was just looking at bearings.... Can't believe bearings would go out so early...
gkamp is online now
post #9 of 157 (permalink) Old 06-12-2017, 05:42 PM
Axle alignment
Even if the axle was out it wouldn't do that. You would notice a horrible chain noise if it was badly out of wack. Have you hit any pot holes?
You could also have a rim problem
post #10 of 157 (permalink) Old 06-12-2017, 05:44 PM Thread Starter
gkamp's Avatar
I mean not anymore than normal riding in the city... Nothing that I recall that was like damn that was hard.... 😟
gkamp is online now
post #11 of 157 (permalink) Old 06-12-2017, 05:45 PM
Yes. You can bang the old ones out if you don't have a tool. Install new ones with a large threaded rod and some washers and nuts if you don't have a tool. I've seen them fail much earlier than that. Do you use a torq wrench when tightening??
post #12 of 157 (permalink) Old 06-12-2017, 05:45 PM
Never too old to let 'er rip
Rainey fan's Avatar
An axle not being aligned properly just means the rear sprocket is not on the same plane as the front sprocket. It would have nothing to do with causing a wobble. Something's not right there.
gkamp and mhuber like this.
Rainey fan is offline
post #13 of 157 (permalink) Old 06-12-2017, 05:47 PM
Replace all things. If money is an issue check each part one by one. Start with the axle. But I doubt it's that.
post #14 of 157 (permalink) Old 06-12-2017, 05:48 PM Thread Starter
gkamp's Avatar
Yes I always torque the rear axle nut with a torque wrench.. wow failing less than 14k... Had ~60k on my zx6rr never once touched bearings 😟.
gkamp is online now
post #15 of 157 (permalink) Old 06-12-2017, 05:48 PM
Chillin'
One2's Avatar
Doesn't look like the tire is wobbling.
I'm sure it's just the sprocket.
Remove it and lay it on a flat surface it's what I would do.
Could also be a cush drive or carrier issue.
iamzombie and mhuber like this.
One2 is online now
post #16 of 157 (permalink) Old 06-12-2017, 05:50 PM
Looking at you video several more times I'm gonna have to say Cush drive inserts and the bearing in the sprocket carrier.
post #17 of 157 (permalink) Old 06-12-2017, 05:51 PM
Bzzzzzzzzzzzzzzzzzzzzzzzzz....off...lol
post #18 of 157 (permalink) Old 06-12-2017, 05:51 PM Thread Starter
gkamp's Avatar
I'll pull it apart and look, anything that can be visually inspected?
gkamp is online now
post #19 of 157 (permalink) Old 06-12-2017, 05:52 PM
Chillin'
One2's Avatar
gkamp likes this.
One2 is online now
post #20 of 157 (permalink) Old 06-12-2017, 05:53 PM
Most of the time they fail due to heat. Just curious do you do any stoppies??
