Front End Shake - Help - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 10 (permalink) Old 05-16-2012, 03:48 PM Thread Starter
blessed
Ruffnery's Avatar
Hello all. I have a 2004 R1, 5000 miles on it. I recently purchased the unit, and it has an issue. It still has the crappy factory tires on it, so i think thats probably my issue, but just in case. Just ordered pilot Powers for front and rear. Any Ways ..... if I am at any speed (30mph or greater) and let off of the handle bars just a little bit, the front end goes in to a small wobble. I noticed it on a ride when I was at 60 mph and sat up a bit releasing my grip on the bars and it started to wobble. Today I was riding and let off the bars at 30 and kinda taped the bars and it started to wobble. I can not feel any shake in the front end as long as I have a good grip on it. Any suggestions??
Thanks!!
Ruffnery is offline
post #2 of 10 (permalink) Old 05-16-2012, 04:10 PM
My R1 go to warp drive
Sabotage's Avatar
Steering stem bolt loose or bearing bad.. Most likely loose stem bolt, tighten it.
PCV tuned, Bazzaz QS, Air box mod, BMC Filter, Block off plates, Flashed ECU, -1 Front Sprocket, SpeedoDRD, Spiegler Lines, EBC Extreme Pro pads, Braking SK Rotors, Q3's, Leo Vince Carbon Fiber slip-on W/ Y-Pipe, Black and Gold Euro conversion, 10,000k HID, Brembo MC and clutch perch, Smoke Puig Windscreen, Shogun Frame Sliders, Signal mirrors, Harris rearset, Techtronic auto blipper, EK 3D 520 chain conversion, Ohlins 30mm ctrg & TTX shock, Lightech chain adjuster, CF sbk hugger, TI bolts kit
Sabotage is offline
post #3 of 10 (permalink) Old 05-16-2012, 04:18 PM
Moving sucks...
Moonlighter's Avatar
I've had the same issue, fixed with new tires...
Moonlighter is offline
post #4 of 10 (permalink) Old 05-16-2012, 04:21 PM
damn turkeys
Send a message via AIM to rorytsm Send a message via Yahoo to rorytsm
tire weights or tires would be my guess
rorytsm is offline
post #5 of 10 (permalink) Old 05-16-2012, 04:30 PM
para bellum
Kangaroo's Avatar
lift the front end and spin the wheel. Check for tire carcass warping. Also mark where it stops. Then spin again. Your tires might be out of balance.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline
post #6 of 10 (permalink) Old 05-16-2012, 05:39 PM
The south roads are best roads
BeaverPuncher's Avatar
Go faster
BeaverPuncher is offline
post #7 of 10 (permalink) Old 05-29-2012, 08:14 PM Thread Starter
blessed
Ruffnery's Avatar
Hey everyone, put on the pilot powers and no more shake. Thanks all. It was just tires.
Sent from my Desire HD using Motorcycle.com Free App
Ruffnery is offline
post #8 of 10 (permalink) Old 05-29-2012, 09:35 PM
damn turkeys
glad it was an easy fix for you
rorytsm is offline
post #9 of 10 (permalink) Old 05-30-2012, 10:06 AM
Hate 2 Lose's Avatar
+1
Hate 2 Lose is offline
post #10 of 10 (permalink) Old 05-30-2012, 12:22 PM
RLTW!
Lance C's Avatar
Glad you got this resolved. I had the same issue, after coming back from deployment. Tire was warped from sitting too long off of stands.
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats."- Henry Louis Mencken (1880-1956)
04 R1 RED
-Yoshimura TRS Carbon Fiber Slip-on
-Gutted Cat
-DynoJet PCIII
-Graves V-Stacks
-Flush mount signals
-Integrated Taillight
-Fender Eliminator
-Ohlins Rear Shock
-CRG GP Clutch
-SATO Rearsets
R1-011 WolfPack
Lance C is offline
Front end shake savage10308 Tire Tech Forum 1 06-05-2011 08:39 PM
Front end shake spectre1 Mechanical / Help 8 10-09-2005 02:22 AM
Front end shake Kenny S Mechanical / Help 6 07-03-2004 09:58 PM
front end shake rabid wombat Mechanical / Help 7 04-25-2003 09:30 PM
front end shake 8ballbilly General Motorcycle Discussions 2 04-12-2002 06:22 PM
