What kind of power does the Graves Monster R1 make? - Page 3 - Yamaha R1 Forum: YZF-R1 Forums
post #41 of 59 (permalink) Old 11-07-2012, 07:13 PM
Originally Posted by Aron213 ti View Post
actually, in motor design, the hotter the cylinder temps get, the more power you make up till you start to melt things, then it becomes bad, what you want is colder air, cold air is dense air, the more air you can get into a motor, the more power you make.
yes, i agree.. all i meant is the crossplane runs hot... needs better RAD to get the most performance out of it...
post #42 of 59 (permalink) Old 11-07-2012, 07:20 PM
Originally Posted by Cerbyr1 View Post
i only just had head work done to my r1 and have gained about 10bhp but the biggest improvement is in how much faster the bike revs (so even with similar power it develops it over a shorter period of time) but also a really good dyno tuno. with the new tune the biggest difference isnt the top end but, how early and hard i can twist the throttle out of the corners. the increased pick up off 0 throttle is staggering compared to stock.
great to hear.! i'm looking to have some work done in a year or so.. after i've put some real miles on the stock engine... i was hoping i'd be looking at 170ish rwhp... currently at 161hp with just a flash and custom tune.. though i'm running conservatively, keep reliability high for many years to come..
post #43 of 59 (permalink) Old 11-12-2012, 08:25 AM
tHE GODFATHER
SpidermanSS's Avatar
Send a message via AIM to SpidermanSS
There is soooooooooo many variables that go into building an engine, mainly who’s building it and there REAL experience in working with the parts. We offer such services (engine builds, full turnkey superbikes, Daytona sportbikes etc) and we know they aren't cheap. The level of meticulous detail and time we put into things is astonishing. Reference the original question it cannot be answered but there are transparent things we offer that can make real world horsepower... We ( Graves Motorsports ) offer some great products and how those products can be used in the real world are what we specialize in. I always tend to shy away from threads requesting specific things as they tend to turn into "prove it" user ego boosting posts that go nowhere. Gains in power also need to be translated into the power under the curve (top number) a lot of time. Fat midrange when and where you need it is usually what you really want. So here is some general information that is extremely informative. - Shane
These links will be for the 09-13 R1... See our site for specific parts for other year bikes. http://www.gravesport.com/R1-2009-2010.html
Our exhaust systems will show dyno charts with the exception of the non-street Superbike version. The tubing sizing and modifications needed to mount it make it not acceptable for a street bike. A full dual can (under tail) Graves exhaust system will reward you 11-13 HP gains over stock when tuned with a proper devise (we recommend a power commander PC5, secondary fuel model and an auto tuner from dynojet).
http://www.gravesport.com/Dynojet-Ya...PC5-09-10.html
http://www.gravesport.com/Dynojet-Au...mmander-V.html
http://www.gravesport.com/Power-Comm...ule-R1-R6.html
Our intake and exhaust camshaft set shows consistent gains additionally of 5-7 hp .. http://www.gravesport.com/Graves-Mot...Set-09-10.html
Exhaust Systems. Here is a side note of knowledge: Add a kit ecu (not for the street, our top and bottom velocity stacks and the superbike exhaust and set up to 25 hp gains.
Our heads are built to order http://www.gravesport.com/Graves-Mot...-R1-Heads.html combined with the 25 hp gain setup above and appropriate higher compression gaskets there should be an additional 10 hp found for 35 hp gains.
Other products you will need.... Smog blog off plates, higher bar radiator cap, possibly better plugs, our works clutch fix kits and springs..
http://www.gravesport.com/Graves-Mot...ort-Bikes.html
http://www.gravesport.com/Works-Bar-Radiator-Cap.html
http://www.gravesport.com/YEC-Yamaha...-Plug-Set.html
http://www.gravesport.com/Graves-Mot...lutch-Kit.html
http://www.gravesport.com/Yamaha-R1-...h-Springs.html
Lastly I'll touch on the cooling system... With big power comes greater cooling responsibilities so be sure to address these things through radiator mods and other methods... If you race our WORKS programs contain bodywork sets that have improved flow air tubes.
www.gravesport.com / www.r1-forum.com / www.r6-forum.com/ Graves Racing Services
Twitter: @SpidermanSS / @Gravesport
Instagram: @SpidermanSS / @Gravesport
KILO 3483 : fastblueR1 : K_FleXXX : GLENN "ELVIS" : Gawarrior : Vman1300 : Bandrews
SpidermanSS is offline
post #44 of 59 (permalink) Old 11-12-2012, 12:13 PM
Aron213 ti's Avatar
Originally Posted by SpidermanSS View Post
Fat midrange .
Sounds like you're describing Frank
http://img.photobucket.com/albums/v347/Aron213/Image3-1_zpsab24bb95.jpg
Aron213 ti is offline
post #45 of 59 (permalink) Old 11-12-2012, 01:12 PM
CupraR1's Avatar
190 bhp top poss 180/185 at the wheel
CupraR1 is offline
post #46 of 59 (permalink) Old 11-12-2012, 01:20 PM
burn-z's Avatar
I was told from a reliable first hand source mid 180's at the rear wheel...184-186hp on a good day.
Sig courtesy of Petrol Spice
burn-z is offline
post #47 of 59 (permalink) Old 11-12-2012, 01:25 PM
CupraR1's Avatar
if you read it thats what I said??
CupraR1 is offline
post #48 of 59 (permalink) Old 11-12-2012, 01:29 PM
burn-z's Avatar
That's exactly what I said. I was agreeing with you.
burn-z is offline
post #49 of 59 (permalink) Old 11-12-2012, 01:32 PM
CupraR1's Avatar
It was the lol
CupraR1 is offline
post #50 of 59 (permalink) Old 11-12-2012, 01:48 PM
CupraR1's Avatar
So 195+bhp is achievable from these engines?? With bolt on goodies
CupraR1 is offline
post #51 of 59 (permalink) Old 11-12-2012, 02:10 PM
tHE GODFATHER
Please read what was posted it's accurate... The R1 most of the time baselines at 145... I don't think heads, gaskets or modding radiators defines "bolt on" hardware... but to some people it might..
Good luck with your project...
post #52 of 59 (permalink) Old 11-12-2012, 02:38 PM
CupraR1's Avatar
Hi. Not being arsey but genuinely would like to know? My meaning of bolt on means exactly as it says “bolt on” does not needs skimming/machining etc. it just bolts on and this would deliver 145 baseline + 35 180 bhp at the wheel?
Steve
PS project going well
CupraR1 is offline
post #53 of 59 (permalink) Old 11-12-2012, 02:56 PM
burn-z's Avatar
Steve
185 at wheel with a full sbk engine build and $50k in electronics. You'll also need a full time guy to interpret data and program electronics.
I have a $3400 Akra Evo kit exhaust, PCV, block offs, Jett Tuning flashed ecu, airbox mod and bmc filter and I'm getting 157 peak hp. Stacks probably wouldn't help much without necessary head work and race rad. I'd say 160 is about max for bolt on mods. I'd love to get my bike dyno'd on one of those dynos people are claiming they got 165-170 with some slip-ons and a fuel controller. I'd probably be pulling 180-185 myself then.
burn-z is offline
post #54 of 59 (permalink) Old 11-12-2012, 04:03 PM
The Lead Farmer
Meister37's Avatar
Barrel chested Freedom fighter midrange.
Kirk is a total dick.
Meister37 is offline
post #55 of 59 (permalink) Old 11-12-2012, 04:13 PM
The Lead Farmer
Meister37's Avatar
Steve
It's just a number. Think of it this way: If I tell you my truck will do 200 MPH, will it impress you? Yes. What I'm not telling you is that I have to drop it out of a C130 to get it to go that fast. Like shane said, useable HP is far more important than a peaky 2 stroke like top end hit. If that's what you like, the 08 might be what you want. Many here have been on the track with me on my 08 and know it's stupid fast on the straights but needs to be in the right spot in the power band to beat the current model out of the corners without spinning the rear tire up too badly. It's all subjective.
I've seen too many happy dyno numbers in my time. There was one guy in Georgia who dropped the weight of his drum to make customers happy.
You can only go so far before it's money down the drain with very little $ to HP gain. You may have to stack 10k and some reliability to get the last 7 HP available in the motor with the stock bore. I'm willing to bet Graves only gets 3-4 races out of a motor before they freshen it up. That monster (Pun Intended) midrange requires and expert hand or electronics to tame it. HP is capable of two things, making you go super fast down the straights, or setting you on your head. How much time do you really spend at 100% throttle on the track? Not nearly as much as you think.
post #56 of 59 (permalink) Old 11-13-2012, 09:28 PM
V4 addict
Oz_R1's Avatar
Properly ducted race fairings will do wonders before touching the plumbing
Oz_R1 is offline
post #57 of 59 (permalink) Old 03-17-2013, 03:25 PM
missed the followup on this thread... yes I gotta agree somewhat with you Chris, Nels got me 158.5rwhp with just LV 3/4 system, pcV, smog plates, Ecunleashed, stock air box, stock air filter..
so after the air box is done and auto-tune cleans it all up i'm looking at ~160rwhp
the thing is when you see huge numbers you gotta wonder if this is at the upper range of performance from said engine...
Nels backed off 5% from what I could have had... because my bike is a street bike, and demands reliability when touring...
post #58 of 59 (permalink) Old 03-17-2013, 03:59 PM
Gearheaded's Avatar
I will be running mine on the Dyno here in the next few weeks, and im not ashamed to post up low numbers if they are.
so far my bike was on a trailer dyno at a local bike night a few months ago and with a race filter, leo 3/4 exhaust, flash tune (restrictions removed) and some 93 octane it made 147rwhp. On the same dyno a brand new panigale made 154rwhp, and a 2012 s100rr made 164rwhp.
now ive switched to a graves low mount system, added a bazzaz ZFI and auto tuner, and here in the next few day ill be adding the radiator add-on. than Ill dyno it again and see how she does. today I took the bike out and uses the bazzaz to tune, and my a/f was way off from the flash tune. the auto tuner wanted to add almost 20% in some spots, and take 20% in others. im curious what gains ill get with the new bazzaz and low mount system.
either way, so far its put down 147 wheel HP, and hurt egos at long straights in Daytona on the banking and the 1/4mi straight at my local track, so I cant complain
Whoody whoody woo!
You pecker head....
R1-016 Venom Squadron
Gearheaded is offline
post #59 of 59 (permalink) Old 03-17-2013, 06:10 PM
OptimoPrime's Avatar
I have 3/4 exhaust, pcv, flash tune, air box mod, stock filter and I make 165 by very reputable tuner I have pic of Dyno sheet but I'm in car on my way back from daytona
1983 yamaha xj550 (SOLD)
1995 kawasaki gpz1100 (engine fail)
2006 suzuki gsxr600 (sold)
1981 yamaha xs450 (sold)
2003 honda superhawk 996 (Sold)
2001 suzuki TL1000r (sold)
2009 yamaha r1 (33k engine overheats SOLD)
2013 bmw s1000rr
OptimoPrime is offline
Monster Graves Yamaha Hayes / Herrin Mid Ohio Video SpidermanSS General Motorcycle Discussions 7 07-20-2012 08:30 PM
Monster Energy Graves Yamaha Infineon AMA Race Pictures SpidermanSS General Motorcycle Discussions 18 05-17-2011 01:50 PM
Monster Energy - Graves Motorsports - Yamaha Champ Josh Hayes Visits Dealership SpidermanSS Main Page News Topics 3 05-07-2011 07:09 PM
Looking for ideas to make my black 03 R1 in to monster edition only_nashi General Motorcycle Discussions 4 03-29-2011 05:01 PM
Why does Team Monster Energy - Graves Motorsports - Yamaha's Josh Hayes Ride? SpidermanSS General Motorcycle Discussions 8 03-03-2011 08:57 PM
