07 tip over sensor resistance? - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 3 (permalink) Old 11-12-2012, 07:53 PM Thread Starter
Alright guys so I have a question for all I have lost my lean sensor or tip over sensor so what I'm asking is for somebody with a voltmeter to go check there's and see what the resistance is so I can build a resistor block because I don't even have my connector anymore thanks in advance to whoever can give me this information
Sent from my SPH-D710 using Motorcycle.com Free App
nelsonsi04 is offline
post #2 of 3 (permalink) Old 11-13-2012, 06:36 PM Thread Starter
Nothing?? please some one help
post #3 of 3 (permalink) Old 11-14-2012, 04:36 PM
HKr1's Avatar
It's not a resistor block.... Has a small circuit board in there.
Blue wire +5v
Yellow/Green is signal to ecm. .4-1.4v is up right. / 3.7-4.4v is tipped over.
Black/Blue is Ground.
Make something that takes the 5 volts to .4-1.4 volts, should be good to go. (can check that in diag too)
Simple voltage divider should work. 10K & 2K resistor should give ya .83volts.
Play here:
http://www.wb5rvz.com/sdr/common/voltage_divider.htm
Name:	lean angle.jpg
HKr1 is offline
