What it's like to ride my 06... - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 57 (permalink) Old 12-13-2012, 04:34 AM
Señor Citizen
Dude, I got tin in my arm and my leg and it's not as impressive as that!
Petrol_Spice is offline
post #22 of 57 (permalink) Old 12-13-2012, 04:35 AM Thread Starter
Screw you guys....
CARBONAR1 is offline
post #23 of 57 (permalink) Old 12-13-2012, 04:36 AM Thread Starter
Go on then...It's my thread...lets go off topic.
post #24 of 57 (permalink) Old 12-13-2012, 04:37 AM
Señor Citizen
What's the x-ray of the hips for?
post #25 of 57 (permalink) Old 12-13-2012, 04:40 AM
BrnEyzR1's Avatar
Love your write up Ben!
Your xrays on the other hand
"The reason I do it is because if you do it wrong, it will kill you. If you think it's too dangerous then go home and cut your lawn and leave us to it"
~ Guy Martin
It's my fault.
Miss you Pierre
Much love Andre
58
BrnEyzR1 is offline
post #26 of 57 (permalink) Old 12-13-2012, 04:42 AM Thread Starter
Open book fracture...no metal, but the bones at the front should be connected by cartiledge!
post #27 of 57 (permalink) Old 12-13-2012, 04:44 AM Thread Starter
Cheers Kimbo...love your avatar.
While I'm showing off...here's the spec list that got the mag intersted in the first place...
Ported and polished head
Reshaped combustion chambers
Kent Performance Race camshafts
Skimmed cylinder block
YEC hi comp gasket
STM EVO slipper clutch
Graves velocity stacks
Akrapovic Ti Evo full system
Akrapovic slash cut CF mufflers, shortened 50mm
BMC race air filter
K&N oil filter
S.B.P. custom dyno tune and map
Removed/bypassed air induction system
Robby Moto Eng. quick action throttle
Bora SBK race radiator, with OEM fans fitted
SFS sillicone coolant hoses
Custom radiator guard
Rizoma oil filler cap
Ti magnetic sump plug
ATF anti slosh tank foam
ELECTRICS
YEC race kit ECU
Dynojet PC III usb
Translogic quickshifter
Shorai lithium battery
Translogic digital race dash
Custom manual fan switch
Magical Racing carbon indicators
Graves exup eliminator
Accumen LED flasher relay
Custom twin projector headlight
A&R 4300K HID kit with LED parker light
Narva 4300K high beam
Narva 90db forklift beeper
SUSPENSION & CHASSIS
Ohlins FG43 road & track forks
Ohlins .95kg springs
Ohlins SBK fork internals upgrade
Slingshot Racing prelaod adjusters
Ohlins steering damper
Robby Moto Eng. damper clamp
Woodcraft clip on clamps
MW carbon fibre handelbars
Robby Moto Eng. ergal adj. offset triple clamps
Evotech top yoke nut
CRG supersport clutch perch and lever
Renthal soft grips
Ebay rubber frame plugs
GYTR delrin frame protectors
Agras engine case protectors
Sato Racing rearset footpegs
Custom superbike style braced swingarm
Ohlins twin speed shock w. hydraulic preload adj.
Graves superstock shock revalve
Ohlins .95kg spring
Renthal/Driven sprockets 16/48
RK GXW 520 race chain
Gilles KTS chain adjusters
Gilles KTS GP lifters
Gilles Ti axel nut
Custom carbon shark fin
BRAKES & WHEELS
Blackstone Tek carbon wheels
Brembo HPK 108mm billet calipers
Pro Bolt Ti caliper bolts
Pro bolt Ti front disc bolts
Greggs Ti caliper spacers
Ferodo XRAC pads
Braketech Starblade Ceramic Matrix Composite front rotors
Spiegler quick connect ss front brake lines
HEL custom quick disconnect rear line
ATE super blue racing brake fluid
Brembo RCS 19 billet master cylinder
TWM remote span adjuster
Brembo brake pressure switch
Brembo clear reservoir hoses F&R
Brembo 15ml reservoirs F&R
Brembo HPK billet rear caliper
Brembo underslung caliper mount
Braketech Axis iron rear disc
Pro Bolt Ti rear disc bolts
Graves brake return spring
PAINT & BODY
OEM upper fairing modified for single light
Zero Gravity DB screen with custom paint
Magical Racing type 4 twill carbon mirrors
OEM side fairings, ram air tubes, mudguard & tank
Motoarbo twill carbon fibre inner fairing panels
Pro-Bolt alloy fairing bolt kit
Lacomoto M1 style slotted airbox cover
Di Noc wrapped lower airbox
Geelong Carbon Craft twill CF tankpad
TWM quick action fuel cap
Techspec C3 traction pads
Massco twill carbon fibre tank side panels
GYTR twill carbon fibre headlight infill panels
GYTR twill carbon fibre ram air infill panels
Green Crown twill carbon fibre side fairing inserts
Dynomite twill carbon fibre bellypan
GYTR twill carbon fibre clutch cable guard
GYTR twill carbon fibre exhaust heat sheild
Magical Racing twill carbon fibre rear hugger/chainguard
Dynomite twill carbon fibre tail fairing
Dynomite twill carbon fibre wrapped OEM underseat tray
Dynomite twill carbon fibre solo seat cowl
Akrapovic carbon fibre sprocket cover
Evolution Composites carbon fibre tail tidy
3M DiNoc wrapped tail light
Attack Performance race fairing & seat unit
post #28 of 57 (permalink) Old 12-13-2012, 04:53 AM
Señor Citizen
Here's a picture of 5 mins into my last build.
post #29 of 57 (permalink) Old 12-13-2012, 04:55 AM Thread Starter
There's your problem dude!...
post #30 of 57 (permalink) Old 12-13-2012, 05:03 AM
Señor Citizen
Watch it!
post #31 of 57 (permalink) Old 12-13-2012, 05:10 AM Thread Starter
:...Wrong quote! I meant to say..
There's your problem, dude...
Now...let's see your metal...
post #32 of 57 (permalink) Old 12-13-2012, 05:18 AM
Señor Citizen
post #33 of 57 (permalink) Old 12-13-2012, 05:20 AM Thread Starter
Awwwww... You present a fair case yourself, man...
post #34 of 57 (permalink) Old 12-13-2012, 05:33 AM
Gearheaded's Avatar
The top screws arnt straight
Whoody whoody woo!
You pecker head....
R1-016 Venom Squadron
Gearheaded is offline
post #35 of 57 (permalink) Old 12-13-2012, 05:40 AM
Señor Citizen
They're straighter than Fikays.
post #36 of 57 (permalink) Old 12-13-2012, 05:45 AM Thread Starter
What always bugs me, is they leave the heads and tips of the screws sticking out of the bone...it's not like there's nothing there for them to catch on! The screw closest to my wrist, in my radius bone, stuck out too far. The tendon that controls my index finger dragged over the tip of it for 8 years, clicking, grinding and burning with pain. They recently removed the screw and sewed up the damaged tendon, and it's been fine ever since!
If I left a screw sticking out, or a sharp weld unground, and someone hurt themselves...I'd be libel...and ashamed of my work!
post #37 of 57 (permalink) Old 12-13-2012, 05:47 AM Thread Starter
....so's this!...
post #38 of 57 (permalink) Old 12-13-2012, 05:56 AM
Gearheaded's Avatar
....so's this!...
Whoody whoody woo!
You pecker head....
post #39 of 57 (permalink) Old 12-13-2012, 09:39 AM
all joking aside, dude! you gotta eat!!
post #40 of 57 (permalink) Old 12-13-2012, 03:39 PM
Señor Citizen
Actually, we gotta stop eating, eating shit. I fu*king hate broken bones.
