Your Maintenance Products In Here! - Yamaha R1 Forum: YZF-R1 Forums
  • 1 Post By bsgesch
post #1 of 17 (permalink) Old 03-17-2017, 10:23 AM Thread Starter
The Doctor's Assistant
Masao Furusawa's Avatar
So what do you guys use to do maintenance on your bike?
Examples include:
- lubing your chain,
- keeping your injectors clean,
- waxing/fixing/polishing your skin, I mean plastics
- Cleaning titanium (or different metals)
- Seafoam?
You get the gist......
Inquiries are more than welcome
Ex. Does this product actually work well?
Masao Furusawa is offline
post #2 of 17 (permalink) Old 03-17-2017, 12:21 PM
The R1S Guy!
Nya`'s Avatar
Chain Lube
Injector Cleaner
Cleaner (you can use this on literally anything on the bike, the metal, plastic, rims, paint, anything)
This stuff is incredible for cleaning your bike, a bottle of this with a microfiber cloth will wipe down any area of your bike spotless and won't leave a single streak.
Nya` is offline
post #3 of 17 (permalink) Old 03-17-2017, 02:15 PM
Plastic surgery pending
thesoapster's Avatar
Chain cleaning/lubing? Do you want a war???
Personally I clean my chain with that Maxima Clean Up, hose it off, hand dry as much as I can. Then I WD-40 it, wipe off as much excess as possible, and do a light spray of Motul chain lube, wiping off excess after a few minutes have passed.
I'm happy with the result.
thesoapster is offline
post #4 of 17 (permalink) Old 03-17-2017, 04:29 PM
Klaus Von Slowpoke
bsgesch's Avatar
What is this "maintenance" you speak of?
Do you have to leave so soon? I was just about to poison the tea.
bsgesch is offline
post #5 of 17 (permalink) Old 03-18-2017, 06:32 AM Thread Starter
Originally Posted by Nya` View Post
Chain Lube
Injector Cleaner
Now that is what I call a response. Thanks for sharing the info. I'm definitely going to look into the Wax-as-u-dry, looks very promising. You've had enough experience with the Lucas Oil product to recommend it?
Yup, why not, Maximaaaans.........attack! I use Maxima as well, Their Chain wax is great, but their chain lube is horrid, flings all over the place.
post #6 of 17 (permalink) Old 03-18-2017, 07:28 AM
WeaponR1's Avatar
I've had 5 bikes, and never once have I used that garb called "chain lube/chain wax". Kerosene on a rag, bike on rear stand, cover chain with kerosene soaked rag and spin the tire. Once your done, dry rag to wipe the excess.
The down fall of chain grease/lube/wax.. It attracts dirt, dirt creates friction, friction creates heat and heat creates stretch. That equals a f$&@ked chain. Don't buy into the gimmicks.
WeaponR1 is offline
post #7 of 17 (permalink) Old 03-18-2017, 11:00 AM
The R1S Guy!
Nya`'s Avatar
No problem, yeah I use Lucas oil and fuel products on my bike and all of my vehicles, it goes a long way to helping the longevity of an engine.
Nya` is offline
post #8 of 17 (permalink) Old 03-18-2017, 11:27 AM
Change the oil n filter and keep the plastics spotless with auri wax. No chain lube never ever. Clean chain free of lube. Everything you need on a chain is sealed internally. I've raced that way n never a problem and my chains last as long as the guys that lube them. Occasionally I'll wipe it off w wd-40. Unless ur riding a Harley you don't have to worry about anything!!!
Yellow60thR1 is offline
post #9 of 17 (permalink) Old 03-18-2017, 11:48 AM
Horsepower whisperer
Torchsport's Avatar
I do normal maintenence. Keep the chain clean and lubed, regular oil changes, keep things adjusted and wipe bugs and dirt off with a squirt bottle with water in it.
I've had dozens of bikes over the decades. Put on over 300,000 miles.
I would never waste 1 minute waxing a bike. That's for the bar hopping pirate crowd.
2016 BMW S1000RR Premium (Dream bike)
2015 MV Agusta Brutale 1090RR (Sex machine)
2014 Yamaha YZ250 (Braaaaaaap!)
2006 Harley Davidson V-Rod Street Rod (Only HD that handles)
2003 Yamaha YZF-R1 (My 3rd R1)
Torchsport is offline
post #10 of 17 (permalink) Old 03-18-2017, 11:57 AM
I don't go to bars when riding !!!
post #11 of 17 (permalink) Old 03-18-2017, 08:00 PM
WeaponR1's Avatar
Mind posting pics of a bike you own that's never been waxed ? I need to see this.
WeaponR1 is offline
post #12 of 17 (permalink) Old 03-18-2017, 09:28 PM
Torchsport's Avatar
A sample. I'll even include my car that DOES get driven in the rain. Never waxed.
The last time I waxed a vehicle was about 1989.
ID:	923378   Click image for larger version
ID:	923386   Click image for larger version
ID:	923394   Click image for larger version
ID:	923402   Click image for larger version
post #13 of 17 (permalink) Old 03-18-2017, 10:03 PM
"What"
Dai.'s Avatar
I use Motul Wash & Wax on all my vehicles car included. I've been using this range for 7 years and leaves the bike with a nice clean shine.
Sig By Petrol Spice.
Dai. is offline
post #14 of 17 (permalink) Old 03-18-2017, 11:56 PM Thread Starter
So both of you are recommending against the OEM instructions to lube your chain every 1000KM.......anyone else just clean and not lube their chains?
post #15 of 17 (permalink) Old 03-19-2017, 09:08 AM
Klaus Von Slowpoke
bsgesch's Avatar
Me. Because this:
If the intent of more sophisticated X-rings, W-rings, etc., is to seal lubricant in the moving parts, why lube the outside? It's not getting past the seals into the moving parts.
Which means this:
gkamp likes this.
bsgesch is offline
post #16 of 17 (permalink) Old 03-19-2017, 11:37 AM
That 1st bike in ur pics doesn't count.
post #17 of 17 (permalink) Old 03-19-2017, 07:32 PM
Scared? You SHOULD be!
Yautja's Avatar
Thumbs up
https://wd40.com/
Yeah, that's right bitches...I'll fire the opening salvo.
- where I come from, things rust like hell. Nothing beats WD-40 in this regard;
- mechanical things need lubrication to keep things running smoothly and slow down wear & tear;
- people have used WD-40 for ages to take care of their chains. Nothing bad ever came out of it. I'll keep using WD-40, thanks (unless someone releases something much superior).
Trust unto God and He shall direct your path.
Yautja is offline
