Are there any 98-01 R1 owners left? - Page 40 - Yamaha R1 Forum: YZF-R1 Forums
post #781 of 843 (permalink) Old 06-20-2012, 10:43 PM
I ride naked
xtremewlr's Avatar
Originally Posted by 2000R1Devil View Post
Any of you guys have problems with regulators and if so, what did you do? My stator is fine but im on my 3rd regulator in 4 years.
I LOVE this bike...ive ridden the newer ones and i would still take mine ANY day but this regulator thing is making me want to sell it.
I replaced the regulator on my bike with a newer one from a 07+ R1s, some VStar bikes and newer FJRs. It's MOSFET technology and much better than the stock regulator that is on the earlier bikes. I know my bike is an FZ1 but I believe they use the same regulator and this mod can be applied to any of the earlier bikes with the SCR type regulators. You will never have issues with the charging system again after this. I've done the same mod on a 2001 SV650, just with a different regulator, not rated as high as the one I used on my FZ.
See my thread here - http://www.yamahafz1oa.com/forum/sho...d.php?t=122303
Let me know if you have any questions about it.
xtremewlr is offline
post #782 of 843 (permalink) Old 06-20-2012, 10:48 PM
Mad Thou Rider
tigertim20's Avatar
upgrade to the mosfet typre regulator off the 07 R1
<img src=http://i1226.photobucket.com/albums/ee415/r1tim/sigpic.jpg border=0 alt= />
thanks petrol!!
tigertim20 is offline
post #783 of 843 (permalink) Old 06-21-2012, 04:19 AM
Have you hugged your R1 today?
13 years, and 70,000kms never had any problem with a regulator.
Take it to the track.
r1ian is offline
post #784 of 843 (permalink) Old 06-21-2012, 06:18 AM
2000R1Devil's Avatar
Thanks for the feedback guys...i'll check into the mosfet r/r.
"4,000 in 1st"
Devil tuning exhaust, Flo-Commander, BMC air filter, Factory Pro 59mm velocity stacks, Scotts steering damper, LED Headlights, ASV shorty levers
2000R1Devil is offline
post #785 of 843 (permalink) Old 06-21-2012, 06:39 AM
Above is the 07, below is the 01....
The 07 fitted into the 01....
Good as gold.
CARBONAR1 is offline
post #786 of 843 (permalink) Old 06-21-2012, 07:51 AM
Cheating death in the "D"
rorlow's Avatar
Mossfvck . . . WTH
rorlow is offline
post #787 of 843 (permalink) Old 06-21-2012, 08:17 AM
post #788 of 843 (permalink) Old 06-21-2012, 05:43 PM
pinkyota's Avatar
Do you have to get the wire harness for the 07 as well? It doesn't look like a plug and play mod. Just curious about this, because my hids seem to draw a bunch of power, and I would like to put less stress on the system.
2001 Yamaha R1
BMC Race Air Filter
Gilles Tooling Rearsets
ASV Shorty levers
Greggs Flushmounts
Graves AIS blockoffs
Renthal Sprockets - 16t Front, 45t Rear
EK MVXZ Chain - 520
Danmoto slipon
Custom painted Auctmarts fairings and cowl
Spiegler Brake Lines
Carbone Loraine SBK5 pads
Tygon Master cyl. lines
for now...
pinkyota is offline
post #789 of 843 (permalink) Old 06-21-2012, 05:49 PM
Sonic Boom!
Benocehcap's Avatar
Good as gold.
Hi Ben,
Why would you do this mod...?
thx
Ben
Benocehcap is offline
post #790 of 843 (permalink) Old 06-21-2012, 06:11 PM
for life.
Mine is in my avatar
jilbake is offline
post #791 of 843 (permalink) Old 06-21-2012, 06:16 PM
I ride naked
xtremewlr's Avatar
Originally Posted by Benocehcap View Post
Hi Ben,
thx
Ben
Answers.
This is a mod that I have done before on a 2001 SV650 and it can be applied to pretty much any bike out there. You can view the thread I made on converting that bike here - http://www.svrider.com/forum/showthread.php?t=111850
I can't take credit for the idea or design except for doing it on my FZ1. The real credit goes to DEcosse, who isn't a forum member here but is on several other bike related sites and has done this mod to all his bikes of varying makes and models. You can read more about it and some of the theory behind it here - http://eviltwinsbk.com/forumz/index.php?topic=276.0
This mod completely eliminates the white connector and related wiring and replaces the stock regulator/rectifier with a much better MOSFET unit. All new weather tight connectors are being used too. In my particular case, I am also relocating the RR to the empty area where the stock air box was since I have pod filters. This will also shorten and compact the RR part of the charging system, causing even less resistance and points of possible failure.
Here is the basic wiring diagram of what I did. Again, credit goes to DEcosse, the author of the thread I linked above from eviltwinsbk forums. While the diagram shows the black and red wires coming out the the stock RR separately, on the FZ they come out all together and go to the white connector, separating later in the wiring harness. The FZ still has the intermediate harness that is to be eliminated.
Answers to a couple questions that I know will come up regarding the new wiring.
1. What's the point of running new wires from the battery?
Direct wiring to the battery from the RR output gives more consistent charging of the battery since there are less points of failure (multiple factory connections in the stock harness) and the wires being used for this are larger 12ga wires. The stock wiring from the RR connector is small gauge and also is not ideally routed/coupled - it actually splices into the wire harness with a crimp coupler that has been known to oxidize & fail. Many are under misapprehension that the R/R ONLY carries the current required to keep the battery charged - it actually carries ALL the current that the bike consumes PLUS the charging current for the battery.
So a 12ga wire directly coupled to the battery ensures there is minimal voltage drop across that larger grade wire than OEM wiring. Performance is thus improved in power delivery to the bike's system as well as the charging voltage applied to the battery.
2. Why the additional fuse? Why not wire it into the existing fuse box?
It provides a measure of safety if there is a short in the system. Running the wires into the factory fuse box would actually be more work in my opinion and not be as simple because of trying to install the wiring into the fuse box. The external fuse holder is easy to install and keeps the charging system wiring separate for ease of troubleshooting if there are issues later.
On to the parts I am using!
The replacement RR I am using is a FH012AA. This is commonly found on 07+ R1s, some VStar bikes and newer FJRs. It's rated at 50A where the stock SH650C-11 RR is only rated at 18A. The Yamaha part # for the FH012AA RR is 1D7-81960-00-00 and it runs for about $131 new according to ronayers.com. I picked mine up on ebay for $90 shipped.
The new connectors that I am using are all sourced from easternbeaver.com. These are "build yourself" connectors, meaning that you need to install the wires into them but they are otherwise ready to go. The RR connectors are identical to the OEM ones and are far superior to anything else on the bike.
An inline 30A fuse is also being added to the system as an additional safety precaution and is also sourced from easternbeaver.com and is weather tight too.
Other items needed are 12ga wire in black and red, 30A ATM fuses (the small ones like the other fuses in the bike), ring connectors for 12ga wire to attach to the battery and shrink tube.
Parts list:
~1 FH012AA Regulator/Rectifier - new or search ebay for 07+ R1, 06+ FJR or 07+ VStar XVS1300. Yamah part # 1D7-81960-00-00
~1 set of Furukawa plugs for the FH012AA RR, get them from here - http://easternbeaver.com/Main/Elec__...onnectors.html
~1 Metri-pack 280 ATM fuse holder for 12ga wire from here, order the "MP280 Fuseholder (14-12 AWG)" and specify 12ga in the notes when you pay - http://easternbeaver.com/Main/Elec__...seholders.html
~1 pack of 12ga wire in RED - AutoZone or similar
~1 pack of 12ga wire in BLACK - AutoZone or similar
~1 pack of 14ga wire in WHITE to extend the stator wires - AutoZone or similar
~1 pack of Ring terminals for 12ga wire - AutoZone or similar, look for "Weatherproof" if available.
~Heat shrink tube.
~30A ATM blade fuses, these are the small ones - AutoZone or similar
post #792 of 843 (permalink) Old 12-18-2012, 02:22 PM
Eastern Beaver will also supply the RR plugs already wired, with two options of cable length. .
And some whoring...
post #793 of 843 (permalink) Old 12-18-2012, 02:41 PM
launch junkie
And some whoring...
What kinda pipe is that,and carbon I have so many questions about my bike and the exhaust,think we talked a bit about it last year but I'm about to have the cash I need to understand it all if ya got time
greenhorn is offline
post #794 of 843 (permalink) Old 12-18-2012, 02:46 PM
That's a Delkevic slip on and link pipe, they're on Ebay. PM me your questiobs, I'd be glad to help if I can.
post #795 of 843 (permalink) Old 12-18-2012, 02:49 PM
SuperMod Abuser
Fikays's Avatar
wtf is a "questiobs", Ben??
SIG courtesy of petrol!
R1-015 `Ghostrider` Squadron CO
Fikays is offline
post #796 of 843 (permalink) Old 12-18-2012, 03:01 PM
Bon't prebend bou bon't bnow whab questiobs are...
post #797 of 843 (permalink) Old 12-18-2012, 03:13 PM
launch junkie
Lol
post #798 of 843 (permalink) Old 01-07-2013, 01:27 AM
Rossi is GOD
oma72's Avatar
been awhile since my last pics so here is my 01 i've owned since 2005-84000 k's
oma72 is offline
post #799 of 843 (permalink) Old 01-07-2013, 02:25 AM
"What"
Dai.'s Avatar
That is superb and your in Ippy,do you hit Mt Glorious,Mt Nebo,Splityard Crk and Northbrook much?. How do you find the grips?
Carbonar1 - That bike is ridiculously clean.
Dai. is offline
post #800 of 843 (permalink) Old 01-07-2013, 01:26 PM
kristophorsR1's Avatar
2001 champ edition #0009
Here she is my time machine, with only 5400 miles on her. Still looks brand new.. Also for the record I did not need to do it, but I did the 07 rectifier as well, just for peace of mind. I will say this it does make a huge difference concerning the heat issues with the standard rectifier.
kristophorsR1 is offline
