For the Forum gun fiends! - Page 450 - Yamaha R1 Forum: YZF-R1 Forums
 72Likes
post #8981 of 15450 (permalink) Old 11-19-2012, 07:06 AM
Send a message via AIM to WarMachine
Hey Jason have you run across anybody that has used this?
http://www.barrettrifles.com/p-1641-...mark-4-m1.aspx
WarMachine is offline
post #8982 of 15450 (permalink) Old 11-19-2012, 09:45 AM
The Lead Farmer
Meister37's Avatar
I saw one demo'd and it seemed to work as long as things weren't too bad as far as weather.
Kirk is a total dick.
Meister37 is offline
post #8983 of 15450 (permalink) Old 11-19-2012, 09:47 AM
I think it's a decent go between with the other system i posted. Still have to use some marksmanship skills, especially with windage.
post #8984 of 15450 (permalink) Old 11-19-2012, 09:51 AM
The Lead Farmer
Meister37's Avatar
I wouldn't use one myself. Trading skill for technology is ok as long as the tech will always be able to be serviced. Using it as a crutch instead of learning the skill properly makes you dependent on it. That I don't like.
post #8985 of 15450 (permalink) Old 11-19-2012, 09:59 AM
That's understandable, knowing the skill first is definitely better, since tech can, has and will fail.
post #8986 of 15450 (permalink) Old 11-20-2012, 07:32 AM
Venom GA state lead.
molonlabe's Avatar
Originally Posted by Creeping Death View Post
Is that the stuff you bake to cure?
No it will cure at room temp. Just don't bang it around while it's curing.
I thing the cure times are:
1 hour for touch
24 hours for reassembly
7 days for general use
30 days for hardcore use and abuse
R1-016 "Venom" GA state lead
Venom sign-up
sig courtesy of Petrol_Spice
RIP Lester
"The limits of tryants are prescribed by the endurance of those whom they oppress." -Fredrick Douglas
molonlabe is offline
post #8987 of 15450 (permalink) Old 11-20-2012, 07:35 AM
molonlabe's Avatar
Originally Posted by gsxcorey View Post
Not big into handguns and monday gonna go get my hk45ct.
What ammo do you guys recommend? Eventually gonna reload and looking for quality ammo so i can compare a box to reloading equipment/supplies. Hard to compare things and know what to look for when I don't know what is considered good ammo? Any recommendations on brands, grains, type, etc?
I like Federal Hydroshok and HST. Other good choices are Speer gold dot, Hornady XTP and FTX, and Winchester PDX
Venom sign-up
RIP Lester
post #8988 of 15450 (permalink) Old 11-21-2012, 11:50 AM
I am anger under pressure
MANOWAR's Avatar
If this works it's pretty cool.
http://www.youtube.com/watch?v=LvbyA...ature=youtu.be
PCIII USB|Yamaha Seat Cowl|R&G Frame Sliders|Greggs Custom Barend Sliders|Intuitive 6MM swing arm spools|CRG Shorty Clutch & Brake Levers|Clear Alternatives Brake/Tail Light Integrator|R&R Fender Eliminator|Harris Grips|High Gear Tech Mount|Puig Dark Smoke Racing Screen|Graves Velocity Stacks|Cycle Gadgets Quick Change Oil Kit|Watsons Flushmount Turn Signals|Custom Race Baffles|Graves Clutch Slider|Acumen Gear Indicator|Racer Solutions Remote Laptimer Kit|Galfer SS Brake Lines|Graves Rearsets
MANOWAR is offline
post #8989 of 15450 (permalink) Old 11-21-2012, 04:14 PM
Moderatorasfcvk
KMac's Avatar
Nothing like 70degrees for T'giving holiday. Went to the gun range today and went thru about 1200 .22's and 200 5.56's. My 14-yr old and I play a .22 shooting game that never gets old. We mark a vertical line on the backstop embankment and place 3 golf balls on the line. Then, we each load 25-rd magazines and shoot at the balls. The object is to shoot the balls onto the other guy's side on the line so that when you're done with the 25 shots there's more golf balls on the other side than on your side. A well placed shot, just barely grazing the bottom of the ball at either 4 o'clock or 8 o'clock will send the ball up to 20' in the opposite direction towards the top of the embankment, where it will then roll down the entire embankment and veer to the left or right depending on what it hits.
There's a ton of different strategies. It's great because it's never the same shot twice and the ball always does something different, plus you can screw the other guy by anticipating his shot and shooting a split second prior to him so he wastes his shot. You can even wait until he is concentrating on one particular ball, then shoot one of the other balls, followed by shooting dirt or broken clays, etc... that may be around it to cover the ball and hide it. I had 2 balls on his side that I had hidden and when he finally got the ball he was shooting at onto my side of the line, he couldn't find the 2 hidden balls and had to shoot at piles of debris hoping the ball was in the pile. He was so frustrated he burned up his last 10 shots and never found either of the balls. We had half the people at the range gathering around to watch at one point. Good times!
The 3 golf balls lasted us the whole time, they're nearly indestructible.
KMac is offline
post #8990 of 15450 (permalink) Old 11-21-2012, 04:18 PM
Sounds like fun, get vid if you can next time out
Sent from my Rooted S3 fool
post #8991 of 15450 (permalink) Old 11-21-2012, 04:34 PM
The Lead Farmer
Meister37's Avatar
I'm going to have to try that, sounds like fun!
post #8992 of 15450 (permalink) Old 11-22-2012, 12:47 AM
my girlfriend likes girls
InkedR1Pilot's Avatar
Send a message via Yahoo to InkedR1Pilot
sig by petrol
RAMPAGE RACING
InkedR1Pilot is offline
post #8993 of 15450 (permalink) Old 11-22-2012, 12:55 AM
The Lead Farmer
Meister37's Avatar
Looks like a shopping list to me.
post #8994 of 15450 (permalink) Old 11-22-2012, 07:27 AM
Moderatorasfcvk
KMac's Avatar
It looks like the minimum requirements spec for the common geardo.
KMac is offline
post #8995 of 15450 (permalink) Old 11-23-2012, 07:04 AM
Viva La Figa
hawk71's Avatar
Finally got to shoot my PSA yesterday! It worked flawlessly and only too two adjustments to zero.
200 rounds including 60 rounds rapid fire and not a single hiccup.
"No. You live more for five minutes going fast on a bike like that than other people do in all of their life."~Marco Simoncelli
R1-016 `Venom` Squadron
NESBA #71
hawk71 is offline
post #8996 of 15450 (permalink) Old 11-23-2012, 07:42 AM
Good stuff D, picked up a 10/22 plus 1k rouds this morning.
post #8997 of 15450 (permalink) Old 11-23-2012, 09:15 AM
The south roads are best roads
BeaverPuncher's Avatar
Dang horder
BeaverPuncher is offline
post #8998 of 15450 (permalink) Old 11-23-2012, 09:25 AM
Originally Posted by BeaverPuncher View Post
Dang horder
Meister is the hoarder I'm just a lowly apprentice
post #8999 of 15450 (permalink) Old 11-23-2012, 09:27 AM
Let's have him committed and go "reorganize" his supply
post #9000 of 15450 (permalink) Old 11-23-2012, 09:29 AM
let's do it
R1-Forum/R6-Forum Memorial Trackday at Jennings GP, March 2010 Sign-Up DanQ Trackdays / Schools 447 03-08-2010 02:40 PM
Special Edition McCoy / R1-forum.com / R6-forum.com Race Suit & Jackets SpidermanSS Vendors and Group Purchases 34 05-18-2007 05:03 PM
Qustions for R1 fiends. Oil Baffle, Gas Cap, Plug for gauges Bonjo2 General Motorcycle Discussions 3 10-25-2006 10:16 PM
