For the Forum gun fiends! - Page 462 - Yamaha R1 Forum: YZF-R1 Forums
 72Likes
post #9221 of 15450 (permalink) Old 12-02-2012, 02:14 PM
Send a message via AIM to WarMachine
Yep, they draw a crowd. The REPR got a new addition today. I'll post pics tonight after a good cleaning.
Cool, i'm gonna start saving for an 16" or 18" REPR. LDUB is a badass manufacturer....No question
WarMachine is offline
post #9222 of 15450 (permalink) Old 12-02-2012, 02:17 PM
Originally Posted by stonewall View Post
what did you have to give for that sexy thang!?
$1700
No serious cleaning, just wiped down the BCG, swabbed the bbl, and the patches cam out clean after that. Got the ammo for $8/20 rd box from dicks sporting goods.
post #9223 of 15450 (permalink) Old 12-02-2012, 02:23 PM
ROWDY
Stonewall's Avatar
$1700
Does that have the chromed bore and chamber?
ROWDY
Stonewall is offline
post #9224 of 15450 (permalink) Old 12-02-2012, 02:27 PM
The Lead Farmer
Meister37's Avatar
I'm going to order a 14.5 pinned with a Bilock. I've almost got enough saved up. I've decided that any conflict that can't be solved with 20 rounds of 308 isn't going to be solved by me regardless. My need list is short, for sure. Then I'm expanding my loading bench.
$1700
They stay pretty clean unless you run a can. I know a couple guys doing failure tests on them. One has over 5k rounds with 2 failures, zero cleaning. Lube application only.
Kirk is a total dick.
Meister37 is offline
post #9225 of 15450 (permalink) Old 12-02-2012, 02:29 PM
Nicorr treated bbl and nickel boron bcg for permanent lubrication. Doesn't need a lot of lube.
Here is the description from the website.
The M6A2™ rifle is a standard carbine available in various barrel lengths and in either 5.56mm NATO or 6.8mm SPC. The M6A2™ rifle is ideal for those who utilize optical sights as it employs a low- profile gas block. There is no A-frame front sight to obscure the field of view of the optical device. The M6A2™ rifle also features a longer midlength free float rail system with a removable return-to-zero top. Any M4 MIL Std 1913 accessory can be mounted to the rail, and because the rail has a monolithic profile, you can bridge devices from the receiver to the rail seamlessly. The longer rail also affords more 1913 “real estate” to mount your accessories.
The M6A2™ rifle can be used in various roles. With the 10.5 inch barrel, it is ideal for close quarters battle or fighting in built up areas. The 14.7 inch barrel M6A2™ rifle is an excellent general purpose carbine capable of effective fire out to 600 meters. And with the 16.1 inch barrel, the M6A2™ rifle can be used as a Squad Dedicated Marksman Rifle.
The M6A2™ rifle’s edge in capability, reliability, accuracy and long service life is the result of advanced technology materials and manufacturing processes, combined with progressive patented designs. All LWRCI™ carbine systems feature our short-stroke gas-piston operating system. The operating system is lightweight, self-regulating, and self-scraping. This system of operation does not foul the moving parts of the weapon with carbon or heat, greatly enhancing service life and reliability while decreasing both user and armorer maintenance. All M6A2™ rifles feature a match grade, cold rotary hammer forged barrel with a target crown. The barrel is treated with NiCorr™ surface conversion technology that extends service life, enhances accuracy, and increases the effective range of the weapon. As in all of our rifles, the bolt carrier group and the barrel extension of the M6A2™ rifle is coated with EXO’s patented nickel-boron surface conversion technology that provides a hard permanent lubrication to the moving parts.
The M6A2™ rifle defines itself as the most modern and incrementally evolved carbine in the world. At the same time it also presents the best value. Service life is extended to four times that of a legacy M4, accuracy is 100 percent better, and our M6 rifles are many times more reliable than the legacy gas-impingement design.
post #9226 of 15450 (permalink) Old 12-02-2012, 02:30 PM
The Lead Farmer
Meister37's Avatar
No, it's Nicorr.
But our revolutionary short-stroke gas-piston system is only one of the improvements we’ve made in the legacy carbine. LWRCI™ rifles and carbines utilize cold hammer forged barrels made out of 41V45 steel alloy and treated with NiCorr™ surface conversion technology. Cold hammer forging takes an oversized barrel blank, and using high pressure rotary hammers, compacts the barrel blank over a mandrel. This forms perfect rifling devoid of tool marks. It also compacts the molecular structure of the metal making it denser and stronger. These barrels can take a lot more use and abuse than a standard barrel before any degradation in accuracy or loss of velocity. NiCorr™ surface conversion has proved more lubricious, harder wearing, more heat and corrosion resistant than the hard chrome normally used in the bore. Our barrels can handle 20,000 rounds before replacement, as compared to 6,000-10,000 rounds on a standard M4.
post #9227 of 15450 (permalink) Old 12-02-2012, 02:31 PM
I should have picked up that single press reloader on black friday but i skipped it. Gonna start saving for a progressive loader. I'm gonna be shooting a sheot ton now.
post #9228 of 15450 (permalink) Old 12-02-2012, 02:34 PM
The Lead Farmer
Meister37's Avatar
If you plan to shoot a bunch of 223, get the 1050. Anything less will cost you time cutting brass and punching mil crimp primer pockets. Worth every penny. 650 for pistol rounds and blackout, single stage for 308.
post #9229 of 15450 (permalink) Old 12-02-2012, 02:35 PM
The Lead Farmer
Meister37's Avatar
http://ericpetersautos.com/2012/11/2...-will-be-done/
post #9230 of 15450 (permalink) Old 12-02-2012, 02:36 PM
Dillon 1050? Who is a good source, Midway?
post #9231 of 15450 (permalink) Old 12-02-2012, 02:45 PM
The Lead Farmer
Meister37's Avatar
Dillon is pretty tight with their stuff. I think there are 2 dealers that sell them online. I just call dillon and get my stuff directly from them. Both mine were second hand so that is another option. You have to act fast when you see one though, they go fast.
Edit: They sell high.
http://www.ebay.com/itm/used-DILLON-...item3f1f5b7dd3
post #9232 of 15450 (permalink) Old 12-02-2012, 02:48 PM
Ok, time to stack some paper.
post #9233 of 15450 (permalink) Old 12-02-2012, 02:50 PM
Damn that's about what dillon charges new
post #9234 of 15450 (permalink) Old 12-02-2012, 03:00 PM
The Lead Farmer
Meister37's Avatar
Converting my 650 to large primer will cost about 300 less than a new machine. I'm considering getting another unit. 3 dillons..... Yeah, that's about right.
Guess what my youngest son's name is?
post #9235 of 15450 (permalink) Old 12-02-2012, 03:09 PM
The south roads are best roads
BeaverPuncher's Avatar
What's the most reliable way to clean my dpms ? Are there different ways to do it ? What would be the most common lube and cleaner also.I only have a decent wood case cleaning kit that covers shotguns ,rifles and pistols of various calibers. Is this adequate or should I use a more specific one for the ar?
BeaverPuncher is offline
post #9236 of 15450 (permalink) Old 12-02-2012, 03:13 PM
The Lead Farmer
Meister37's Avatar
What you have will work fine for now. You will need a chamber brush sooner or later. Hoppes or equivalent will do fine. Get on youtube and look up AR15 cleaning. Break the entire gun down to field stripped condition and clean it. Pay careful attention to the BCG. That is the heart of the system. Lube well, I mean wet! A wet AR is a happy AR. Always clean from breech to bore.
post #9237 of 15450 (permalink) Old 12-02-2012, 03:13 PM
I'm gonna say Dillon?
Sent from my Rooted S3 fool
post #9238 of 15450 (permalink) Old 12-02-2012, 03:22 PM
The Lead Farmer
Meister37's Avatar
Yep
post #9239 of 15450 (permalink) Old 12-02-2012, 03:32 PM
ROWDY
Stonewall's Avatar
No, it's Nicorr.
Damn! Very nice! If it was just selective fire it would have everything a man could want.
ROWDY
post #9240 of 15450 (permalink) Old 12-02-2012, 03:38 PM
Since we're on the subject... Guess what my son's middle name is?
Hint: It's not a loader...
fjorn is offline
R1-Forum/R6-Forum Memorial Trackday at Jennings GP, March 2010 Sign-Up DanQ Trackdays / Schools 447 03-08-2010 02:40 PM
Special Edition McCoy / R1-forum.com / R6-forum.com Race Suit & Jackets SpidermanSS Vendors and Group Purchases 34 05-18-2007 05:03 PM
Qustions for R1 fiends. Oil Baffle, Gas Cap, Plug for gauges Bonjo2 General Motorcycle Discussions 3 10-25-2006 10:16 PM
