ContourRoam: need help - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 11 (permalink) Old 04-11-2013, 10:33 AM Thread Starter
So got myself a contour roam off Craigslist. Wanted to mount on the side of the helmet and have a few mounts on the bike if I ever want to change location. Figured everything except for the helmet. I'm afraid the double sided tape may come off against high speed winds
siddiqim is offline
post #2 of 11 (permalink) Old 04-11-2013, 03:56 PM
Use the 3M gray double sided tape. Should do the trick.
cataclyzm123 is offline
post #3 of 11 (permalink) Old 04-11-2013, 03:59 PM
Owner of the color changing R1
R1nStang's Avatar
i used the adhesive they supplied on the flat mount on my swingarm...never had an issue with it. just clean the area with alcohol. let it dry. then apply the mount applying pressure for a few minutes....if you can somehow clamp it thats great....let it set for 24 hours
R1-015 `Ghostrider` Squadron
Competition Werkes slipons, Leo Ypipe, PCV, -1/+1 520 conversion, Flashtune.
R1nStang is offline
post #4 of 11 (permalink) Old 04-11-2013, 07:17 PM Thread Starter
Ok there's no belt or clip that can hold it in place?
siddiqim is offline
post #5 of 11 (permalink) Old 04-15-2013, 09:30 AM
R1nStang's Avatar
i tied the lanyard to the brake line "guide" but i never had any problems..the camera never budged
R1nStang is offline
post #6 of 11 (permalink) Old 04-15-2013, 10:01 AM Thread Starter
I'm trying to have it on my helmet
siddiqim is offline
post #7 of 11 (permalink) Old 04-15-2013, 10:41 AM
My R1 feeds me
Wings of gold's Avatar
I put my contour on my helmet and its annoying as all hell....freakin drag it gives off at higher speeds is annoying for anything more then a 15 min ride on the highway
Wings of gold is offline
post #8 of 11 (permalink) Old 04-15-2013, 10:47 AM Thread Starter
What if you attach it to the side?
siddiqim is offline
post #9 of 11 (permalink) Old 04-15-2013, 10:51 AM
My R1 feeds me
That's what I did, left side of helmet, maybe if you put it dead centre on top
post #10 of 11 (permalink) Old 04-15-2013, 11:17 AM
The Dovahkiin
Minacious's Avatar
The double-sided tape supplied with the camera should be more than strong enough if applied correctly.
I've run both Contour+ and ReplayXD cameras on the sides of my helmets and there is no perceptible drag.
Ed - Klingon women are HOT! (A Trekker for life)
CG Artist and Sci-Fi Nerd
Manic-Depressive and my head hurts.
Minacious is offline
post #11 of 11 (permalink) Old 04-15-2013, 11:24 AM
IMSTuner's Avatar
It holds just fine.
2008 R1 Black - Gold AVS C5 Levers, Puig DB Wind Screen, EvoTech Sliders Kit, T-Rex Clutch slider, Stomp Tank Pads, LeoVince Ti Factory Evo II CF end caps, Arko Y-Pipe, EvoTech Fender Elim., Proton Signals, PZRacing GearTronic Zero , Q2 tires, Flash-Tune Interface,Brembo RCS Ohlins FRT fork and TTX shock
My Build Thread
YouTube Page
IMSTuner is offline
