Brembo M4 Caliper and Y-pipe 3/4 Akrapovic Bung size for Autotune - Yamaha R1 Forum: YZF-R1 Forums
 6Likes
post #1 of 21 (permalink) Old 03-15-2017, 09:34 PM Thread Starter
Hello everyone, I searched and didnt see anything mention about what I intend to ask, so i post a new thread here.
1) Anyone own R1-15-16 installed brembo M4, please show me yours and give me suggestion? I bought M4 Caliper and intend to use it with OEM Rotor, but when i try to install it on my bike (60th anniversary) but the top of M4 caliper is snagged by the bolt (plz look at picture). They said i should cut the front fender and cnc new pad. Do i need spacer when I use OEM rotors?
2) I bought autotune and my bike uses 3/4 Akrapovic, my technician said autotune' sensor will not fit with the sensor on Y-pipe, he should make new hole. Is it true? my bike is at his shop now so i cant check.
V1nc3nt is offline
post #2 of 21 (permalink) Old 03-16-2017, 07:10 AM Thread Starter
Up for answer
V1nc3nt is offline
post #3 of 21 (permalink) Old 03-16-2017, 09:26 AM
Be good humans!
bfrank's Avatar
I know about the Auto tune. I had a Graves 3/4 pipe and both the bugs were too small. I got a new mid pipe from Graves with a single larger bung for the larger diameter AutoTune sensor.
Be good humans!
bfrank is offline
post #4 of 21 (permalink) Old 03-16-2017, 10:13 AM
R1, "A Superior Addiction"
cyclepsycho7's Avatar
What kind of bugs were they, ants or something, LOL.
PS: Sorry but couldn't pass up the chance being I've made a typo or two on the site and totally got my balls busted.
Lucky 13 Squadron
cyclepsycho7 is offline
post #5 of 21 (permalink) Old 03-16-2017, 10:14 AM
you lose
Mr_Snips's Avatar
Should be brembo part # 220A06115
If everthing is coming at you...then your in the wrong lane
Mr_Snips is offline
post #6 of 21 (permalink) Old 03-16-2017, 04:51 PM Thread Starter
About the Akra Y-pipe is the size of bun for autotune is 12 while size of autotune sensor is 18?
About brembo, i stuck front fender pad when trying to install M4 calipers like in the picture. Do you know how to solve it and what spacer when use M4 with OEM rotors?
V1nc3nt is offline
post #7 of 21 (permalink) Old 03-16-2017, 06:09 PM
yamaharandy's Avatar
yes you need a 18mm bung. woolich racing sells them in Stainless steel or Titanium. they also have an adapter so you can install the wideband sensor into the smaller 12mm bungs. might be the perfect solution for you so you don't have to have a bung welded into the pipe. they also have caps to plug the other bung holes if you need them. make sure the sensor is installed in a pipe that all the cylinders will flow through. you want it to be sniffing all 4 not just 2.
https://www.woolichracing.com/produc...x#productTable
I have no idea about the caliper issue
V1nc3nt likes this.
yamaharandy is offline
post #8 of 21 (permalink) Old 03-16-2017, 10:31 PM
O2 Bung
The Akrapovic link pipe should have 3 Bungs.. I had the Akra Link and end Can and its has 3 bungs. 2 in the front where it connects to the headers and one after the end of of the y pipe..
Enzo15R1 is offline
post #9 of 21 (permalink) Old 03-16-2017, 10:56 PM
c(','c)
2muchbluE's Avatar
Up for answer
you need 5mm spacers for the m4 calipers to work. I have the same set up.
Getting the caliper on is the issue? After installing the 5mm spacers, press the pads in the caliper all the way open. Then tilt the caliper in a slight angle to get it over the brake disc evenly. It is a close fit but it will go on.
hit up @SBK Unlimited for the spacers
Promtana, Yautja and V1nc3nt like this.
2015R1M@Instagram
2muchbluE is offline
post #10 of 21 (permalink) Old 03-19-2017, 08:58 PM
Costa Rica R1's Avatar
V1nc3nt I own the Akrapovic Evolution GP 3/4 and have FTECU autotune with auto-blipper. The autotune sensor fits in the last hole towards the rear you have to unplug the 2 oem sensors up front and plug them with 2 blanking nuts.
Sent from my SM-G920I using Tapatalk
Costa Rica R1 is offline
post #11 of 21 (permalink) Old 03-19-2017, 09:06 PM Thread Starter
Can I have a clear picture of your M4 calipers, I wanna see how it was installed
V1nc3nt is offline
post #12 of 21 (permalink) Old 03-19-2017, 09:12 PM
c(','c)
2muchbluE's Avatar
Best I can do for now....
Promtana and V1nc3nt like this.
2015R1M@Instagram
post #13 of 21 (permalink) Old 03-19-2017, 09:17 PM Thread Starter
Thank you, so we do not do anything with this pad and front fender right? Just use spacer and plug & play
V1nc3nt is offline
post #14 of 21 (permalink) Old 03-19-2017, 09:40 PM
c(','c)
2muchbluE's Avatar
Yes, it bolts right up
2015R1M@Instagram
post #15 of 21 (permalink) Old 03-24-2017, 07:04 PM Thread Starter
Hello i cant, the fender
V1nc3nt is offline
post #16 of 21 (permalink) Old 03-24-2017, 09:09 PM
Gian11
gsa013's Avatar
that`s because the R1M has a different fender that doesn`t attach in the back like the regular R1 fender does.
Guess you can always upgrade to an R1M style carbon fender to make it work.
gsa013 is online now
post #17 of 21 (permalink) Old 03-25-2017, 12:03 AM
Chef R1
R1@150@alltimes's Avatar
Use a zip tie for that rear fender bolt. Thats what I did with my brembo calipers which are not M4's, but its the same shit...
R1@150@alltimes is online now
post #18 of 21 (permalink) Old 03-25-2017, 08:06 AM
Gian11
gsa013's Avatar
that´s one way to go about it...
me.. My OCD would push me to buy a new fender.
post #19 of 21 (permalink) Old 03-25-2017, 08:58 AM
I'm the happy go lucky mod!
Kevap's Avatar
Mine too... zip ties are only needed in an emergency fix after crashing to get you back on the track/road.
TEAM: SO SCARED NO LEAN
Kevap is offline
post #20 of 21 (permalink) Old 03-25-2017, 02:39 PM
Go Hard or Go Home!
Carlos461's Avatar
I never noticed that the R1M fender mounted differently than the R1. Here is a pic of mine, I took off the bracket that holds the brake line and I have the GP4-RX calipers, not M4.
Carlos461 is offline
