09 starter failure picture! - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 11 (permalink) Old 10-12-2012, 09:52 AM Thread Starter
For those of you having starter problem on your 09+, this is most likely the problem. The magnets sometime come unglued, and either fall out, or join together as one solid magnet, which is what mine did. Which then becomes to strong and fights the polarity of the starter. I got word from the dealer that Yami is going to cover the entire job ($700) outside of warranty! If you work with the right people, ask nicely, and be patient, Yami will work with you!! What a great manufacture, this definitely strengthens my ties to Yamaha Motor Co.
speileoR1 is offline
post #2 of 11 (permalink) Old 10-12-2012, 10:05 AM
RedDragon666's Avatar
thanks dude, i'll keep an eye out for that failure with my customers.
RedDragon666 is offline
post #3 of 11 (permalink) Old 10-12-2012, 10:54 PM
R1, art of engineering
Halo_2's Avatar
Is it possible to glue them back into position ??
Halo_2 is offline
post #4 of 11 (permalink) Old 11-06-2012, 07:48 AM Thread Starter
No, at least it's not recommended. The dealer covered my issue under warranty (2 years outside of warranty).
post #5 of 11 (permalink) Old 11-06-2012, 01:46 PM
kickarsmann's Avatar
Do you have a before and after video or sound clip? I only have starting problem in the cold. Summer time starts up fine.
kickarsmann is offline
post #6 of 11 (permalink) Old 11-10-2012, 06:21 AM
Darquechild010's Avatar
Dude!!! I'm so glad you posted this... I've been having a starter issue... If park while my bike is at 221° or more the starter sounds like my battery is dead...
Darquechild010 is offline
post #7 of 11 (permalink) Old 11-14-2012, 10:15 AM
JOKER BANAJA
Joker BANAJA's Avatar
The magnet will fail or unglued because of the heat of the engine
Joker BANAJA is offline
post #8 of 11 (permalink) Old 11-14-2012, 10:20 AM
JOKER BANAJA
here are many problem with r1 2009-2011:
1-The heat of the engine will decrease the pulling power of the magnet in the starter
2-The fans will Eat 1.5 v dc from the battery while the engine is not running
So it will be very difficult to start the engine
The solution is :
1- put the key ,put on the switch, wait for 2 sec and push the starter switch to start if not
Wait until the sound of the injector fuel is clear and start again
Keep some time between around 2 second and
Repeat the operation for maximum three time
The motorbike will start
2- don't try to start the Engine while the fan is running
I DONE THIS and I don't have now any problems with the starter or battery
post #9 of 11 (permalink) Old 11-14-2012, 10:23 AM
The solution is :
That's exactly what I been doing lately... Thanks
post #10 of 11 (permalink) Old 11-14-2012, 10:37 AM
Hmm I wonder if it's possible to get the dealer to check it out while i get my valve adjustment. Since they are going deep in that engine.
post #11 of 11 (permalink) Old 11-14-2012, 10:38 AM
JOKER BANAJA
The problem is not the starter or the battery
My advice to every one have starter problem:
1-push the starter after the sound is clear
2-don't push the starter if the fan is running you have to wait for the engine to cool down then you can start
3-don't switch off the engine direct
You must wait at least for 2 minutes before switch off the engine
Because the injector will have some fuel must be burn , so it will be difficult to burn the fuel when you start the engine next day
My advice give some time 2 minutes before switching off the engine and the extra fuel in the injector will clear
And you can start the engine next day Easley
Thankx for every one
