07 Rear Caliper Replacement - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 7 (permalink) Old 10-31-2012, 09:41 PM Thread Starter
Hello,
I accidentally broke the seal on my rear caliper while removing the tire. The shop told me they would charge me $120 to have the rear caliper rebuilt. I was wondering if i buy a used caliper for $50 do I still need to rebuild the used one or I can just put the brake pads on it and start using it?
Thank you
rider18 is offline
post #2 of 7 (permalink) Old 10-31-2012, 09:50 PM
skunkworx's Avatar
Just get a seal kit and do it yourself. It's the rear so there's only one piston. I think 30 bucks or so should cover it.
All threads lead to Frank...
skunkworx is offline
post #3 of 7 (permalink) Old 11-01-2012, 08:27 PM
I've fallen and I can't get up
Blue Streak's Avatar
Originally Posted by rider18 View Post
Hello,
Thank you
Like skunk said - its easy to rebuild yourself.
To answer your question - if you buy a used rear it is probably good to go as most come off of crashed bikes and are salvaged parts. You should be able to do a quick swap out (if it comes with pads in make sure you clean your discs before using different pads).
Blue Streak is offline
post #4 of 7 (permalink) Old 11-09-2012, 03:27 AM
My R1 is MY ROAD DAWG 4 LIFE
deecarp1's Avatar
Send a message via Yahoo to deecarp1
if you need a rear caliper I have two, I can easily let one go.
Sig courtesy of Uncle P
My Thread update
deecarp1 is offline
post #5 of 7 (permalink) Old 11-09-2012, 05:05 AM
Hope is what makes us Human.
Benocehcap's Avatar
Hello,
Thank you
Dont rebuilt a OEM stock part
if you dont have the money for upgrade get a use one. Like "deecarp1" is offering. Just make sure he sends you pix and he guarantees u that the parts is in 100% working condition.
“Not every legend is a myth, some are flesh and blood. Some legends walk among us, but they aren’t born, they’re built. Legends are made from iron & sweat, mind and muscle, blood and vision and victory. Legends are champions, they grow, they win, they conquer"
Benocehcap is offline
post #6 of 7 (permalink) Old 11-09-2012, 05:49 AM
I disagree. There is nothing wrong with the OEM calipers and rebuilding one is a good way to ensure it's in proper working order during the life of the bike. Why spend $50, or more, for a used caliper when you don't know it's condition? It might be slightly bent, warped, corroded on the inside, etc. If you buy used, you should take the opportunity to rebuild it to ensure you have a properly functioning part.
The OEM calipers are easy to rebuild if you have some mechanical abilities. The rear caliper kit is around $50 or less:
http://www.boats.net/parts/search/Ya...PER/parts.html
Item #4 on that page. It's $51.08 MSRP, $38.25 they are selling it at.
fjorn is offline
post #7 of 7 (permalink) Old 11-09-2012, 06:02 AM
deecarp1's Avatar
Here is a link to the page that has a picture of the caliper. the price in the add is for the entire assembly shipped. or make a reasonable off for just the caliper.
FS: 07-08 R1 Stock Parts - Tank, Fairings, Rotors, Shock, Rear Cailper, Taillights
My Thread update
deecarp1 is offline
