04-06 to 07-08 brake difference? - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 10 (permalink) Old 11-14-2012, 05:37 PM Thread Starter
U win some U lose some
mr2guru's Avatar
Are the brake rotors the same or is there a difference?
Can I put 07 forks and 6pot brakes on my 06 and have it line up with my current rotors?
Thanks
mr2guru is offline
post #2 of 10 (permalink) Old 11-14-2012, 05:42 PM
The Lead Farmer
Meister37's Avatar
No.
Kirk is a total dick.
Meister37 is offline
post #3 of 10 (permalink) Old 11-14-2012, 06:09 PM Thread Starter
mr2guru's Avatar
No.
Well poop. New rotors too? Will they at least bolt to the 04-06 wheels?
mr2guru is offline
post #4 of 10 (permalink) Old 11-14-2012, 06:39 PM
The Lead Farmer
Meister37's Avatar
You will need new rotors and fender. The wheel is the same. The 310's bolt right up.
post #5 of 10 (permalink) Old 11-19-2012, 04:47 PM Thread Starter
mr2guru's Avatar
Apparently all I need are these spacers... perfect fit... for '06 320mm rotors and the '07 up brakes/forks
mr2guru is offline
post #6 of 10 (permalink) Old 11-19-2012, 04:54 PM
R1der
kingnba6's Avatar
did you do the swap? so you are doing this mod on a 06 right? basically getting 6pot brakes on a 06?
My 06 R1 Build Thread
R1-013 'Lucky 13th' Squadron
kingnba6 is offline
post #7 of 10 (permalink) Old 11-19-2012, 05:09 PM Thread Starter
mr2guru's Avatar
Doing it here shortly...
Picked up the '07 forks with Ohlins internals from RSV4 and will have them this week. I had some '07 brakes laying around. Anyway I wanted to keep my Galfer rotors $$$ and this way I can!
mr2guru is offline
post #8 of 10 (permalink) Old 11-22-2012, 08:25 PM
Agreeded kingnba6. Im doing the same thing actually.. 2008 forks and the 6 piston calipers will botl right up ypu just need a 5mm spacer the fit for the larger rotors on the 04-06 models
04r1j89 is offline
post #9 of 10 (permalink) Old 11-24-2012, 06:29 AM Thread Starter
mr2guru's Avatar
Done... also painted the spacers. You have to look hard to notice them.
mr2guru is offline
post #10 of 10 (permalink) Old 11-24-2012, 08:17 AM
R1der
kingnba6's Avatar
great work! made a lot of peoples life easier
kingnba6 is offline
