Please help, coil/spark plug issues!!! - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 31 (permalink) Old 11-21-2012, 07:05 PM
Rubber side down
did your old plugs look identical to new, and if not why did you install a plug that was not the same exactly that is why your coils are not fitting
Slvr04r1 is offline
post #22 of 31 (permalink) Old 11-21-2012, 07:06 PM
Rubber side down
u must unscew the tip in new plugs
Slvr04r1 is offline
post #23 of 31 (permalink) Old 11-21-2012, 07:08 PM
Rubber side down
hopefully you didnt do any damage to coils trying force them
Slvr04r1 is offline
post #24 of 31 (permalink) Old 11-21-2012, 07:13 PM
Rubber side down
hum
Slvr04r1 is offline
post #25 of 31 (permalink) Old 11-21-2012, 07:40 PM Thread Starter
How do I unscrew the tip? I tried. And I didn't do any damage I put the old ones in and it runs fine
maxrider is offline
post #26 of 31 (permalink) Old 11-21-2012, 07:44 PM
Rubber side down
I just sent you a private message check it
Slvr04r1 is offline
post #27 of 31 (permalink) Old 11-21-2012, 07:46 PM
Rubber side down
Slvr04r1 is offline
post #28 of 31 (permalink) Old 11-21-2012, 07:46 PM
Rubber side down
its very basic use pliars and a wrench to hold the plug
Slvr04r1 is offline
post #29 of 31 (permalink) Old 11-21-2012, 08:16 PM Thread Starter
-_______- I tried using my fingers I didn't think to even use pliers lol
maxrider is offline
post #30 of 31 (permalink) Old 11-21-2012, 08:47 PM
Rubber side down
let me know what you find out i know that will fix it
Slvr04r1 is offline
post #31 of 31 (permalink) Old 11-26-2012, 02:05 PM
R1 pilot
RedDevil154's Avatar
Unscrew the little nipples on the end of the plug as shown. They are tight from NGK. I used my leatherman to get them broke loose. Once those are off the coils will go on but they dont go on easy but with some downforce and a turning motion they should slide on.
RedDevil154 is online now
