engine died after hitting bump - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
post #21 of 30 (permalink) Old 12-07-2012, 06:30 PM Thread Starter
Josestrainz's Avatar
WHERE CAN I DOWNLOAD THE 06 R1 WORKSHOP MANUAL. I did hard reset.Have gone through every plug wire and connection. Repaired the tilt sensor, turned over the engine and it still wont start. I ve ran system diagnostic and i get no codes. WTF am I missing??????? I spent an hour and a half on phone with mechanic from local dealership and we still couldn't figure out.....the bike when i turn the key on, it primes and i hearthe fuel pump. I pulled the spark plug cranked it over and have no spark!!!!
Josestrainz is offline
post #22 of 30 (permalink) Old 12-07-2012, 06:42 PM
Bourbon is my blood
T.C.'s Avatar
Try this thread, There are a few links in it, you will find it in there.
http://www.r1-forum.com/forums/showthread.php?t=275916
Your not getting power power to your coils. Trace the wires back from your coils to the battery, the problem is in between the two.
Sig by Uncle P.
Call me an alcoholic all you want. I will not remember in the morning, or the next day.
My '02 R1 thread..
T.C. is offline
post #23 of 30 (permalink) Old 12-08-2012, 12:40 PM Thread Starter
I downloaded the service and racing manual. i repaired the tilt sensor, went through the checklist, have no codes showing but still will not start. It will turn over just fine but it wont start. I am now checking why I have no spark. Will let you guys know asap.
Thanks
post #24 of 30 (permalink) Old 12-08-2012, 11:46 PM
R1 throttle cracker
Dnas_tat2s's Avatar
Possible stator went out??
Dnas_tat2s is offline
post #25 of 30 (permalink) Old 12-20-2012, 09:27 AM
Bourbon is my blood
T.C.'s Avatar
Update?
Sig by Uncle P.
My '02 R1 thread..
T.C. is offline
post #26 of 30 (permalink) Old 12-20-2012, 11:54 AM
look for special phrase here
greenstreak9205's Avatar
I would've started at the beginning/root and check battery connections. Woulda caused all those problems
The Man, The Legend Uncle P
Phantom Squadron CO
greenstreak9205 is offline
post #27 of 30 (permalink) Old 12-20-2012, 01:28 PM
Ride it like you stole it!
Does the bike have an immobilizer (chip inside the key). One reason for the bike turning over but not starting could be from the computer not recognizing the key in the ignition. If the computer and the key don't have the right 'code', the bike won't start. I'm really curious what the problem ends up being.
Trevmo is offline
post #28 of 30 (permalink) Old 12-20-2012, 01:40 PM
WOG
SPanega SS's Avatar
Not here in the states.
SPanega SS is offline
post #29 of 30 (permalink) Old 12-20-2012, 01:50 PM
Yeah, I kinda figured. Wasn't sure if all bikes in the states were that way.
Trevmo is offline
post #30 of 30 (permalink) Old 12-20-2012, 02:08 PM
R1, "A Superior Addiction"
cyclepsycho7's Avatar
If he has a Scorpion Alarm system that is exactly what would happen if you hit a bad bump. That's why I didn't install that option.
Lucky 13 Squadron
cyclepsycho7 is offline
